Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-16-2007, 07:05 PM   #1
R50THC5
CF Senior Member
R50THC5's Avatar
Default ATI Procharger clatter
When I drove past a co-worker at work I was asked what the racket was. He told me it sounds like some bearings going bad or something was very loose. Anyone else hear something similar with theirs.
R50THC5 is offline   Reply With Quote
Old 10-16-2007, 07:36 PM   #2
saplumr
CF Senior Member
Support Corvetteforum!
saplumr's Avatar
I had a similar sound when the front oil seal started to leak. Pretty bad rattling sound. Took 30 minutes to pull the head unit, sent it to ATI for rebuild under warranty. Check for any oil at bottom of the head unit.
Bruce
saplumr is offline   Reply With Quote
Old 10-16-2007, 07:46 PM   #3
R50THC5
CF Senior Member
R50THC5's Avatar
I will check. My install is less than 2 1/2 months old. This concerns me. Thanks for info
Old 10-16-2007, 07:57 PM   #4
06.Z51.MontRed.Vert
CF Senior Member
St. Jude Donor '08-'09
06.Z51.MontRed.Vert's Avatar
Location: Eastern PA:ECS Paxton Novi 1500(676rwhp,585tq on stock engine),LG headers, 410's, Corsa Sports, ECS Alky Kit
Maybe he thinks it is going to sound like a Honda? Prochargers aren't quiet thats for sure.
06.Z51.MontRed.Vert is offline   Reply With Quote
Old 10-17-2007, 06:46 AM   #5
R50THC5
CF Senior Member
R50THC5's Avatar
I did not think it was an excessive noise but have not heard anyone elses to compare with. Guess I will call ATI and ask some questions. Hopefully get a fair and honest answer.
Old 10-17-2007, 08:30 AM   #6
EuroRod
CF Senior Member
EuroRod's Avatar
The straight cut gears in the ProCharger make some scary noise at idle. If the noise goes away, off idle, then it should be okay. Good luck.
EuroRod is offline   Reply With Quote
Old 10-17-2007, 10:24 AM   #7
Busa196
CF Senior Member
Busa196's Avatar
Send a message via Yahoo to Busa196
Quote:
On my last Pro-Charger car I had the same noise......perfectly normal and I had no issues with it.
Busa196 is offline   Reply With Quote
Old 10-17-2007, 01:22 PM   #8
5 Liter Eater
CF Senior Member
St. Jude Donor '11
5 Liter Eater's Avatar
Quote:
It's annoying to say the least but not abnormal.
__________________
Bill Winters
'05 Black on black M6 Z51 - TTIX and forged 408 in the works.
"When life hands you lemons you upgrade to a C6." - Me
5 Liter Eater is online now   Reply With Quote
Old 10-17-2007, 06:06 PM   #9
R50THC5
CF Senior Member
R50THC5's Avatar
No oil on the bottom side. Thanks for all the feed back. I feel more at ease.
Old 10-17-2007, 08:03 PM   #10
Sportsdude
CF Senior Member
Sportsdude's Avatar
The noise on my P1 is more of a quite high pitch whistle
Sportsdude is offline   Reply With Quote
Old 10-18-2007, 07:44 AM   #11
0EPP
CF Senior Member
The straight cut gears do indeed create the noise that you mentioned, and is perfectly normal. The noise tends to get quieter as the blower gets miles on it and the gears break in. Bob
EPP is offline   Reply With Quote
Reload this Page ATI Procharger clatter
Tags
cut, gears, procharger, straight
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
ATI Procharger Noise? BBC5 C5 Forced Induction/Nitrous 22 10-20-2004 06:04 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
