[ZR1] Want Better 60ft Times? How About Build Boost On the Line? Get Your 2 Step @ Hinson
Former Vendor
If you want harder and better launches with lower 60ft times then this is the product for you!
LINGENFELTER 2 STEP WITH ADJUSTABLE LAUNCH CONTROL CLICK HERE FOR PRICING AND INFO
Specifications:
• Custom molded high temperature glass filled Nylon 6 enclosure with direct access to the controller settings without requiring removal of a cover or access panel.
• 40 MHz 16-bit automotive qualified processor with eight channel Enhanced Time Module.
• Each coil drive circuit has a dedicated timer to keep the timing accurate over the full RPM range.
• Independent coil drive provides Sequential Ignition Kill when RPM limiting is active.
• Reverse battery protection.
• Both of the activation inputs have active clamps and optical isolation to suppress electrical noise from external solenoids such as transmission brakes and line locks.
• Digital filter provided in software to further isolate electrical noise on the activation inputs.
• Separate Primary and Secondary RPM x100 & RPM x1000 switches for easier setting adjustments.
• RPM limiter activation point can be adjusted from 1500 to 9,900 RPM in 100 RPM increments.
• Both Ground Activation and +12 Volt Activation inputs are provided for the Primary RPM limit activation.
• Dedicated +12 volt activation input for the Secondary RPM limiter.
• True plug-and-play coil pack connection design for ease of installation and removal.
• Fully encapsulated (potted) construction for added durability.
I know a guy who installed a combo two-step/no-lift shift device on his Whipple Mustang Cobra... it just blows away the tires at pretty much any RPM he sets the two-step to. He bought it for the NLS, but turned on the two-step since it was there. It definitely doesn't make a whole lot of sense on a car with a positive-displacement blower.
Former Vendor
Sorry guys this got posted in wrong section. At this time this model is not compatible with the ZR-1
