Take what we said about the Vortech sale last week and forget about it! We're able to put a group purchase together for the C6 Z06 and C5 Z06 Vortech superchargers. There is two price levels. One for 5-9 orders and one for 10 or more orders for each kit.
Fuel management/calibration components used are high-capacity fuel injectors, high-flow fuel pump, fuel management unit (FMU), high-flow MAF, ECM chip or module, ECM re-programmer and timing controller.(The above items vary per application.).
Oil feed and oil drain assemblies deliver the best possible lubrication and cooling for the supercharger, even under sustained boost conditions.
High-flow air intake configuration with reusable air filter and specially designed inlet ducts for superior fit.
Inlet and discharge duct connections utilize heat resistant silicon sleeves and premium quality stainless steel clamps.
OEM-type cast aluminum or billet aluminum mounting bracketry for rigidity and a factory installed appearance.
Compatible with factory OBD II engine management systems.
The Group Purchase Prices are much better than what is listed above. Please give us a call at 1-877-482-9763 or e-mail tbyrne@tbyrne.com to receive a quote. "Fine print" can be seen in the Group Purchase section of our website. Please check that out if you are unsure how GPs work.
I have the Vortech kit on my car and I couldn't be happier! If you get a chance to get in on a group purchase I would jump at it. It's amazing how fast a stock car with a bolt-on blower kit can be. I love technology these days.
Chad
With a very mild tune my car is making over 600 to the wheels. Wouldn't change a thing!!
