C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] Dyno numbers, I expected more...
Old 07-23-2014, 10:07 AM
Morphin
Morphin's Avatar
Default Dyno numbers, I expected more...
Well I took my car to the dyno and got 645whp 647wtq was really expecting more here is my mod list:
LPE 710 kit
Pulley 2.35
Lingenfelter damper 14%
LPE snout ported to 102mm
Nick Williams 102mm
LS3 ported and polished heads - Intake 387cfm Exhaust 236cfm
Meth injection
Short throw MGW
Cam Comp cams - 227/243 @.050 .614/.624 109 CL
SPEC double disc clutch
Headers 2"
No cats
AEM wideband
NT05R 345/30/19
I really was expecting at least 700whp.
Old 07-23-2014, 10:19 AM
Ballbearingturbo
Ballbearingturbo's Avatar
With those mods you should be around 750 rwhp. What's your psi?
Old 07-23-2014, 12:04 PM
Dave Schotz
Dave Schotz's Avatar
Something is off.
Old 07-23-2014, 12:19 PM
Morphin
Morphin's Avatar
I am at 17psi how can I upload the log of that run? When I try to attach it it says invalid file.
Old 07-23-2014, 01:25 PM
Mechanical
Mechanical's Avatar
What kind of dyno was it?
Old 07-23-2014, 01:54 PM
Morphin
Morphin's Avatar
It is a dynojet.
Old 07-23-2014, 02:22 PM
ss2z06
ss2z06's Avatar
Is the meth working right? How much timing? What fuel are you running?
Old 07-23-2014, 02:26 PM
timmyZ06
timmyZ06's Avatar
something is deff wrong you should be well over 700whp. 17PSI seems low for that setup, unless cam make and headers specs justify that boost drops.
Old 07-23-2014, 02:58 PM
Morphin
Morphin's Avatar
Meth is working fine, I am on 92oct.
Altitude is 7000ft over here thats why I on ly get 17psi.
Old 07-23-2014, 03:30 PM
Morphin
Morphin's Avatar
I notice that IAT2 numbers where on the sky, here is a comparison of the IAT2 on the dyno and on the street, same file same everything. How much power could I be loosing because of this?
Old 07-23-2014, 04:18 PM
David@MMS
Supporting Vendor
David@MMS's Avatar
it pulls MAJOR timing when the IAT2 gets that high.
I'd have to look but I think it pulls 8-9* when the IAT2 goes over 130*.
Old 07-23-2014, 05:01 PM
Morphin
Morphin's Avatar
This is the knock retard table on the same run.
Old 07-23-2014, 05:07 PM
ZBADESTZ@Straightline
ZBADESTZ@Straightline's Avatar
Your car pulled 4.5* @ 6,000 rpm...
Check your intercooler fluid.....It shouldn't be 70* above ambient...
Your coolant was at 207*
Do the fan setup like I told you...
you should be in the mid 700's
Old 07-23-2014, 05:08 PM
That could be false knock when you initially started the run...
Old 07-23-2014, 08:25 PM
Morphin did that info I gave you on the throttle body help ya?
Also check for belt slip....Your boost is dropping 2 lbs
I would think that pulley setup would push more...I have 14% lower with 2.6 upper at 16lbs
Old 07-23-2014, 09:30 PM
ace32x
ace32x's Avatar
your belt is slipping, still not sure why power is so low on your set up. i made 752 whp in 110 degree ambient with similar set up but ported ls9 ehads. back at home with better weather with the same pulley combo im seeing 21.8 lbs (lower to sea level in washington) car got tuned in phoenix
Old 07-23-2014, 10:10 PM
Morphin
Morphin's Avatar
The shop where I dynoed the car didnt had a BIG fan they only had 2 small ones thats why temperature got that high. I usually dont have issues with IAT2 numbers.
To Dyno numbers, I expected more...
Old 07-23-2014, 10:14 PM
Morphin
Morphin's Avatar
This are how my IAT2 numbers usually are:
I am going to need to take the car to another shop where they have a big fan for dyno runs.
Morphin
Morphin's Avatar
Yeah it was slipping just fixed it today, belt was installed wrong.
Old 07-23-2014, 10:32 PM
Ballbearingturbo
This are how my IAT2 numbers usually are: I am going to need to take the car to another shop where they have a big fan for dyno runs.
Maybe I overlooked, what heat exchanger do you have?
Quick Reply: [ZR1] Dyno numbers, I expected more...
