Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-08-2007, 08:46 PM   #1
extremecorvette
CF Senior Member
Default Post your Turbo cam specs
I would like people to post there turbo cam specs along with what size the motor is, size of turbos, and boost level.
For example:
Cam Spec Int Exh
Adv Dur xxx xxx
Dur@.050 xxx xxx
Vale Lift xxx xxx
Lobe xxx
427ci
GT35R
18 lbs boost
extremecorvette is offline   Reply With Quote
Old 10-08-2007, 09:08 PM   #2
07MontRedcp
CF Senior Member
Support Corvetteforum!
07MontRedcp's Avatar
Specs in sig.
BJK
__________________
APS TT 630 rwhp/654 rwtq @ 9 psi
'07 Z51, TR6060 conversion w/Z06 ratios. DTE Stage 4 Quaife Diff w/brace (3.73). Z06 Brakes, mild turbo cam & dual springs (222/222, LSA 115, .581/.581), LS9R clutch, GT2 Coilovers, Autometer Cobalt Fuel & Boost Guages, Progressive Alky Controller, and e-Boost2 Controller. PFADT poly bushing for control arms and Sports sway bars. MGW shifter. 3" B&B Fusion. RSI Stage 1.5 fuel system.
07MontRedcp is offline   Reply With Quote
Old 10-08-2007, 09:17 PM   #3
cablebandit
CF Senior Member
408 8.8 cr
238/238 .589/.589 116 lsa
s488
cablebandit is offline   Reply With Quote
Old 10-08-2007, 10:28 PM   #4
Brabus2
CF Senior Member
Brabus2's Avatar
402 cid
9.5:1 cr
230/230 115LSA
__________________
2001 Brabus EV8 Kompressor
2002 S500 Sport
2007 Chyrsler T&C Limited
2006 Brabus ML500 B11
2005 C6 LAPD/APS Twin Turbo 402 cid -sold
Meth-dual nozzle, Blitz i-Color, WCCH LQ9, 230/230 115LSA, FAST 90, Wilwood BBK, LPE hood, Hotchkis bars, PFADT Coilover, LS7 Clutch, Cobalt gauges & shift light, Callaway shifter, Bullets, Z06 Time Attacks & rear fenders, 2bar SD tune.
2009 SL65 AMG (Brabus Tuned)
Brabus2 is offline   Reply With Quote
Old 10-08-2007, 11:29 PM   #5
Shinobi'sZ
CF Senior Member
Shinobi'sZ's Avatar
Comp Xer 224/224 .581 114lsa 110 icl
__________________
Click on link for mods & pics
http://temp.corvetteforum.net/member...es/shinobis97/
347cid PTK TT 01 Z06 835/804 rear hp/tq..on really low boost Here is the vid link http://s95.photobucket.com/albums/l1...BBQ6-30-07.flv
1999 Suzuki Hayabusa
Shinobi'sZ is offline   Reply With Quote
Old 10-09-2007, 05:04 PM   #6
DSOMC6
CF Senior Member
DSOMC6's Avatar
Same cam as Bruce!
DSOMC6 is offline   Reply With Quote
Old 10-12-2007, 06:47 PM   #7
j4three
CF Senior Member
St. Jude Donor '08
j4three's Avatar
I didn't start this thread but as I'll be going TT in a few months I find this thread very informative. This thread could save someone a lot of phone calls. I've spoken to a lot of shops in the last couple of months regarding this very subject.
Thanks to all that responded so far.
How about a few more responses from the rest of you with turbos? It would be very beneficial for anyone going the TT route ... and me of course
j4three is offline   Reply With Quote
Old 10-12-2007, 10:30 PM   #8
1bdasvt
CF Senior Member
St. Jude Donor '06-'09
1bdasvt's Avatar
228/232 114lsa.....................oh $hit,.....I have a Maggie!!
1bdasvt is offline   Reply With Quote
Old 10-13-2007, 03:08 AM   #9
Brabus2
CF Senior Member
Brabus2's Avatar
Turbo Cam Selection 101...good read!
http://www.forcedinductions.com/help.htm
__________________
2002 S500 Sport
Old 10-13-2007, 12:57 PM   #10
j4three
CF Senior Member
St. Jude Donor '08
j4three's Avatar
Very good read ... Thanks Brabus
Old 10-13-2007, 04:22 PM   #11
07MontRedcp
CF Senior Member
Wish I could say the same. I have tried two browsers and both have the same problem. Several pages of the Turbo 101 section are overlaid on each other and end up as garble.
