Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-02-2007, 08:44 PM   #1
Mark Muncy
Junior Member
Default Procharger and Nitrous?
I have an 06 A6 Vert with LG long headers and Calloway DD exhaust. I am in the process of trying to install gears and 100 wet shot of nitrous. I am unsure of the reliability of a tune with these gears (I have not read or seen anyone familiar with automatics). I'm toying with the idea of dropping the gears, and adding a procharger with the nitrous to keep it cool. No other mods. Am I throwing away cash here? Any ideas or recommendations? I just want out of the hole on the street with only occasional (monthly) track appearances.
Help?
Mark Muncy is offline   Reply With Quote
Old 02-02-2007, 09:14 PM   #2
Mr.Big
CF Senior Member
Mr.Big's Avatar
Mark,
One piece of advice... Go with a "Dry" kit vs. wet... "Dry" is the only way to go up to a 200hp shot...There are several posts on here by myself and others that have some great info. either search my posts or "Myhardtop" for his posts...
__________________
Jeremy
Dallas/Valley Ranch Tx
1070+rwhp930+rwtq Boost ONLY
Dallas Performance custom F1R system, D.P. Forged 370, ALKY Control/D.P. Triple nozzle, D.P. E85 fuel system, Wilson Billet intake, D.P. Direct Drive + 10rib, WCCH 317's, D.P. Blower cam, HPTuner, D.P. '09 rearend, TR6060, Mcleod "sintered" twin, THANKS to www.dallasperformance.com
Mr.Big is offline   Reply With Quote
Old 02-03-2007, 02:24 PM   #3
Myhardtop
Supporting Vendor
Myhardtop's Avatar
Quote:
Originally Posted by Mr.Big View Post
Mark,
with Jeremy, search and ask plenty of questions. We are all family here; we can help you achieve your goals by avoiding pit falls. Listen to those who being There done That, and are running good times safely and reliably.
Myhardtop is online now   Reply With Quote
Old 02-03-2007, 11:30 PM   #4
excessive81
CF Senior Member
excessive81's Avatar
Send a message via Yahoo to excessive81
very few i would trust and they all post often....listen to what they say 4 sure!!!!!!!! and bigs is #1
excessive81 is offline   Reply With Quote
Old 02-04-2007, 12:26 PM   #5
Mr.Big
CF Senior Member
Mr.Big's Avatar
Quote:
he he he
__________________
Jeremy
Old 02-16-2007, 06:58 AM   #6
0EPP
CF Senior Member
Quote:
Help?
Are you on the stock bottom end? If you are, I wouldn't do a 100 shot of nitrous with the addition of an ATI ProCharger. A very small shot of nitrous will make a very dramatic difference with an ATI ProCharger, as the inlet air temps will drop substantially. A 100 shot would most likely take out your number seven piston. Bob
EPP is offline   Reply With Quote
Old 02-20-2007, 01:43 AM   #7
c6nut
CF Senior Member
c6nut's Avatar
I did the Procharger running 6psi, headers and a 50 dry shot on the stock bottom end all last year. No problems. A 50 shot with the S/C is very dramatic and enough. With BFG D/R's I was able to run 10.8 - 10.9 all day long. I put 1 - 5lb bottle in each of the rear compartments. Hid the lines and sprayed into the intake of the S/C in front of the motor ffrom underneath. Works like a charm andno one will suspect you have the N2O since you haave the S/C. 535 RWHP and 497 RWTQ.
take a look. click on C6 Pics
http://www.fastnfuriousrides.com/mai...%2Findex2.html
c6nut is offline   Reply With Quote
Old 02-20-2007, 07:01 AM   #8
0EPP
CF Senior Member
You have a great looking C6! Bob
Old 02-20-2007, 08:45 AM   #9
chuntington101
CF Senior Member
Mark,
whay cant you run a wet kit?? also what if you are not running a MAF????
Thanks Chris.
chuntington101 is offline   Reply With Quote
Old 02-20-2007, 02:56 PM   #10
F1_SS
CF Senior Member
Quote:
Thanks Chris.
You can run that on a dry OR a wet kit. Its not really advised unless your good at tuning the actual N2o kit. What happens is there are at times distribution problems of the n2o not going evenly into each cylinder. Once you start spraying over a certain amount its best to go with a direct port setup to ensure that every cylinder is getting what its suppose to.
If your not running maf then you need to tune for it when tuning for SD. I personally wouldnt do an SD tune. I know there are benefits of it but its too much work for me.
F1_SS is offline   Reply With Quote
Old 02-22-2007, 11:35 AM   #11
Mr.Big
CF Senior Member
Mr.Big's Avatar
Quote:
__________________
Jeremy
Reload this Page Procharger and Nitrous?
Tags
nitrous, procharger
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Nitrous with procharger? Stock internals? Anyone doing it yet? BlackMagicC5 C5 Forced Induction/Nitrous 36 11-09-2004 01:47 AM
NX With an ATI Procharger 78Vette-SA C5 Forced Induction/Nitrous 17 06-16-2004 11:09 PM
Do I need to upgrade my stock fuel pump with a procharger? BlackMagicC5 C5 Forced Induction/Nitrous 23 05-25-2004 12:39 AM
Supercharger and Nitrous Combination: Comments Needed Inelpaso C5 Forced Induction/Nitrous 11 07-14-2003 01:26 AM
Supercharging vs. Nitrous cheemsaf C5 Forced Induction/Nitrous 27 02-11-2003 10:23 AM
'01 LS1 Bird - ATI and NOS LS1 Bird C5 Forced Induction/Nitrous 9 12-09-2002 01:23 AM
Is it possible to use an ATI Procharger AND NOS? MyFirstCorvette C5 Forced Induction/Nitrous 10 09-15-2002 04:09 AM
ATI procharger owners - need your input BubbleHead C4 Forced Induction/Nitrous 38 05-16-2002 02:24 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
