Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-02-2007, 07:17 PM   #1
Bushong572
CF Senior Member
Bushong572's Avatar
Default Maggie Oil Change Info
This might be old news to some, but I couldn't find the information anywhere (including my instruction book and other maggie owners). I talked to a tech at Magnuson today about the oiling system for the maggie...this is what he said:
There is a black allen head plug at the rear between the pulleys...this is the oil fill/drain. You have to use a syringe to remove and refill. The supercharger holds 5.5 oz.....I don't know if you can remove all of it, so you better measure what you take out. I was told to buy "Supercharger Oil" from a GM Dealer (it is a synthetic). While some owners never change the oil, Magnuson recommends doing so every 6-10,000 miles. If anyone has additional info on this, pls reply.
Hope this helps.
Bushong572 is offline   Reply With Quote
Old 02-03-2007, 04:56 PM   #2
EuroRod
CF Senior Member
EuroRod's Avatar
Jezzzz, I thought that changing the oil in the ProCharger was a PITA!
EuroRod is offline   Reply With Quote
Old 02-10-2007, 04:25 PM   #3
Bushong572
CF Senior Member
Bushong572's Avatar
Just curious if anyone has changed the oil in their maggie????????
Old 02-10-2007, 04:44 PM   #4
1bdasvt
CF Senior Member
St. Jude Donor '06-'09
Support Corvetteforum!
1bdasvt's Avatar
Not yet Steve,but if You want to ask an expert on Maggies,call Brian Zucudo.
He has a shop for maggie installs only,and used to work at Magnuson!
Phone # is {818}998-1975
Take care!
1bdasvt is offline   Reply With Quote
Old 02-10-2007, 06:06 PM   #5
Bushong572
CF Senior Member
Bushong572's Avatar
Thanks, I"ll keep his # handy.
Old 02-10-2007, 07:12 PM   #6
1bdasvt
CF Senior Member
1bdasvt's Avatar
Hey Steve,You said Your making 7 lbs of boost.
Are You sure{do You have a boost gauge}
I have a 3.2 and am making only 5.5 to 6?
Old 02-11-2007, 06:03 PM   #7
Bushong572
CF Senior Member
Bushong572's Avatar
I have had a gauge on mine (I did not mount one yet...I haven't found a mount that I like) it peaked about 6.9 lbs. I wonder if your bigger headers (1 7/8") and cats are producing lower boost #s. I also wonder if there is a difference in pulleys (are they both actually 3.2"? ...mine is not a Reichard). I know of 2 maggies with the stock 3.4" that are making 5-5.5 lbs. If you're at 5.5-6 lbs now, I would definitely go with a 2.9". That should put you at 7 lbs and over 500rwhp/480-490rwtq.
Old 02-11-2007, 08:31 PM   #8
1bdasvt
CF Senior Member
1bdasvt's Avatar
Good idea!!
I think I'll do that!
Reload this Page Maggie Oil Change Info
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