BJK
__________________
Old 10-13-2007, 06:56 PM   #12
Brabus2
CF Senior Member
Brabus2's Avatar
Quote:
BJK
Bruce, here you go buddy...hope this helps some.
How to select a turbo cam
Duration:
Duration is critical to a turbo setup since its probably the single most important event of a turbo motor (i.e. time valve sits open and closed). Since the air is being forced instead of drawn into and out of the combustion chamber, duration will be your largest variable on how that incoming/outgoing air is managed.
Duration when using a manifold or log design on most turbo cams is usually about 6 degrees more intake duration than exhaust duration (226/220, 240/234). This is mainly because a manifold/log design will typically see higher then a 2:1 pressure ratio in the exhaust ( as high as 4:1 with some logs). By using a reverse split duration this will somewhat help prevent from getting exhaust gas reversion.
Duration when using an efficient header setup with most turbo cams will usually be (230/230, 224/224) or better known as a dual pattern cam. The thinking is with the exhaust backpressure being only 2:1 you can leave the exhaust valve open a little longer then if the exhaust backpressure was 3:1 or higher. Also some of the new turbo designs produce a much lower backpressure with the advent of better flowing turbine wheels and housings which further decrease the total amount of backpressure created by the system.
Overlap:
Overlap definition, is the time period when both the exhaust valve and the intake valve are open at the same time. The exhaust valve needs to stay open after the piston passes TDC in order to use the vacuum created of the exiting exhaust gases to maximize the amount of exhaust gas drawn out of the cylinder. The intake valve opens before TDC in order to use the vacuum created by the exiting exhaust gases to start drawing the intake charge into the cylinder.
This sequence of events above are controlled by the duration and LS (Lobe separation) of the cam. On a typical N/A motor this is essential since you have no pressure being developed on the intake side to push the charge into the combustion chamber. The problem with this event is a turbocharged motor will create a larger amount of backpressure on the exhaust side. Due to this event the above definition will not apply. Reason being is, when the intake valve opens at BTDC, the burned gasses in the chamber will exit out the intake since the pressure is lower than the exhaust. Since this is true you would not want to open the intake valve until the piston has started going down, ATDC. This will lower the combustion chamber pressure till it's below the intake manifold pressure.
To calculate the overlap of your cam simply follow these steps below:
**Example turbo cam:**
Duration @ .006 218/212
Lift .544/.544 lift
Lobe Separation (LS) 114
Add the intake and exhaust durations
Divide the results by 4
Subtract the LSA
Multiply the results by 2
Overlap is -6.5 Degrees of overlap
**Example N/A cam :**
Duration 236/242
Lift .568/.576
Lobe Separation (LS) 112
Subtract the LSA
Overlap is 15 Degrees of overlap
Above was the process on how to calculate your cams overlap. As you can see, the overlap in the 2 cams differ greatly. Running the N/A cam example on a manifold setup would be a horribly in-efficient setup and the engine would be operating well below its potential output. While running the example turbo cam would work well even with the most in-efficient of the header systems out there.
Typically a overlap spread of -8 degrees to +2 is a safe bet. Of course this will differ with whatever combination header, turbo and exhaust is used, so those #'s could be higher or lower.
Lift:
How much lift should I get in my cam? Well that will depend on your heads' flow characteristics. To choose the correct turbo camshaft, you really need to know how your cylinder heads flow. Reason is if your cylinder head flows X amount of air at X amount of lift, choosing a cam that has a lift much greater then that will gain you nothing except extra heat and premature wear of the valve spring. Airflow through a head reaches a peak as the valve is opened, then starts to drop off as the valve is lifted beyond that peak. Most of this of this will hold true to definition, but with a forced induction motor, valve lift is not as critical since the incoming air is pressurized.
A good rule of thumb is to select a cam that will lift the valve 20-25% past its peak flow point.
So be the definition above if your head flows best at 0.500" of lift, use a cam that will lift the valve between 0.600" and 0.625". The reasoning behind this is, if you lift the valve only to its peak flow point, then the valve only flows best when it's wide open. The cycle is brief and would only happen once per stroke. So to benefit from you peak flow the most, you want to lift the valve past its peak. That way the valve will pass its peak flow twice in the cycle. The result is more flow during the opening and closing event of the valve. You do not want to raise the valve much past the peak flow though, or you lose total flow by going too high.
