[ZR1] plumbed in an ice tank tongiht
need to wrap up the front tomorrow.
ran a mezeire 20 gpm pump in the back driver side cubby post ice tank to feed back to the front, still using the stock pump aswell. will have results thursday hopefully
Circut is now ic bricks to magnuson heat ex to straight line tank to stock pump to Icebox to mezeire pump back to ic bricks system should hold 6-7 gallons now
after playing around with it a little last not i found the second pump to be a restriction so i took that out and refilled it and temps seem good. after 20 mins of idling with hood shut iat 2 was only at 90. need to get the bumper and stuff back on and do some data logging for the new intake and get the tune dialed in to see what it does at wot
I lied I do need the second pump. Stock pump was pressurizing the cell quicker then it was traveling back to the intake. Removed the 90s off the pump in the back and put straights on and seems fine. Surprisingly very quiet so in going to mount it next to the fuel cell for the nitrous for ease of access. Got the new intake on today aswell. Hoping to do some logging and get some info on all of it tomorrow
Be careful with dry ice. While it is extremely cold (-139 F), it quickly becomes gaseous carbon dioxide which will over pressure your closed loop cooling system resulting in a burst hose. If the dry ice is not contained, the gaseous carbon dioxide could affixiate the driver in a closed cockpit.
You are definitely on the right track with increased water flow as this is the only variable available for increased cooling against a fixed intercooler brick surface area. Removing unnecessary flow restrictions such as the 90 degree elbow fittings in the stock cooling system will also improve water flow to the intercooler.
I repositioned my stock pump to improve water flow. Also added the Straightline expansion tank. Dropped my south Texas IAT2 by 20 F. I want more cooling, since 140 F is still a little warm. I have a Katech heat exchanger. Thinking about switching it to the Magneson.
Keep it going!
Keep it going!
did some driving around tonight, cruising temps seem to vary from 4-8 degrees over ambient. cars not dialed in all the way on the intake but did two back to back second gear pulls and temps only went up 6 degrees.
I need to find a better lid for water tank tho this one is kinda finicky and wants to leak once the pumps get going. need to find some large aluminum pipe thread so I can thread on a real 4" cap
Problem is you have to relocated the body controle module that is in that cubby on the zr1s
