The Synergy Stage II cam can add 35 to 40 rwhp on a LS7/Centrifugal SC combination. I had this cam in my NA setup, and now in my SC setup. I gained even more from the cam when I went to FI. This cam LOVES boost on the LS7. Good job Rick.
I had this question on my mind today thanks for posting, I hope to get a blower cam soon. It should also benifit the engine in terms of lowering the risks of boost and a high compression ratio right?
Don't really understand your question. You won't have to run as much boost to make big power. This synergy cam is now proven to be a very effective c6 z06 blower cam based on scientific testing. With a Procharger (or vortech for that matter) you can hit 700 rwhp with this cam and 6.0 to 6.5 psi. I think the cam is worth 40 rwhp in a FI application.
Don't really understand your question. You won't have to run as much boost to make big power. This synergy cam is now proven to be a very effective c6 z06 blower cam based on scientific testing. With a Procharger (or vortech for that matter) you can hit 700 rwhp with this cam and 5.5 to 6.0 psi. I think the cam is worth 40 rwhp in a FI application.
Hey Rudy
If a Z06 427 can hit 700rwhp on 5.5-6 psi
I wonder what I would I hit with 14psi on my 402ci .
Any specs available on this cam ? Or is it one of those secret cams ? ...
I don't know how to say it better, but my current weak link is the fuel system, I will have to stick with 600 RWHP for a while, before I go to the next stage =D
Hey Rudy
Perry
HI Perry,
This is one of those secret cams but I think Rick at Synergy is willing to talk a little. You are going to be over 1000 rwhp! Your car is nuts and there is just no comparison to be made here.
BTW, it was late last night and I mis-typed! I meant to say 6.0 to 6.5 psi to hit that number. My bad sorry.
HI Perry,
btw I just checked their website, and the pages arent up for the cams etc... How much does the cam cost? Also will they be able to provide me with the valve springs, retainers etc..?
E-mail Rick at Synergy. When I got the cam, i got the springs and all. Can't remember exact cost. It came with the best springs from comp cams.
It amazes me with all the crap that gets posted on these forums that when I go and place factual data that someone accuses me of lying. But then i also see this guy doesn't fill out any personal information so it's easy for a to post what he wants. I have a vendor backing up the data with their $250,000 Superflow dyno so you lose.
The numbers are real folks, take it to the bank.
weapons, are you on stock pistons, crank, etc..? i'm getting LG G7x4 cam/head pkg, and my next step would be FI, but i've been told that 1) i would need a smaller cam for FI, and 2) i'll have to build the motor. so... cam swap, motor build, FI = alot of money!!
btw, nice numbers!!
btw, nice numbers!!
I am all stock. The Synergy cam is very mild. Good luck!
