Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-02-2007, 06:44 PM   #1
BrooklynC6
aka allbottle¬hrottle
St. Jude Donor '08
BrooklynC6's Avatar
Location: Brooklyn New York The DVL and the chicken sleep with the fishes....
Default Blown Guys - Boost-a-pump or secondary ??
Blown People - I want to add a fuel delivery system to my Procharged
C6 - Who thinks its better to shell out the extra $ for a secondary pump - Further , am I correct in assuming the the second pump will support a HP bump in the future better than the KB BAP ?
BrooklynC6 is offline   Reply With Quote
Old 08-02-2007, 07:19 PM   #2
C6dude
CF Senior Member
C6dude's Avatar
The BAP is fine for a stock engine with a OE Procharger kit, the supplied pulley and tune.
Now if you start messing around with smaller blower pulleys for more boost/power then your BAP/stock fuel pump might be at their limit at your higher RPM's.
IMO .....If your plan is on a forged short block in the future to run more boost, a secondary fuel system, although not cheap, is definitely a better option as it will meet all your fuel demands without being overworked .
You can take the money for the BAP and put it towards your upgraded fuel system. There are many good ones on the market including A&A Corvettes and APS's fuel systems.
Here's the one I just made for a guy in NY with a soon to be 9 sec C6Z06.
http://76.163.32.26/gpage8.html
I will have his car on my site when he's done in the "Vette Road Warrior" section
__________________
My Youtube Videos : " DPE C6 "
C6dude is offline   Reply With Quote
Old 08-06-2007, 01:58 AM   #3
qwiketz
CF Senior Member
qwiketz's Avatar
Hey, what's the little box with the digital readout on your fuel system?
thanks!
__________________
2004 Jaguar S type R. 4.2L V8 w/ Stiegemeier Snakebite Eaton M112 w/Alky Injection. H&R springs...
92 383, CNC'd LT4 top end, auto, custom vortech YSI trim, progressive alky kit, brembo 13.5's, magnesium speedline 18"'s with 275/335s, 7.30's@97 in the 1/8 (old combo)... The build up of an Low 10 second daily driver.
89 Saleen Clone with a 335" T trim'd blower motor. DFI, CNC'd victor jr's, vic 5.0. Was shooting for high 9's and 740 rwhp. Gone, but definately not forgotten...
qwiketz is offline   Reply With Quote
Old 08-06-2007, 03:37 PM   #4
AlwaysInBoost
CF Senior Member
AlwaysInBoost's Avatar
IMO you can never have to much fuel or pump! After all fuel is what makes power. All a SC, turbo or n2o does is give us the ability to burn more fuel by supplying the oxygen.
I haven't had a chance yet to see how maxed out a blown c6 with a stock fuel system & KB BAP is, but I would guess the duty cycles are up there. Especially considering some of these guys are pushing 600+ whp @ 6500RPM. The stock system just wasn't designed to flow that much fuel and safely support that kind of power.
If it were me I would get a High Output intank fuel pump to replace the stocker, if they are available, with a boost-a-pump and also add a secondary pump that will run when you tell it. either all the time or only when boost comes on via a hobbs switch. That is exactly what I have in my procharged Z and it has worked great so far.
AlwaysInBoost is offline   Reply With Quote
Old 08-08-2007, 12:26 PM   #5
C6dude
CF Senior Member
C6dude's Avatar
Quote:
thanks!
RPM switch, for precice 2nd fuel pump control. I don't run out of fuel until high RPM's so instead of coming on via Hobbs boost switch when boost is sensed, I have it come on at 4500rpm. 1000 rpm before the engine needs the fuel.
Also, If your OEM intank pump ever fails, you can command the second fuel pump to fuel your engine until you make a repair on the OEM pump.
Perry
__________________
Old 08-10-2007, 03:27 AM   #6
NemesisC5
Over The Edge
Support Corvetteforum!
NemesisC5's Avatar
Send a message via AIM to NemesisC5 Send a message via MSN to NemesisC5 Send a message via Yahoo to NemesisC5
__________________
Scotty
"More is Never Enough"
Street_1999 MN6 Coupe:
"A&A Corvette" Vortech S-Trim Supercharged—ECS Alky—Mamofied FAST 90—AFR 205—Comp 220/228—Kooks—Corsa—RPS Triple C/C—Baer "6s"—Pfadt C/O's—Hotchkis Sways—708whp/640wtq SAE @11.4psi Pics Here
R.I.P. Track_2002 ZO6: Dynatechs—Pfadt Oil Cooler—Setrab PS Cooler—Dewitts Rad—DRM Brake/LG Spindle Ducts—PF 01's—R888's—RPM 3.73 Diff w/Cooler—Pfadt C/O's—Pfadt PB's—Pfadt Sways—Pfadt Camber Kit—Evo 2 w/Teamtech—394whp/377wtq SAE
NemesisC5 is offline   Reply With Quote
Reload this Page Blown Guys - Boost-a-pump or secondary ??
Tags
aps, c6z06, fuel, pump
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Supercharger Best suited for Road racing / hotlapping Trans-Damn C5 Forced Induction/Nitrous 20 01-25-2005 04:41 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
