APS C6 intercooled twin turbo tuner system - $6995 inc door to door freight
Hi Guys, I've been working on putting together a deal for you guys for the APS C6 intercooled twin turbo tuner system. I ran a C5 twin turbo system deal last month and the interest and sales from Corvette forum members was far greater than expected so I thought that APS should also extend this one time C6 intercooled twin turbo tuner system offer to C6 Corvette forum enthusiasts.
The APS C6 intercooled twin turbo system can be browsed on the APS web site at the link below,
All you need to add is your own fuel supply system and tuning data, because this intercooled twin turbo tuner system does not include any fuel system components. A set of 60 lb Siemens injectors and a Walbro 255 LPH fuel pump will support around 540 whp. For the guys who are planning on going to higher power levels in the future, the APS C6 extreme fuel system would be an ideal choice, see link below.
This APS introductory C6 twin turbo tuner system deal includes direct door to door air freight to any destination within the 48 mainland states of America.
Now to the exciting news and I know this will rock all of you guys. The MSRP of the new APS C6 intercooled twin turbo tuner system is $7995 USD. This is a huge reduction from the original APS twin turbo system which had an MSRP of $8995. A huge saving of $1000 USD by giving you guys the option of supplying your own fuel system parts.
Now to the special one time C6 twin turbo tuner introductory offer - finally.
The MSRP of ther twin turbo tuner system is $7995 though this special deal from APS further reduces the cost by $1000 to just.. $6995..delivered door to door anywhere within the 48 mainland states of the US.
This special APS direct offer is available to the first 15 members only - so get in quick as the deal will be over when the 15 systems are sold.
Payment: Visa and Mastercard credit cards will be accepted and the entire transaction will be in US dollars (therefore the currency exchange rate between Australian and US dollars won't impact on you guys).
These APS C6 twin turbo tuner systems are currently in APS inventory so door to door delivery will be approximately 5 to 7 days from payment.
Feel free to contact me via PM or email (peter@airpowersystems.com.au).
I'm in Dallas, Texas. Anyone off-hand know roughly what it would cost to complete this kit with the necessary fuel system (miler side is fine), gauges, etc. and have it all professionally installed?
Call or email Shawn at L.A.P.D. and see if they will give you and install price. Install instructions look pretty involved and lots of hours to do. Most shops here charge $85-$125 per hour. I have priced Autometer gauges, and for boost and wide band A/F gauges plus pillar, and it was around $650. Most tunes are $500. No idea on injectors or fuel system, haven't looked into that yet, just went with vendors recommendation or his kit. I've found there's a lot more to these installs than just a kit
How much are we talking for a full kit with the high performance fuel system?
The C6 tuner twin intercooled twin turbo system is $6995 inc door to door air freight (C6 tuner twin turbo systems are in stock for immediate shipping) and I would recommend the APS extreme fuel system if you're planning on very high power into the future. See link below.
A pro shop would need approximately $2500 for the install and you should allow at least $500 for a thorough dyno tune. What are your power goals? Once I know this I can advise you on the minimum fuel system required.
Does this system bolt right up to the H-Pipe, or does the H-Pipe need modifing also. How about oil life, is it shortened any from heat?
I recommend changing the engine oil and filter every 3000 miles and in extreme conditions and you may need to fit an engine oil cooler system when on a race circuit. The APS turbo down pipes bolts straight up to the factory exhaust system, see pic below.
Peter
I would want to shoot for 550-575 RWHP. From what I can tell, I can probably do that without breaking parts everytime I romp it. If I could change clutches and nothing else I would be happy.
6) Twin 3 inch 304 stainless steel turbo down pipes.
Peter
Peter, I am curious as to why these are advertised as 3" down pipes. On my kit the opening (toward the exhaust) is only 2 1/2"...was there a change made to these?
