Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-15-2007, 09:05 AM   #1
EuroRod
CF Senior Member
EuroRod's Avatar
Default Crankcase ventalation questions
I've recently read where some here are having issues with oil buildup inside the intake maniflod and throttle body of their FI cars, assumely from crankcase blow-by. My ProCharged C6 is plumbed per the instructions, whereas the crankcase vents are vented into the air cleaner. I have also vented each valve cover into a catch can. I have drained the catch can, but no oil has ever come out. My questions is: should I replumb the crankcase vent lines into the catch can, too? Thanks.
EuroRod is offline   Reply With Quote
Old 07-15-2007, 11:45 AM   #2
vertC6
CF Senior Member
Support Corvetteforum!
vertC6's Avatar
No because the procharger acts as the pvc valve by pulling vacuum and fumes out of the engine, just like the stock pvc does from the factory. If you run it through a vented catch can you will lose all vacuum, now you can run it through a sealed style catch can, but if you have both vc plumbed on both sides you should not have much of an issue of oil vapors making it back to the intake through the supercharger. If anything it maybe coming back up through the intake valve when it first opens. When I build my car I plan to put a one way krank vent valve on the opposite side of the procharger vent (drivers side) vc. This will allow the engine to maintain vacuum until the pressure in the crank case builds and the krank vent valve will open to releave pressure.
As far as keeping the intake and valves clean once again as I tell everyone, meth is the only way to go. It raises your octane level, drops intake temp, and when you tear the engine apart it looks brand new because the meth acts like carb cleaner. Its going to keep build up off the valves that can cause hot spots and the nasty D word. Hope that helps.
vertC6 is offline   Reply With Quote
Old 07-15-2007, 11:46 AM   #3
vertC6
CF Senior Member
vertC6's Avatar
Have you taken off your intake tube and look down inside the intake man?
Old 07-15-2007, 12:52 PM   #4
EuroRod
CF Senior Member
EuroRod's Avatar
Actually, I had the intake manifold off to replace a gasket just last week. It was clean inside, too. So, I guess I'll leave everything as is. Thanks for the help.
Reload this Page Crankcase ventalation questions
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
