Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-06-2007, 03:43 PM   #1
0Brian@FI Performance
Former Vendor
Brian@FI Performance's Avatar
Location: FI Performance : Norwalk Connecticut www.FIPERFORMANCE.com
Send a message via AIM to Brian@FI Performance
Default ATTN: NEW APS TT Owners *** A Great Kit Can Be Made Better with THESE ***
Hi Guys,
Due to many of you PMing and calling about the BPV's since the APS kits have been released, I have decided to hook up the CF FI crew with the Hyperboost Compact Smooth DV to replace the Bosch Valves.
Why should I go with this valve you ask... Well for starters, there is nothing to tear or let go in this valve unlike the Bosch's. No rubber diaphram here... This piece also has a true piston movement which will give you increased throttle response becuase it reacts much better than the Bosch even the 710N. THIS BY NO MEANS ADDS ANY POWER, it will hold any amount of boost you can throw at it in a Vette and will yeild a nice whoooosh sound. This would also be a direct replacement on the ECS kits and A&A's kit can be modified to take this valve as well and is now a DIRECT REPLACEMENT FOR THE VALVES APS Kits USE. I personally have sold over 1000 of these valves and have never had a failure....Well, that isn't entirely true, I have had a few turn purple from the heat. Now imagine what that kind of heat does to rubber if it messes up an anodized metal.
I keep a minimum of 30 of these in stock at all times because this is standard upgrade in any Turbo Audi/VW/Porsch/ SC BMW / and any other vehicle that has a Bosch Valve. I go through about 15 week alone and the only reason manufacturers use this part is to keep kit prices down etc... This upgrade will compliment already well put together kits like the ones mentioned above, APS kits require 2, others or kits that require only 1, $155 shipped.
Anyway, feel free to email me:
CF Member APS Special $310 shipped (USUALLY $348)
or paypal to:
sales@icsperformance.com ($319 to cover Paypal fees)
If you have questions about this application in your ride or any other questions, give me a call.
Brian
Brian@FI Performance is offline   Reply With Quote
Old 02-07-2007, 01:32 AM   #2
07MontRedcp
CF Senior Member
Support Corvetteforum!
07MontRedcp's Avatar
Is this the same as the Hyperboost HX Compact Smooth Diverter Valve??
BJK
__________________
APS TT 630 rwhp/654 rwtq @ 9 psi
'07 Z51, TR6060 conversion w/Z06 ratios. DTE Stage 4 Quaife Diff w/brace (3.73). Z06 Brakes, mild turbo cam & dual springs (222/222, LSA 115, .581/.581), LS9R clutch, GT2 Coilovers, Autometer Cobalt Fuel & Boost Guages, Progressive Alky Controller, and e-Boost2 Controller. PFADT poly bushing for control arms and Sports sway bars. MGW shifter. 3" B&B Fusion. RSI Stage 1.5 fuel system.
07MontRedcp is offline   Reply With Quote
Old 02-07-2007, 02:36 AM   #3
Brabus2
CF Senior Member
Brabus2's Avatar
I've purchased the Hyperboost from Brian @ ICS Performance before, the hardware is well built, and very good customer service...he answered all my questions! Brian, I'm sure I'll be picking up a set from you for the TWINS soon, it's on my list...hang tite.
__________________
2001 Brabus EV8 Kompressor
2002 S500 Sport
2007 Chyrsler T&C Limited
2006 Brabus ML500 B11
2005 C6 LAPD/APS Twin Turbo 402 cid -sold
Meth-dual nozzle, Blitz i-Color, WCCH LQ9, 230/230 115LSA, FAST 90, Wilwood BBK, LPE hood, Hotchkis bars, PFADT Coilover, LS7 Clutch, Cobalt gauges & shift light, Callaway shifter, Bullets, Z06 Time Attacks & rear fenders, 2bar SD tune.
2009 SL65 AMG (Brabus Tuned)
Brabus2 is offline   Reply With Quote
Old 02-07-2007, 10:58 AM   #4
Former Vendor
Quote:
BJK
Yes it is.
Reload this Page ATTN: NEW APS TT Owners *** A Great Kit Can Be Made Better with THESE ***
Tags
aps, diverter, tt, valve
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
