Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Corvettes for Sale
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
Private Classifieds, Used C6 Corvettes For Sale, and Modified or Stock Corvettes Sponsored by
Les Stanford Chevrolet
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-17-2009, 10:28 PM   #1
msko7
CF Member
Send a message via MSN to msko7
Default WTS/WTT 2000 convt triple BLK fully built 839rwhp/822rwtq on pump gas
hey guys.
Unfortunately i will have to sell my dream.
i have always wanted a 1000 hp corvette ever since i bought this vette in 2006. now that my dream almost came true, i am forced to let my babe go.
the car was dynoed at 839 rwhp/822 rwtq at 19 psi on pump gas, no meth. (that about 965 hp on the flywheel "839 * 1.15)
It has a 3 Bar tune on it which took a hell of a long time.
the car is scary fast, it breaks the tires loose at 100 mph.
here are some of the mods:
Engine:
- 413ci Iron block , 4.00" stroke, 4.030" bore (0.03" over) ( squared and rotating assembly balanced)
- Eagle forged crank
- Eagle forged H-beam rods with upgraded ARP 2000 bolts
- Wisco forged pistons with upgraded rings.
- Clevite main and rod bearings.
- Compression Ratio is: 8.8:1
- Melling High Volume oil pump
- LMP High Volume water pump
- Comp Cams Lifters, R series.
- Comp Cams Double Roller Chain
- Comp Cams push rods
- Comp Cam : 234/236 0.601" lift 113 or 114 LSA
- 241 heads with stage 3 port on them ( porting were done@ High Flow Engines in Lakeland,fl)(heads flow 320 at 0.600" lift)
- Stailess Steel Rev Intake (2.02) and Exhaust (1.60) Valves
- Patriot Dual Gold spring with Titanium Retainers and super 7 degree locks
- ARP head studs
- Cometic MLS head Gasket
- Harland Sharp Rocker Arm
- LS6 Intake manifold
- LS6 ported Throttle Body
- New O2 Sensors
- MSD wires
- B&M Engine Oil cooler
- Custom Over flow Tank
- Custom alternator bracket
Transmission:
- all internals have been hardened and Cryo Treated and rebuilt with extreme duty parts. (carbon fiber blocking rings, steel forks, new synros. etc
- Hardened and Cryo treated output shaft of transmission
- Spec Stage 3+ with Spec Steel Flywheel (ARP flywheel bolts)
- B&M short shifter
- new Slave cylinder
Differential :
- Heavy Duty Springs and Clutches
- Both sides Hardened output shafts (300M)
- DTE deff brace
- Rev Xtreme Billet Side cover ( for added strength)[b]
Turbo System:
- completely custom/ebay PTK style twin turbo kit
- Both exhaust manifolds and downpipes are ceramic coated and then wrapped with DTE exhaust wrap for additional insulation (the wrap was recently done, you wont see it in the pics)
- 2 X Master Power t-64 turbos with anti-surge inlet Housing
- 2 X Tial 38mm wastegate
- HKS SSQV blow off valve
- AEM UEGO Electronic Boost Controller
- AEM wideband
- Autometer Carbon fiber boost guage
Fuel:
- 79 lbs Racetronix high impedance injectors
- 2 X in-tank Walbro 255 pumps
- Racetronix fuel pump harness
- Mechanical on rail Fuel pressure guage.
Wheels and Tires:
- Zo6 style wheels ( black with machined lip) ( 17*9.5 , 18*10.5)
- 265-40-17 Falken in the front ( about 80-85 % left)
- 295-35-18 Goodyear in the rear ( about 50 % left)
Brakes
- crossed and drilled ACDelco performance rotors and brake pads
Exhaust
- Magnaflow exhaust system.
Cooling system
- Dewitts high capacity aluminum radiator
- custom made dual fan setup blowing 5000+ cfm ( you can't find it anywhere as i hade it custom made for me)
- 160 degree thermostat
Suspension
- C6 ZO6 shocks all around
i drive the car back and forth very often from tampa, FL to Sarasota which about 70 miles each way with the A/C on with no issues at all.
All the work was done by Tracy at Rev Xtreme performance in Bradenton, FL.
im sure that i have missed some stuff.
the car has about 2000 miles on the new build
i have a 40,000 $ in receipts. without the price of the car of course
Im looking to get about 28,000$ for it. Willing to listen to offers from you guys.
again, i would luv to keep the car but circumstances are forcing me to
selling it.
i will be willint to listen to trades, im interested in a sedan or c6 corvette 2005+
click on the link below for some pics :
http://s589.photobucket.com/albums/s...%20TT%20vette/
msko7 is offline   Reply With Quote
Old 11-17-2009, 10:55 PM   #2
hayabusajohn
CF Member
Link not working for me. Can you send pic's to 97tt@nc.rr.com ?
Also what type of 4 door trades ?
hayabusajohn is offline   Reply With Quote
Old 11-17-2009, 11:17 PM   #3
gman31
CF Senior Member
What rear gear ratio? Is the motor a 408 or 413? Your other thread says 408.
gman31 is offline   Reply With Quote
Old 11-17-2009, 11:41 PM   #4
msko7
CF Member
Quote:
yea other thread was a typo, the stock 6.0L iron block is 408 ci, i had the machine shop go 0.003 over which makes it a 413 ci.
it has the stock 3.42 rear end.
thanks
Old 11-17-2009, 11:48 PM   #5
msko7
CF Member
email sent.
i dont really have something in mind, let me know what u have and i will see if it catches my interest. i will also be interested in a luxurious coupes.
thanks
Old 11-18-2009, 03:21 AM   #6
msko7
CF Member
i fixed the linked.
it should be working now
Old 11-18-2009, 02:58 PM   #7
tomlink
CF Member
tomlink's Avatar
If you are using a 15% drivetrain loss factor from FWHP to RWHP, the correct formula to figure the HP at the flywheel would be 839 divided by .85.
This would put your FWHP at 987.1 - a little closer to your goal!
tomlink is offline   Reply With Quote
Old 11-18-2009, 06:46 PM   #8
msko7
CF Member
Thanks alot man, so only 13 more to go, which i think i can get them when weather is a little cooler. i had the dyno done when it was about 82 degrees in Florida
Old 11-19-2009, 12:57 PM   #9
tomlink
CF Member
tomlink's Avatar
With just 13 more to go, cooler weather should do the trick. Go get that 1K dyno # before you sell it - braggin' rights forever!
BTW, bump for a smoking deal. I would love a street monster like this but my C5 is my DD so the next step for me is a new GS vert in a year or two. Good Luck.
Old 11-19-2009, 01:34 PM   #10
msko7
CF Member
thanks man.
this has been my DD for about 2.5 yrs before i decided to add "some" power to it
Old 11-20-2009, 01:26 AM   #11
msko7
CF Member
ttt
Old 11-21-2009, 12:17 PM   #12
msko7
CF Member
ttt
Old 11-23-2009, 05:51 PM   #13
msko7
CF Member
ttt
ITS a great price guys, you need more than double my asking price to duplicate this car
Reload this Page WTS/WTT 2000 convt triple BLK fully built 839rwhp/822rwtq on pump gas
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
