Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-24-2007, 05:44 PM   #1
Rick Voss
CF Senior Member
Support Corvetteforum!
Default Low oil pressure on APS Twin Turbo's
I am concerned with the oil pressure on my 2006 vert APS twin turbo’s. Hot oil pressure (oil temp 245-250) of 18-19 PSI at idle, and 43-45 PSI under heavy load. I like to see over 50 PSI under load to protect the rod bearings. Cold PSI is 29-30PSI at idle, and 50-53 over 3500 RPM. I am running Mobil 1 10w30 presently, and I am considering going to Mobil 1 15w50, or Amsoil 20w50 racing oil. I am curious on your opinions, if this to high a viscosity? Should I consider a high out put oil pump? Another issue I am seeing is I am burning some oil under heavy throttle, and see blue smoke in the rear view mirror. I have used about 1 qt. of oil in 3,000 miles. Also the exhaust outlet is very black and sooty. Is this normal for APS twin turbo's? Thanks for your input.
Rick V
Rick Voss is offline   Reply With Quote
Old 07-24-2007, 08:01 PM   #2
wewing
CF Senior Member
wewing's Avatar
Your idle oil pressure sounds correct. I see about 23psi at 216 degrees oil temperature at 650rpm idle speed using Mobile 1 5w30. I have not seen my oil temp over 225 degrees, so I can't say what pressure I'd have at that temp, but anyway, others have reported similar idle oil pressures with 5w30. I am not uncomfortable with pressures in the 20's since I don't drive the car everyday, and it doesn't idle for long periods.
Lots of people have switched to higher viscosity oils, and others have raised their idle speed to around 800rpm. Both of these solutions will raise the pressure.
As far as the oil consumption is concerned, I have not seen any, but I only have about 1500 miles on my APS kit. The oil consumption could be lots of things. Do you hear your scavenger pump running when you are idling? It is loud enough to hear very clearly in my car. That could be the simplest problem to fix, it could be a wire, a fuse or a relay issue with your scavenger pump. Less likely, of course, would be one of the turbo's exhaust seals, or something in the motor. Check with your tech, it doesn't sound normal.
wewing is offline   Reply With Quote
Old 07-24-2007, 10:43 PM   #3
Subdriver
Premium Supporting Vendor
Subdriver's Avatar
Rick,
I used to run the Series 2000 20w50 in my relatively stock 02 Z06 on the track in the hot Memphis summers, but I've since switched to the AMSOIL SAE 10w40 Marine Synthetic Motor Oil because this oils High Temp High Shear rating is the same as the 15w50 Mobil 1 EP, but in a 40 weight oil. In the 20w50, you'll really have to be careful on the throttle until the oil is very warm or your oil pressure will skyrocket. Since my car was a track only car, letting it warm up for 15 minutes wasn't a problem. But, for a daily driver it is problematical to wait that long for your oil to come up to temp.
If you do decide to go with either AMSOIL fluid, consider the AMSOIL Preferred Customer Program.
Drop me a PM if you have any questions.
__________________
Phoenix Performance/Carbotech Engineering #66 SCCA T1
2004 SCCA MidWest Division T1 Champion
C66 Racing
AMSOIL Direct Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program Members buy at Wholesale - a savings of about 25%
Subdriver is offline   Reply With Quote
Old 07-24-2007, 11:36 PM   #4
0APS
CF Senior Member
Quote:
Rick V
Rick, The info in the link below will help you on the engine oil pressure readings.
Peter http://airpowersystems.com/corvette/...il_control.htm
APS is offline   Reply With Quote
Reload this Page Low oil pressure on APS Twin Turbo's
Tags
aps, c5, corvette, idle, kind, kit, low, oil, pressure, temperature, turbo, turbos, twin
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
