Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-18-2007, 12:36 PM   #1
stopltracr
CF Member
Default Procharger Help
Alright, I've decided to do a head/cam swap and I had a few questions. I'm considering either the AFR 205 heads which won't require a pulley swap to maintain the 6.5psi I'm at or the AFR 225 heads which will require an 8psi pulley to maintain the 6.5psi.
Questions:
1. Is anyone having belt slippage with the 8psi 6 rib setup? I can't afford to do an 8 rib swap at this time.
2. I know that the 225 heads with the 8psi pulley will require the addition of a BAP and bigger injectors. Has anyone used the 205 heads and a blower cam and left the fuel system alone?
3. I know that the 225 heads and smaller pulley setup will make more power than the 205 heads with the stock pulley but any idea how much more?
stopltracr is offline   Reply With Quote
Old 07-19-2007, 12:49 PM   #2
AlwaysInBoost
CF Senior Member
AlwaysInBoost's Avatar
whats your current displacement/setup.
I've been told that the AFR225 heads, which I have on my stock cube motor, have a larger bowl diameter then the cylinder bore. I haven't seen this first hand for myself because I don't have a need to take apart the motor but this info came from a reputable source who put the motor together. Just something to think about when making your decission.
AlwaysInBoost is offline   Reply With Quote
Old 07-19-2007, 02:11 PM   #3
stopltracr
CF Member
This is true for the 72cc AFR 225 head which I am considering. The bore diameter of the head is 4.125 and the cylinder bore of a stock LS2 is 4.000. The AFR 225 small bore 65cc heads have a 4.000 bore.
My motor is all stock with the exception of the Procharger. My only concern is the difference in compression between the heads. The AFR 205 66cc heads and the AFR 225 65cc heads will nearly maintain the stock compression ratio and won't require an increase in boost to maintain the final compression ratio of the engine. I've been looking all over and I can't find any comparison between small and large cc heads on actual boost/hp.
Old 07-20-2007, 07:33 AM   #4
0EPP
CF Senior Member
Quote:
Questions:
The better flowing 205cc cylinder heads that you are thinking of installing will still lower the overall boost that your engine is producing. The same goes for when you add headers, exhaust, more cubes, camshaft, and move to a higher elevation.
I have not had problems with the six rib assembly at 8 psi, keep the belt tension tight, and remember that a new belt stretches.
The stock fuel system is barely adequate at 8 psi. I would add a boost a pump when you add the heads. Since it sounds like you don't have a lot of disposable cash laying around, I would not add a head and cam combination to your car with a stock bottom end. The pistons may hold up, or they may not. It's a gamble at best. I would add a better camshaft, the boost a pump, possibly larger fuel injectors, and get the car tuned. Bob
EPP is offline   Reply With Quote
Reload this Page Procharger Help
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Procharger TOO Loud WTF!!! zbest4me C5 Forced Induction/Nitrous 56 06-09-2005 10:16 PM
noisy $9,000 mod. WTF! please help zbest4me C5 Tech 36 06-02-2005 06:35 PM
Toyota Supra djohnson C5 Z06 Discussion 69 01-09-2003 12:38 PM
Attn: ATI Procharger Engineers and Employees vetterdstr C5 Forced Induction/Nitrous 47 12-14-2002 11:43 AM
Overheating with a Procharger -- HELP!!! tscales C5 Tech 12 08-23-2002 12:41 AM
ATI Procharger Install with Pic's and Dyno numbers BBC5 C5 Forced Induction/Nitrous 42 06-03-2002 09:35 PM
C5 Intercooled ProCharger system now available! tbyrne C5 Tech 134 12-28-2001 05:45 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
