Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-21-2007, 01:35 PM   #1
Z06.R
CF Senior Member
Z06.R's Avatar
Default Cost to put forged pistons/rods in a Z06?
What would it approximately cost to have a set of forged pistons and rods put into a Z06 so you an stay safe when running FI on the LS7 motor?
Z06.R is offline   Reply With Quote
Old 07-21-2007, 02:25 PM   #2
EuroRod
CF Senior Member
EuroRod's Avatar
Titanium rods and fordged pistons and crankshaft already in there.
EuroRod is offline   Reply With Quote
Old 07-21-2007, 02:34 PM   #3
Z06.R
CF Senior Member
Z06.R's Avatar
Quote:
I know that the rods are titanium, but are they forged, and are you sure that the pistons are forged?
Old 07-21-2007, 02:51 PM   #4
RGT
CF Senior Member
RGT's Avatar
Send a message via Yahoo to RGT
Quote:
Pistons are cast, not forged.
RGT is offline   Reply With Quote
Old 07-21-2007, 03:35 PM   #5
bowmanized
CF Senior Member
bowmanized's Avatar
It's about 20 hours to remove and replace the motor down to the block. Depending on your shops rate say $90 per hour that's $1800
Then you need to have a machine shop/engine builder install the new rods and pistons. Prolly $800 on the high side. Prolly around $900 for new rods and pistons. Depends on what you get.
I'd say around $3500 out the door.
bowmanized is offline   Reply With Quote
Old 07-21-2007, 03:58 PM   #6
Vindication
CF Senior Member
Send a message via AIM to Vindication Send a message via Yahoo to Vindication
or you can buy a short block thats ready to go? A good short block probably cost you 4k-5k depending on what you go with?
Vindication is offline   Reply With Quote
Old 07-21-2007, 04:23 PM   #7
RGT
CF Senior Member
RGT's Avatar
Quote:
Call Andy at A&A Corvette. He has forged short blocks in stock. He has a 441 ci LS7 based forged short block that would be killer.
Old 07-21-2007, 04:25 PM   #8
Vindication
CF Senior Member
Old 07-21-2007, 10:51 PM   #9
chriswtx
CF Senior Member
chriswtx's Avatar
Send a message via AIM to chriswtx
The rods are plenty strong, just put in forged pistons and have the machine shop do a light hone for the new rings and rebalance the assembly. Then put it back together..
chriswtx is offline   Reply With Quote
Old 07-22-2007, 01:53 AM   #10
Pio
CF Senior Member
Support Corvetteforum!
Pio's Avatar
Forged pistons are my next step. However, I've been "staying safe" with FI on my Z since February I'm going to forged pistons for more power.
Pio is offline   Reply With Quote
Old 07-22-2007, 08:35 AM   #11
EuroRod
CF Senior Member
EuroRod's Avatar
Sorry, I made a wrong assumption. Figured that if GM spent so much time touting their T-rods they would have capped them off with fordged pistons. Like it would have added $100 bucks to the cost of the car. Guess the crank is a cast unit, too, huh ??
Old 07-22-2007, 03:12 PM   #12
Pio
CF Senior Member
Pio's Avatar
Old 07-22-2007, 08:23 PM   #13
Vette-Pilot
CF Senior Member
Vette-Pilot's Avatar
The Z06 has a forged crank but the weakest link is the cast pistons.
__________________
Vette-Pilot
(Jack)
2007 Lemans Blue Z06 (EVIL Z) :Sold
2006 Black SLK55 AMG
Garland, Texas
Vette-Pilot is offline   Reply With Quote
Old 07-22-2007, 09:16 PM   #14
Z06.R
CF Senior Member
Z06.R's Avatar
Quote:
What else do you plan to have done while you put in forged pistons? Anything with the oil pump or oil system. I've read of a few stock motors having possible oil problems.
Old 07-22-2007, 09:33 PM   #15
NemesisC5
Over The Edge
NemesisC5's Avatar
Send a message via AIM to NemesisC5 Send a message via MSN to NemesisC5 Send a message via Yahoo to NemesisC5
GM uses cast pistons instead of forged for other reasons that have more to do with warranty, and I believe emmissions as well. I know this for sure, it was not just to be on the cheap. Somebody here will catch this thread and chime in with the correct answer
NemesisC5 is offline   Reply With Quote
Old 07-22-2007, 10:39 PM   #16
RWSjr
CF Senior Member
RWSjr's Avatar
Less oil consumption with the Hypereutectic pistons? Might be reason enough for no forged pistons...
RWSjr is offline   Reply With Quote
Old 07-22-2007, 10:41 PM   #17
Pio
CF Senior Member
Pio's Avatar
No issues with the dry sump, going to leave it as is. WeaponsGradeTorque mentioned I should lower the compression, might do that as well. I'm not thinking anything too crazy, I want to get it to around 650 rwhp and 600 rwtq.
Quote:
True, my 03 has a forged L92 and it goes through one quart of Mobil 1 every 1K miles.
Old 07-22-2007, 10:58 PM   #18
WeaponsGradeTorque
CF Senior Member
Quote:
My understanding is that the cast pistons also allow for cooler combustion and hence made more power in this particular case.
WeaponsGradeTorque is offline   Reply With Quote
Old 07-22-2007, 11:36 PM   #19
chriswtx
CF Senior Member
chriswtx's Avatar
cast pistons also allow for tighter clearences and tighter ring gaps. Which equals less noise and better emissions....
Old 07-23-2007, 12:19 AM   #20
NemesisC5
Over The Edge
NemesisC5's Avatar
Quote:
Quote:
Thank You Gentlemen
Reload this Page Cost to put forged pistons/rods in a Z06?
Tags
441, c5, c6, cam, ci, corvette, cost, forged, interenals, internals, intrenals, ls7, pistons, put, rods, z06, zo6
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C6 Z06 Frequently Asked Questions(FAQ) LTC Z06 C6 Z06 Discussion 56 08-02-2011 03:23 PM
Forged shortblocks blu00rdstr C5 Forced Induction/Nitrous 94 12-30-2005 03:08 PM
Best sleeper setup rsxmanjoe C5 Forced Induction/Nitrous 66 08-10-2005 11:10 PM
You wanted pics here's 45 pics. of my MTI 427 C5R Vert for sale! Mopar Jimmy C5 Corvettes for Sale 25 03-16-2005 07:16 PM
My MTI built, installed & tuned 427 C5R 98 A4 Z07 Vert is back on the market! Mopar Jimmy C5 Corvettes for Sale 44 03-16-2005 07:03 PM
G5X-2 Cam and head Results on a C5/Z06... 470.6 rwhp 430.5 rwtq LG Motorsports C5 Tech 111 02-18-2003 01:15 AM
Whats with all the Z06 VS 03 Cobra posts?? Marksman14 C5 Z06 Discussion 118 07-26-2002 08:50 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
