Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-10-2007, 01:01 AM   #1
bowmanized
CF Senior Member
bowmanized's Avatar
Default Building a forged 402...
I want to go with a stroker forged bottom end to create more NA power and hold 14.7 lbs of boost. Am I better off buying the crank, rods, pistons, rings, etc., and have it built or just buy a built shortblock like texas-speed offers. Where can I find prices for cranks etc if that route? From a price perspective it seems like just reusing the stock block I'd save some money. I'd like to be able to run AFR 225 with a 72cc combustion chamber and -2 or -4 pistons. Or I may use the ported LS7 heads so I can just use Z06 stock headers and exhaust. For the sleeper/semi-carb legal car, plus I could get them cheap. I'm looking to start with 700rwhp with the S-trim and then be able to upgrade to T-trim and make 875rwhp. Is that reasonable?
bowmanized is offline   Reply With Quote
Old 10-10-2007, 07:47 AM   #2
0EPP
CF Senior Member
Quote:
It would most likely be less money to buy a built shortblock, but here are the parts we typically use. I would go with the AFR heads, as they have a much thicker deck surface. Bob
http://www.exoticperformanceplus.com...html?item=1078
Compstar crank
http://www.exoticperformanceplus.com....html?item=683
Compstar rods
http://www.exoticperformanceplus.com....html?item=686
Diamond pistons
http://www.exoticperformanceplus.com....html?item=151
AFR Heads
EPP is offline   Reply With Quote
Old 10-10-2007, 05:59 PM   #3
pennys58
SC CF Senior Member
St. Jude Donor '06-'07-'08
Support Corvetteforum!
pennys58's Avatar
Send a message via AIM to pennys58
I did a very similar build. I picked her up today to put some miles on the new engine, so far 100. I will have another 100 on tonight and will have it tuned tomorrow. I don't have the heads, but I do have a blower cam and meth. If everything works to the numbers I want, I will send you my build sheet on the engine. Pretty much the same parts that EPP stated, except I have different pistons. I also got a ported oil pump. I will tell you what. At 20mph and at a 1/4 throttle, it is breaking the tires loose!
John
pennys58 is offline   Reply With Quote
Old 10-10-2007, 06:39 PM   #4
Vindication
CF Senior Member
Send a message via AIM to Vindication Send a message via Yahoo to Vindication
there are a lot of top notch engine builders on this website. If your looking for a boost motor I would suggest you also go to the C5 section of this site and do a search in there. You will find tons of 700-900 hp cars in there from people who have gone down the road and could probably give you a better idea as to what set ups to use and costs. LS1tech has some Boost Junkies in there as well so you definately want to get some information from there.
Vindication is offline   Reply With Quote
Old 10-11-2007, 11:25 AM   #5
fsuforever
CF Senior Member
fsuforever's Avatar
I just Bought the Ls2 402 from Tsp as well 9.1 to 1 comp ,Diamond Dished 15 cc pistons ,Scat rods & Eagle crank ,should make 14 lbs of boost & 800 rwhp fairly Easy with the Correct Fuel system ,Also The Short Block Cost me 4,790.00 Delivered to the door
fsuforever is offline   Reply With Quote
Old 10-11-2007, 11:29 AM   #6
Vindication
CF Senior Member
Quote:
Sounds like a good deal to me.
Reload this Page Building a forged 402...
Tags
402, c5, c6, forged
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
DTE LS2 Engine Conversion Performance Upgrade Package- C5 Corvette DTE Powertrain C5 Tech 125 10-07-2005 08:36 PM
Is A 383 Worth It? Big Perm C5 Forced Induction/Nitrous 26 09-08-2005 05:08 PM
LG Motorsports Cam and AFR head special with LG Headers LG Motorsports C5 Tech 57 08-22-2005 07:35 PM
Anyone running the Procharger P-1 Kit? BlownV6 C5 Forced Induction/Nitrous 15 04-10-2005 11:53 PM
LS2 Block Forged 402 INSOMNIAC C5 Forced Induction/Nitrous 20 11-27-2004 10:18 AM
Has anyone been able to run 12's with the 2.73 gears? Evil_Bob C5 General 14 10-26-2004 10:55 AM
twin turbo echerbst C4 ZR-1 Discussion 60 11-18-2003 04:37 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