Calculating the best lift:
0.500 X 1.20 = 0.600
0.500 X 1.25 = .0625
Conclusion:
There are way too many factors to just say XX cam will make XX power with your combo. Things like "114LS is best, or 117LS, or ..etc", are just blanket statements. Backpressure, RPM range, boost level, target horsepower, A/R of turbo, turbo frame (T3, T4, T6/Thumper), head flow, cubic inches, and even location of turbo...etc. All of these factors are extremely important in determining the cam that best suits your needs. There is no rule of thumb with a turbo cam. There are too many variables and the only way to get the right cam is to take all of those your parameters into consideration, and only then can a proper cam be selected. All of the points of reference above are just to get you on your way to building the best and most powerful turbo system for you. Study your design and ask questions along the way and you will be smiling the next time your opponent lines up next to you. Feel free to contact us for your needs. Also once you have read this and want to know the theory behind turbo charging, check out our advanced look at the engineering behind turbochargers
__________________
2002 S500 Sport
Old 10-13-2007, 06:58 PM   #13
Brabus2
CF Senior Member
Brabus2's Avatar
Stay in touch and keep us posted when you start your TT project.
__________________
2002 S500 Sport
Old 10-13-2007, 07:54 PM   #14
07MontRedcp
CF Senior Member
Thanks Richard!!
BJK
Old 10-16-2007, 10:45 PM   #15
j4three
CF Senior Member
St. Jude Donor '08
j4three's Avatar
Will do but it won't be near the beast you've created. I followed your build ... very nice!
My goals are pretty modest compared to your TT setup but I figure to be around 550-600 rwtq with the cam and stock heads and somewhere between 7.5-9.5 psi.
Again, thanks to all ... very informative.
__________________
2007 LeMans Blue Coupe Z51 MZ6
Grand Sport widebody, APS Twin Turbo & exhaust
Old 10-16-2007, 11:16 PM   #16
07MontRedcp
CF Senior Member
I'm seeing 600rwhp/600rwtq at 8 psi.
__________________
Old 10-17-2007, 05:11 AM   #17
Brabus2
CF Senior Member
Brabus2's Avatar
Thanks!
My street setup is approx. at 640rwhp/680rwtq (8psi), anything above and beyond can get pretty scary on street rubber and unnecessary unless I'm in a track environment. The most rewarding part of a TT setup I have discovered is adjustability....your desire for 7.5-9.5psi is as simple as a push of a button.
Feel free to send me a PM if you have an questions about the APS kit, I'm no expert but here to help.
Best of luck to you!
__________________
2002 S500 Sport
Old 11-04-2007, 12:51 PM   #18
extremecorvette
CF Senior Member
Thank you for all the info
Old 11-09-2007, 01:57 AM   #19
Showdown
CF Senior Member
Showdown's Avatar
Showdown is offline   Reply With Quote
Old 11-24-2007, 08:27 PM   #20
k0bun
CF Senior Member
Location: NJ..."the way I saw it, everyone takes a beating sometimes."
Does anyone know if this cam will work with twin turbos? (APS)
228/228 114LSA .580/.580
k0bun is offline   Reply With Quote
Reload this Page Post your Turbo cam specs
Tags
1996, bb, cam, characteristics, heat, lift, lsx, maximus, motor, reverse, selection, specs, split, turbo, twin
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C6 Z06 Frequently Asked Questions(FAQ) LTC Z06 C6 Z06 Discussion 56 08-02-2011 03:23 PM
Ptk Project NICK YOSKIN C5 Forced Induction/Nitrous 275 07-26-2005 10:27 AM
My 421cid LT5 IS ALIVE AND WELL!!!!! NITROUS JUNKIE C4 ZR-1 Discussion 196 04-10-2005 11:53 PM
Twins Versus Superchargers NICK YOSKIN C5 Forced Induction/Nitrous 12 07-14-2004 09:59 PM
What RWHP can I expect from this 383 setup? ericcer C4 Tech/Performance 26 07-12-2004 12:12 AM
Anyone running TPIS's mini ram intake on an L98? stubbs C4 Tech/Performance 12 10-16-2002 11:42 PM
We ordered my turbo cam today, it's bigger than I woulda' thought. Monty Engine Mods 17 05-17-2002 03:39 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
