Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-21-2007, 05:18 PM   #1
stopltracr
CF Member
Default What Fuel System Mods Needed For Increase From 6 To 8psi?
I'm considering increasing the boost on my Procharger from 6 to 8psi. Right now I have the 48lb injectors that came with the kit. Would a Boost-A-Pump be sufficient or would I also need 60lb injectors?
stopltracr is offline   Reply With Quote
Old 10-21-2007, 08:55 PM   #2
onfire
CF Senior Member
48lb injectors will be fine with 8psi. Just need a retune for safety.
Which pump are you using now? Single Walbro without a bap will be fine for 8 psi.
onfire is offline   Reply With Quote
Old 10-21-2007, 09:33 PM   #3
07MontRedcp
CF Senior Member
Support Corvetteforum!
07MontRedcp's Avatar
I have the boost-a-pump and 60# injectors and no problems.
BJK
__________________
APS TT 630 rwhp/654 rwtq @ 9 psi
'07 Z51, TR6060 conversion w/Z06 ratios. DTE Stage 4 Quaife Diff w/brace (3.73). Z06 Brakes, mild turbo cam & dual springs (222/222, LSA 115, .581/.581), LS9R clutch, GT2 Coilovers, Autometer Cobalt Fuel & Boost Guages, Progressive Alky Controller, and e-Boost2 Controller. PFADT poly bushing for control arms and Sports sway bars. MGW shifter. 3" B&B Fusion. RSI Stage 1.5 fuel system.
07MontRedcp is offline   Reply With Quote
Old 10-21-2007, 10:19 PM   #4
ayousef
CF Senior Member
Send a message via MSN to ayousef
Quote:
BJK
how much power are you making, I am using 60lbs and my tuner is telling me that I need smaller ones
ayousef is offline   Reply With Quote
Old 10-22-2007, 12:11 AM   #5
07MontRedcp
CF Senior Member
Quote:
I made 654 rwtq and 630 rwhp @ 10 psi as my max WOT tune. However,
on the street I run 8 psi which gives me 597 rwtq and 593 rwhp by using my e-Boost2 controller.
If your tuner is telling you that you need smaller ones it probably has to do with the duty cycle of the injector. I suspect that there are ideal efficiency ranges for injectors but have not seen the charts. The APS TT comes with sixty pound injectors and LAPD never mention that they were to big. I'll probably do some research the next couple days to learn a little more.
BJK
__________________
Old 10-22-2007, 12:18 AM   #6
99Silverbullet
CF Senior Member
CI 8 & 9 Veteran
St. Jude Donor '07-'08
99Silverbullet's Avatar
yah i agree with him, i have the aps kit and have no fuel problems what so ever. I have an msd boosta pump, walbro high flow fuel pump and 60lbs..and the cars liking it
99Silverbullet is offline   Reply With Quote
Old 10-22-2007, 12:51 AM   #7
07MontRedcp
CF Senior Member
I just found the thread "stock injector size??" in the C6Z06 section, that you started, and it looks like I was right about injector charts and maximum duty cycles.
My car runs extremely well under all conditions. I can drive around town or on long trips and never have the TT go into boost and get over 30 mpg. I can also run the boost anywhere between 7 psi and 10 psi and still no problems. You MAY have a problem with a bad/sticky injector
BJK
__________________
Reload this Page What Fuel System Mods Needed For Increase From 6 To 8psi?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Technical Summary and FAQ - Please Read on a Regular Basis. bogus C4 Tech/Performance 82 09-15-2011 12:07 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
