Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-18-2007, 11:05 PM   #1
Busa196
CF Senior Member
Busa196's Avatar
Send a message via Yahoo to Busa196
Default Big HP guys - rear tires......help!
I recently added a D1 and a 3200 stall and I'm making 600rwhp. I currently have some measley 295 Potenza's on a 19x10" rim.....obviously, the tires are pretty much worthless below about 50mph.
I'm getting ready to go to the rear Z panels and I'd like to put on a 19x12 rear with a 345?? What are you guys running for traction? There's no DR available in a 19" so what do you do? Any of you running that Hoosier I've heard about? My car isn't a daily driver or a dyno queen.....I want to be able to use the power to it's fullest extent . I'd run DR's 24/7 if they made them. Any of you switch to an 18" due to the abundant tire selection?
Any of you had good luck with a radial? Suggestions/input welcome
Busa196 is offline   Reply With Quote
Old 07-18-2007, 11:30 PM   #2
C6dude
CF Senior Member
C6dude's Avatar
I'm sure dedicated 19 DR's are just around the corner.
They will not be as effective as 18" or lower dia tires because of the sidewall, but they will be 100% better than any street tire out there.
I have the Hoosier R6 345/19 rear, 285/18 front, but have not mounted them yet to give you any feedback. I think others on the forum have tried ,do a quick search if you want info
I'm trying to wear out my stock tires before I swap for the R6's.
here's a pic. I had them grooved.
They are pretty sticky.
__________________
My Youtube Videos : " DPE C6 "
C6dude is offline   Reply With Quote
Old 07-18-2007, 11:53 PM   #3
Busa196
CF Senior Member
Busa196's Avatar
What are the ones in the pic? Are you happy with them?? I realize they're "pretty sticky" but could you elaborate
Old 07-19-2007, 12:06 AM   #4
pennys58
SC CF Senior Member
St. Jude Donor '06-'07-'08
Support Corvetteforum!
pennys58's Avatar
Send a message via AIM to pennys58
https://www.hoosiertire.com/rrtire.htm
Click on specs, under road racing tires. Go down to SPORTS CAR D.O.T. - RADIAL (A6 & R6), and they are the 19" 345's.
They are a road racing tire, that when re-grooved, can be "used on the street". I am not sure if they have true dot regulations for the street, but people are using them.
The do not have the grooves in them, so you have to get them grooved. I know a guy on the north side of town that has them on his 06' Z06 and loves them to death. The only problem is driving in the rain. And lately, it can be sunny with out a cloud in the sky and all of a sudden it down pours. I think I am going to try the Hoosier Road Racing tires as well though.
John
pennys58 is offline   Reply With Quote
Old 07-19-2007, 12:07 AM   #5
C6dude
CF Senior Member
C6dude's Avatar
.....Hoosier R6 345/19 rear, 285/18 front, but have not mounted them yet to give you any feedback. I think others on the forum have tried ,do a quick search if you want more info.
Sticky as in my fingernail digs in the tread easily
Perry
Old 07-19-2007, 09:21 PM   #6
WeaponsGradeTorque
CF Senior Member
Perry
I use them. They offer amazing grip.
WeaponsGradeTorque is offline   Reply With Quote
Old 07-19-2007, 10:03 PM   #7
NemesisC5
Over The Edge
NemesisC5's Avatar
Send a message via AIM to NemesisC5 Send a message via MSN to NemesisC5 Send a message via Yahoo to NemesisC5
NemesisC5 is offline   Reply With Quote
Old 07-22-2007, 11:48 PM   #8
Rkreigh
CF Senior Member
where do you all get them grooved??? look really nice.
I'd be worried about the race tire carcass on the street, what about them going away after the heat cycles. not sure if they are "tough enough" to survive the mean streets, but they sure would be fun!
Rkreigh is offline   Reply With Quote
Old 07-22-2007, 11:56 PM   #9
C6dude
CF Senior Member
C6dude's Avatar
Quote:
Roger kraus racing. California
__________________
Old 07-23-2007, 07:02 PM   #10
ayousef
CF Senior Member
Send a message via MSN to ayousef
how many miles are those things rated to last up to?
ayousef is offline   Reply With Quote
Old 07-25-2007, 11:13 PM   #11
C6dude
CF Senior Member
C6dude's Avatar
Quote:
I don't think they rate racing compounds in mileage.
I cannot see them lasting more than 6K on the street.
But that is just a guess.
Others might chime in if they wore out a set.
__________________
Old 07-26-2007, 01:12 AM   #12
RJW
CF Senior Member
St. Jude Donor '08
RJW's Avatar
Location: Tinker till it blows... then back it off a notch, maybe!!
So...roughly what did they cost, grooved and out the door?
Thx
RJW is offline   Reply With Quote
Old 07-26-2007, 06:46 AM   #13
NemesisC5
Over The Edge
NemesisC5's Avatar
__________________
Scotty
"More is Never Enough"
Street_1999 MN6 Coupe:
"A&A Corvette" Vortech S-Trim Supercharged—ECS Alky—Mamofied FAST 90—AFR 205—Comp 220/228—Kooks—Corsa—RPS Triple C/C—Baer "6s"—Pfadt C/O's—Hotchkis Sways—708whp/640wtq SAE @11.4psi Pics Here
R.I.P. Track_2002 ZO6: Dynatechs—Pfadt Oil Cooler—Setrab PS Cooler—Dewitts Rad—DRM Brake/LG Spindle Ducts—PF 01's—R888's—RPM 3.73 Diff w/Cooler—Pfadt C/O's—Pfadt PB's—Pfadt Sways—Pfadt Camber Kit—Evo 2 w/Teamtech—394whp/377wtq SAE
Old 07-26-2007, 08:35 AM   #14
WeaponsGradeTorque
CF Senior Member
2K, still stick like Glue, not even close to being worn out. Keep in mind I use these just to improve straight line traction.
Old 07-26-2007, 12:14 PM   #15
C6dude
CF Senior Member
C6dude's Avatar
Quote:
Thx
They usually have the Hoosier tires in stock at Roger Kraus racing.
I think I paid roughly 100 a tire to have them grooved.
Check Tire rack fo the price on the size tires you need.
Perry
__________________
Reload this Page Big HP guys - rear tires......help!
Tags
big, corvette, rear, tires, tube
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
C6 Z06 Frequently Asked Questions(FAQ) LTC Z06 C6 Z06 Discussion 56 08-02-2011 03:23 PM
Big horsepower to the ground Aussierock C3 Tech/Performance 10 01-04-2004 03:57 AM
how much HP will a stock 74 rear end take. bhmyers C3 Tech/Performance 12 09-16-2003 08:19 PM
Crate motor vs. modify original motor? weihemuller C1 & C2 Corvettes 20 02-27-2003 06:59 PM
Need help displaying dyno charts RedZR C4 ZR-1 Discussion 23 07-05-2002 11:25 PM
Help Me Shut My Buddy Up :) bence13_33 C3 Tech/Performance 18 10-14-2001 03:22 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
