Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-12-2007, 12:35 AM   #1
FastBlackTA
CF Senior Member
Default APS System GT 3076r Turbos @ 12-15 PSI?
Deciding between the TTx system and the APS - my only concerns are the smallish GT 3076r turbos on the APS system with a forged bottom end. The TTx system allows larger turbos and a t3 housing.
What power levels are people making with forged stock cube motors @ 12-15 psi with the APS kit? I know a few people made big power with the old incon kits on the F bodies, but just wondering about the C6 system....
FastBlackTA is offline   Reply With Quote
Old 02-12-2007, 12:56 AM   #2
onfire
CF Senior Member
APS says the C6 uses GT3076R's and the C5 goes bigger!
onfire is offline   Reply With Quote
Old 02-12-2007, 01:10 AM   #3
0APS
CF Senior Member
Quote:
Originally Posted by onfire View Post
I don't think the C6 system uses GT3076R turbos....someone that knows will chime in, but I thought they were closer to GT2871R spec on the C6.
The C6 system does utilize GT3076r turbos.
APS is offline   Reply With Quote
Old 02-12-2007, 03:33 AM   #4
Phate
CF Senior Member
Send a message via Yahoo to Phate
Quote:
Peter, what is being used on the c5 kits?
Phate is offline   Reply With Quote
Old 02-12-2007, 03:50 AM   #5
Brabus2
CF Senior Member
Brabus2's Avatar
Hope to have an answer to your question soon, just got my car back from the body shop last Friday....and plan on taking the car to LAPD sometime this week to get the high pressure actuator replacements installed....stay tune. The Forged Motorsport actuators weren't a direct fit as I was told would be, fortunately found another source thanks to Scott...hope this one gets the job done!
__________________
2001 Brabus EV8 Kompressor
2002 S500 Sport
2007 Chyrsler T&C Limited
2006 Brabus ML500 B11
2005 C6 LAPD/APS Twin Turbo 402 cid -sold
Meth-dual nozzle, Blitz i-Color, WCCH LQ9, 230/230 115LSA, FAST 90, Wilwood BBK, LPE hood, Hotchkis bars, PFADT Coilover, LS7 Clutch, Cobalt gauges & shift light, Callaway shifter, Bullets, Z06 Time Attacks & rear fenders, 2bar SD tune.
2009 SL65 AMG (Brabus Tuned)
Brabus2 is offline   Reply With Quote
Old 02-12-2007, 10:41 AM   #6
onfire
CF Senior Member
Nice! 1000 engine hp capable.
Old 02-12-2007, 03:53 PM   #7
backchannel
CF Senior Member
Support Corvetteforum!
backchannel's Avatar
can someone show a dyno sheet that uses T2 housings and actually makes that power?
backchannel is offline   Reply With Quote
Old 02-12-2007, 06:03 PM   #8
onfire
CF Senior Member
Quote:
Go to zo6vette.com and search for "lingenfelter". 4-5 cars there built by LPE dyno'd around 850rwhp (1000eng) and have posted sheets. T25 housings and 50lb/min turbos on stock cubes.
Old 02-12-2007, 07:03 PM   #9
Phate
CF Senior Member
Quote:
Awesome Richard...can't wait to see that beast @ 14psi
Old 02-13-2007, 12:21 AM   #10
onfire
CF Senior Member
Quote:
100% Correct..........the C5 twin turbo system has larger turbine wheels and turbo housings than the C6 system to cope with larger cube engines that C5 owners are now frequently building..........the C5 twin turbo system has loads of in built flexibility to cope with 346 - 427 cube engines, all good.
Peter
They must be really big. The C5 is a T3 turbine. Since they are bigger than a GT3076R it will be a nice set-up for big cube motors.
Old 02-13-2007, 12:30 AM   #11
Phate
CF Senior Member
Peter
Weren't you trying to fit some -13 CHRAs in the Incon stuff? It required a compressor cover change, correct? It looks like there is room for larger compressor covers in the C6s.
Old 02-13-2007, 04:24 AM   #12
Brabus2
CF Senior Member
Brabus2's Avatar
I'll give these Forge actuators another try, they really are nicely built. And, Geoff at NLP has been very kind and helpful to send some pictures of his install and has offered to take them back and test fit them personally....somehow or another they should work, cuz I need my daily fix.
You must be having a BLAST with your APS hotrod!!!.....nothing compared to your 9 sec. car tho...
__________________
2002 S500 Sport
Old 02-13-2007, 10:30 AM   #13
onfire
CF Senior Member
-12 will fit. Too many issues changing the TO4B's to a TO4E though. The baby GT2871R's with TO4B and T25 took me to 9.9 at 141mph pushing 3800lbs....so they do get the job done.
I'm working on a twin T3 GT35R now
Old 02-13-2007, 11:27 AM   #14
turbo_tom
CF Senior Member
turbo_tom's Avatar
Send a message via AIM to turbo_tom Send a message via Yahoo to turbo_tom
My car with the APS kit made 600 whp/ 620 tq with a small cam at 10.5 psi.
Right now I am less concerned with making more power and more concerned with putting what I have to the ground... then I'll look for more power. I wonder what I'll make at 14 psi...?
__________________
*APS Twin-Turbo*
*CLICK HERE FOR PICS & MODS!*
turbo_tom is offline   Reply With Quote
Old 02-13-2007, 11:43 AM   #15
FastBlackTA
CF Senior Member
Thanks guys. Looks like I'll be purchasing the system today
Old 02-13-2007, 12:34 PM   #16
Phate
CF Senior Member
Still using the Incon manifolds?
Old 02-13-2007, 01:08 PM   #17
onfire
CF Senior Member
Since they neck down to a t25 opening, I'm using a custom manifold with a T3 flange.
I'm going to sell the Incon kit.
Old 02-13-2007, 11:30 PM   #18
RoadRebel
CF Senior Member
RoadRebel's Avatar
The C6 TTiX will make 800+ rwhp with the standard supplied turbos. It sports virtually the same PROVEN combination as the C5 kit.
Phil
RoadRebel is offline   Reply With Quote
Old 02-14-2007, 12:32 AM   #19
onfire
CF Senior Member
Quote:
Originally Posted by RoadRebel View Post
The C6 TTiX will make 800+ rwhp with the standard supplied turbos. It sports virtually the same PROVEN "secret turbo" combination as the C5 kit.
Phil
Just funnin ya Phil.
TTiX is a great kit.
Old 02-14-2007, 12:54 AM   #20
Zteve
CF Senior Member
Zteve's Avatar
A 3076r is by definition running a T3 frame. If it was a T25 frame the part number would be 2876R.
Zteve is offline   Reply With Quote
Reload this Page APS System GT 3076r Turbos @ 12-15 PSI?
Tags
aps, c6, corvette, gt3076r
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
