Octanium – The Most Powerful Race Fuel Concentrate Available!
And, I am proud to announce that Gulf Coast Performance is now a dealer!
It’s time for the monopoly to move over for a new and improved product! I’ve been watching and waiting for the development of this stuff for the last few months and it is now available to the public!
In 2006, a team of leading automotive tuners, drivers, and scientists came together with a single goal: create the world’s most powerful octane booster for gasoline powered, high performance vehicles. After countless hours in the lab and on the dyno, a powerful formula emerged: Octanium! No other major brand additive can match Octanium for true, measurable increases in gasoline octane. Using Octanium can raise 93-octane gasoline up to 100 octane; dramatically more than any other additive.
The proprietary blend of ingredients in Octanium is designed to eliminate detonation and pre-ignition by stabilizing and modifying the burn rate of gasoline and increasing the autoignition temperature of the air/fuel mixture. Octanium is the ideal product for high performance factory or custom engines that require the chemical properties of a race fuel to achieve maximum power and reliability. Octanium works great with high-compression normally aspirated engines and supercharged, turbocharged, and nitrous assisted engines. Whatever you drive, Octanium helps your car, truck, SUV, motorcycle, or watercraft run at peak engine performance.
• Comes in 32 oz. brushed aluminum container
• Treats up to 15 gallons of gas. Save $$$$ from race gas!
• Safe for oxygen sensors and catalytic converters
• Reduces hydrocarbon and carbon monoxide emissions
• Cleans injectors & combustion chambers of carbon deposits
• Lower cost on a per ounce basis than the competitors
• Independent lab tested, verifiable results. The only octane booster that will actually perform as advertised
For a limited time to introduce the product here are the prices! Shipping is outrageous these days so I will cover some of it.
One bottle - $21.95 shipped
Four pack - $72.95 shipped
Race Case - 12 Bottles (Buy 11, get the 12th at no charge) - $197.45 + $5 for shipping = $202.45 shipped!
In stock for immediate shipment!
Orders can be placed here or by calling 832-385-9622. Thanks! Jason
I tried some of this, it does work. I'm not a big fuel "additive" guy but after I tried it, I will definatley use it. My daily driver is a SC300 single turbo. On 93 oct I can run 18.3 psi on most days, hot weather I can run 18.0 without ping. I put a can of Octanium with a full tank of 93 and I can get away with 20.8 on the street. We hooked up a lap top and saw no timing being pulled until 21 psi. Running 2.5 more psi is about 40hp on the street. The stuff works.
What would the octane be of the blend if I were to add one 32 oz. can to 15 gallons of 91 octane premium gas?
