Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-17-2007, 07:48 PM   #1
BrooklynC6
aka allbottle¬hrottle
St. Jude Donor '08
BrooklynC6's Avatar
Location: Brooklyn New York The DVL and the chicken sleep with the fishes....
Default A/F Ratio Question
What should to optimal A/F ratio be on an otherwise stock ls2 with a procharger or similar system ? More importantly , what is the point that is so lean that it can cause damage ? Thanks Folks !
BrooklynC6 is offline   Reply With Quote
Old 07-18-2007, 03:47 AM   #2
C6dude
CF Senior Member
C6dude's Avatar
Quote:
Engines are all a little different so optimum AFR will vary slightly as far as producing max HP.
GM puts a very conservative tune to fuel you engine to make up for all the differences in the LS2's.
That is why people are getting some free HP just tweaking a stock computer.
As far as AFR on a stock engine with add on forced induction shoot for 12.5 - 12.8 at WOT .
I have an EGT in my car on the leanest running cyl on LS engines, #7 .Then I tune my car for optimum temp on that cyl.
If you are running high boost levels you can go as rich as 11.0 or more to achieve max power. Running a little richer also reduces detonation by it's cooling effect.
As far as leaning it out where it can cause damage. At WOT your AFR is critical, so running leaner than your optimum tune for power is going to create extra heat and detonation in your engine. You have cast pistons and they would not fare well.
That being said , It depends how long you stand on the throttle when the lean condition arises.
If you have a fuel problem at WOT you need to take care of it before it takes care of your motor. Much more critical with forced induction..
__________________
My Youtube Videos : " DPE C6 "
C6dude is offline   Reply With Quote
Old 07-18-2007, 08:34 AM   #3
EuroRod
CF Senior Member
EuroRod's Avatar
EuroRod is offline   Reply With Quote
Old 07-18-2007, 09:08 AM   #4
NLPerformance.com
CF Senior Member
C6Dude,
I think you meant to say 11.5 to 11.8 for a blown situation, 12.5 to 12.8 is way too lean for a force inducted engine, general rule of thumb for tuning is 12.8 to 13.0 for a naturally aspirated engine, and 11.8 to 12.0, with a little more fuel at peak torque for a forced inducted engine (supercharger or turbo), some engines are different and want more fuel. Every engine is different and will tell you what they want on the dyno when tuning, just make sure you keep your timing reasonable when tuning for blown applications, so you don't get into any detonation. Good Luck, Geoff.
NLPerformance.com is offline   Reply With Quote
Old 07-18-2007, 09:13 AM   #5
Busa196
CF Senior Member
Busa196's Avatar
Send a message via Yahoo to Busa196
Quote:
Originally Posted by NLPerformance.com View Post
C6Dude,
Busa196 is offline   Reply With Quote
Old 07-18-2007, 11:42 AM   #6
C6dude
CF Senior Member
C6dude's Avatar
C6Dude,
Geoff
12.5 -12.8 is what I meant.
The reason is because he said on a stock LS2 with a bolt on kit.
I agree with richer AFR for higher boost levels.
There is a tuner on this forum who goes even leaner, 13 or more at WOT with no detonation. He has tuned cars for many years and is a veteran tuner. I was at his house a couple of months ago and he gave me some pointers and showed me some of his results. I was floored when he told me that and I was real sceptical. I will not reveal his name because he is secretive with his tuning like most tuners.
Some tuners I know in my area will run very rich AFR's to cool the cylinders if they are experiencing detonation because they do not want to lower their timing any more. I think that is a bandaid approach.
Myself ,I put a base timing map for F/A apps. Then I set the AFR where it makes the most power on the dyno. After that I start playing with the timing tables again raising timing slowly until slight detonation is present ,then I back it off until it's completely gone.
__________________
Old 07-18-2007, 12:40 PM   #7
Busa196
CF Senior Member
Busa196's Avatar
Quote:
Originally Posted by C6dude View Post
Geoff
I've got a stock LS2 with a bolt on kit and you woudn't catch me dead running anything over low 12's on a FI car.....and I run Torco and straight meth, so detnoation is no problem for me. My current A/F up top is 11.7-11.8. To each their own though.....opinions on FI cars, safe boost levels, A/F ratios, is like watching the local weather forecast, every channel has a different % chance of rain.
