C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
what rpm does boost start w/procharger
Old 12-11-2006, 09:20 PM
bear1a
Support Corvetteforum!
bear1a's Avatar
Default what rpm does boost start w/procharger
what rpm does the boost start to come on...3k, 4k? 5k?..
Old 12-11-2006, 09:42 PM
tbyrne
tbyrne's Avatar
Location: Westport, MA. www.tbyrnemotorsports.com - 1-877-4-TBYRNE
St. Jude Donor '06-'07
You really start to feel it come on around 3500 RPMs.
Old 12-11-2006, 09:47 PM
bear1a
bear1a's Avatar
is that with a p1sc or d?..and what size pulley..
Old 12-11-2006, 10:14 PM
excessive81
excessive81's Avatar
that when you start to loose traction tha for sure
Old 12-11-2006, 11:33 PM
peter pan
Life Time NCM #2196
peter pan's Avatar
Received 1,096 Likes on 808 Posts
My little ole 346 starts pulling at 3k, and then is just sick after that until the shortened redline of 6200 to give me long engine life, oh I see 14lbs at 6200
Old 12-11-2006, 11:38 PM
bear1a
bear1a's Avatar
wow..what size pulley on the d1sc
mdhmi
mdhmi's Avatar
Doesn't matter necessarily where it 'starts', it matters where it starts making real power, which is high in the power band. By 4,000 - 4,500 you can definitely feel the blower. This has pros and cons. The pro is it helps traction.
PP - keep in mind your will start a little earlier as you have a smaller pulley with a forged motor combo.
Old 12-12-2006, 11:32 PM
FunCool
FunCool's Avatar
I don't know about a procharger, but my maggie makes full boost at 1500rpm and pulls like a raped ape!
Old 12-14-2006, 04:58 PM
HIGHRPM
HIGHRPM's Avatar
I run a Procharger F1R on a 429 ci motor....low end is just overwhelming.... I make over 450rwtq at 2000rpm, over 550 at 3000rpm, over 650 at 4000rpm and over 750 at 5000rpm. There is no street tire that can handle close to this much power in the first 4 gears.....but over 100mph its Don't worry about having alot of power at less than 3000rpm...... races are won in the higher rpm ranges so big power at 1500-2000rpm is not necessary. Any 500rwtq car can spin the tires up to 70-80mph..... once the tires hook.....big power at the top wins. The Auto guys have stalls of 2800, 3500 or more to get away from dealing with power profiles that start out high and trail off at the higher rpm levels. Optic ran 9.8x times with a D1....show me a Maggie that can do that.
A Procharger setup and tuned right will provide as much power as you want. I'm thinking about maybe a 454 based on the new GM iron block..6 bolt heads and an F3 blower, 24psi...... should be 1200-1400rwhp ....might even beat some of those Viper records.
Old 12-15-2006, 12:06 AM
Bushong572
Bushong572's Avatar
For a street car, I"ll take the low end power (below 3000 rpm's) everytime. That's where you spend the majority of your time.
Old 12-15-2006, 11:00 AM
Vindication
Vindication's Avatar
top end.....
Old 12-15-2006, 01:45 PM
HIGHRPM
HIGHRPM's Avatar
That may be where you spend your time, but 1500-2900 rpms is not where C5 motors really perform. Consistant running a motor in the 1500-2500rpm range will not even win a street race..... all your doing is shifting all the time wearing out the clutch and driveline...if you own a Corvette...DRIVE IT!!
Old 12-15-2006, 07:20 PM
saplumr
saplumr's Avatar
Received 1,251 Likes on 895 Posts
That car sounds really impressive. You need to get some pics in your sig.
Old 12-15-2006, 11:21 PM
Brabus2
Brabus2's Avatar
..Rich, I'll be needing a testride on that KING KONG whenever your back at LAPD.
Old 12-16-2006, 07:30 AM
Bushong572
Bushong572's Avatar
You don't have to teach me how to win a race...There is nothing in my post about racing.....In a street driven car , you spend most of your time below 3000rpm's.
Old 12-16-2006, 09:17 AM
excessive81
not mine...lol
Old 12-16-2006, 11:56 AM
Bushong572
Bushong572's Avatar
Originally Posted by black05c6z51
not mine...lol
After getting my car back, I know what you mean. I really like your LPE Twin Turbo Hood...I thought about going with that hood instead of the RK. Do you know if it would clear a maggie? I have a friend that is having the same package as mine installed...he is trying to decide on a hood.
To what rpm does boost start w/procharger
Old 12-16-2006, 05:45 PM
HIGHRPM
HIGHRPM's Avatar
If thats the case a stock motor has plenty of low end power for just cruising around town.....since you shift before 3000 rpm when you're not racing, power levels above stock should not be important.
Old 12-16-2006, 05:50 PM
HIGHRPM
HIGHRPM's Avatar
Be happy to....next time I'm in LA come by LAPD and we will go for a test ride...... ask Al about King Kong... I gave him a "white knuckle" ride.
Old 12-16-2006, 09:17 PM
peter pan
Life Time NCM #2196
peter pan's Avatar
I run a 3.85 pulley on my 6 rib setup and no issues and over 5k in a year with it
Quick Reply: what rpm does boost start w/procharger
