Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-08-2007, 01:42 PM   #1
Razrback16
CF Senior Member
Default ATI Procharger Oil Change
Search feature is down currently so I wanted to see what kind of answers I could get.
I have experience with Vortech S/C systems on my Cobra Mustang. From some of the info I've read, it sounds like the installation of a ProCharger would be easier since it doesn't have to tap the oil pan -- my question though is how hard is it to change the oil in the ProCharger and how frequent? Also, is the installation actually easier or less involved that other centrifugal blower systems? One more -- how is the reliability on the ATI units? (when I was actively modding my Mustang, the ATI units constantly had quality issues, specifically bearing issues with the units which pushed me to my Vortech which I've had no issues with, but I like the ATI in that the oil pan wouldn't have to be tapped -- I'm looking for a unit that will be easy on, easy off).
On a side note also -- how are the stock bottom ends holding up to boost? Most of you swapping out the bottom end for a forged setup prior to boost?
Thanks for the help!
__________________
08 Corvette Coupe
Bone Stock
97 Cobra
Forged 4.6L DOHC
Vortech Supercharged (S-Trim - 10.5psi)
Homepage: http://home.columbus.rr.com/razor/home.html
Razrback16 is offline   Reply With Quote
Old 10-08-2007, 05:11 PM   #2
saplumr
CF Senior Member
Support Corvetteforum!
saplumr's Avatar
Before you install the head unit, install a valve and ss drain hose and forget about senseless suction pumping oil for oil change.
saplumr is offline   Reply With Quote
Old 10-08-2007, 07:00 PM   #3
EuroRod
CF Senior Member
EuroRod's Avatar
EuroRod is offline   Reply With Quote
Old 10-10-2007, 07:51 AM   #4
0EPP
CF Senior Member
You can also draw the oil right out of the top of the head unit with a suction kit, such as what they do for marine use. The first oil change is at 500 miles, after that it is every 6,000 miles.
The stock bottom end will handle 7-8 psi of boost without any problems.
Check these LS2 ProCharger equipped cars out. Bob
http://www.exoticperformanceplus.com...Car.php?car=30
http://www.exoticperformanceplus.com...Car.php?car=46
EPP is offline   Reply With Quote
Old 11-17-2007, 05:26 PM   #5
aTX427
Guest
Quote:
What is the fitting size and thread for the head unit?
Old 11-17-2007, 07:02 PM   #6
saplumr
CF Senior Member
saplumr's Avatar
Quote:
#5 Boss
Old 11-18-2007, 02:28 AM   #7
aTX427
Guest
Is that the (1/2 - 20) -5 O-ring Boss?
O-Ring Boss | Straight Thread: The O-ring Boss fitting is a modification of the male JIC where the beveled 37 nose has been removed and a groove has been machined between the threads and the hex in which an O-ring is seated. The female is a port which has been tapped to the proper straight thread size and chamfered at the port face to provide an O-ring seat. The seal is made when the O-ring is trapped between port chamfer, thread under-cut, and the male.
Old 11-18-2007, 04:40 AM   #8
saplumr
CF Senior Member
saplumr's Avatar
Yes it is an o-ring fitting.
Old 11-18-2007, 10:18 AM   #9
excessive81
CF Senior Member
excessive81's Avatar
Send a message via Yahoo to excessive81
to each his own of course but i preffer the part c6dude is making. i have tried all the above methods except the drain and hose and i can tell you anyway that does not remove the oil from the bottom drain hole...ie sucking out the top....leaves some of the oil in the head unit..... i did this before i installed my piece just to see what was left.....
excessive81 is offline   Reply With Quote
Old 11-18-2007, 10:37 AM   #10
saplumr
CF Senior Member
saplumr's Avatar
Quote:
Needless to say it is impossible to leave any oil in the head unit with this drain setup and you dont need to pump it out. Doesn't get much easier than this, but if for some reason you prefer to pump it out..
Old 11-18-2007, 04:16 PM   #11
excessive81
CF Senior Member
yeah that what i ment. a drain from the bottom or the kit like i have. sucking it form the top leaves oil behind. only benifit to the setup i have is you can do it from under the hood...and i like an fittings and braided lines ...lol
Reload this Page ATI Procharger Oil Change
Tags
ati, c6, change, corvette, drain, hose, oil, pics, plug, procharger, suction, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
ATI Procharger Noise? BBC5 C5 Forced Induction/Nitrous 22 10-20-2004 06:04 PM
I'm ready for my first oil change on the Procharger: What's the easiest way? CAracer C5 Forced Induction/Nitrous 13 06-15-2004 05:46 PM
Any other "must have mods" if I do an ATI Procharger on an '02 C5 MN6..? sdunham C5 Forced Induction/Nitrous 25 05-20-2004 10:46 AM
Is everyone happy with their ATI Procharger? CAracer C5 Forced Induction/Nitrous 23 02-02-2004 09:58 AM
ATI Procharger D-1 88 L98 C4 Forced Induction/Nitrous 9 07-28-2003 06:19 PM
ATI Owners please read BLUTHUNDER C5 Forced Induction/Nitrous 9 10-31-2002 12:02 PM
C5 Intercooled ProCharger system now available! tbyrne C5 Tech 134 12-28-2001 05:45 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