-Busa196-
Old 07-18-2007, 12:45 PM   #8
BrooklynC6
St. Jude Donor '08
BrooklynC6's Avatar
On my last Dyno run the car was pretty much stable at 10.2 to 10.6 through the rev band - Of course I had told my tuner that I wanted a very conservative tune - but is this running TOO rich ? Based on your explanations it seems I have a good amount of horsepower to gain while still staying in "safe" territory ? Thanks Guys
Old 07-18-2007, 01:22 PM   #9
Busa196
CF Senior Member
Busa196's Avatar
Damn, that's REAL rich.....and unnecessary if you ask me. You should really be in th levels discussed above.....conservative would be 11.0-11.5, IMO. But, I'm no expert and no tuner.......some actual "tuners" may chime in here
Old 07-18-2007, 01:39 PM   #10
C6dude
CF Senior Member
C6dude's Avatar
Quote:
Way too rich....
You have some power left on the table thats for damn sure.
...... For a conservative safe tune for people that are street cruisers and daily drivers ,I set AFR to 12.0 at WOT. When I adjust their timing for power I back off a little more than usual after sensing KR to give them a bigger window for safety.
Old 07-18-2007, 01:58 PM   #11
BrooklynC6
St. Jude Donor '08
BrooklynC6's Avatar
Aside from loosing potential power and maybe burning more fuel - are there any reliability downsides to running such a rich tune ?
Old 07-18-2007, 02:08 PM   #12
C6dude
CF Senior Member
C6dude's Avatar
.....A little rich is OK ,but yours is too rich
After a while you will form deposits on your pistons and combustion chambers in your heads. Then you risk detonation because the deposits glow red hot and ignite your mixture before the spark plug does. (very bad).
Old 07-18-2007, 03:30 PM   #13
BrooklynC6
St. Jude Donor '08
BrooklynC6's Avatar
Gotcha - That makes alot of sense I guess this is something I have to take care of - Thanks for the Info !!
Old 07-18-2007, 04:43 PM   #14
Busa196
CF Senior Member
Busa196's Avatar
Exactly.........
Old 07-18-2007, 06:08 PM   #15
LS7 ZO6
CF Senior Member
LS7 ZO6's Avatar
How do you know what your air fuel is do you have a guage in the car.
When i get my clutch fixed i would like to put An LM1 wide band in my car.
LS7 ZO6 is offline   Reply With Quote
Old 07-18-2007, 06:15 PM   #16
BrooklynC6
St. Jude Donor '08
BrooklynC6's Avatar
I dont have a guage , but I am thinking about getting one now.... right now all I have is a boost and FP guage . When my tuner runs it on the dyno , they moniter A/F ratio on their comp.
Old 07-18-2007, 08:30 PM   #17
excessive81
CF Senior Member
excessive81's Avatar
Send a message via Yahoo to excessive81
i just put a aem wide band in my car ($275.00). works great. it also works well with my hp tuners software. they already have it in their menus. it nice to know when you got this much damage potential that things are ok!!!!
excessive81 is offline   Reply With Quote
Reload this Page A/F Ratio Question
Tags
af, forced, induction, needed, present, ratio, richer
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Still Trouble shooting A/F ratio & Pressure! Herb C4 Forced Induction/Nitrous 24 12-17-2004 12:40 PM
A/F Ratio & RWHP Question Als98C5 C5 Forced Induction/Nitrous 20 06-03-2004 04:39 PM
A/F ratio gauge question. Sliding C4 Tech/Performance 10 10-06-2003 07:54 PM
A/F Ratio Question: Do these numbers look good? TIMSPEED C4 Tech/Performance 9 06-17-2003 05:47 PM
MAFT Tuning question... WOT detonation with 13/1 A/F ratio CAracer C5 Tech 10 06-29-2002 08:25 PM
A/F Ratio fxrhm C5 Tech 17 05-15-2002 08:40 PM
A/F Ratio Guage Question Flame Red C4 Tech/Performance 13 09-20-2001 10:04 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
