C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] Dyno numbers, I expected more...
Old 07-23-2014, 10:48 PM
ace32x
ace32x's Avatar
Originally Posted by Morphin
Yeah it was slipping just fixed it today, belt was installed wrong.
what belt are you running? i found the 76mm idler and a stock ilder and stock length belt give tightest fit/wrap. got a micro v belt and it seems to be pretty grippy
Old 07-23-2014, 11:06 PM
Morphin
Morphin's Avatar
Originally Posted by Ballbearingturbo
Maybe I overlooked, what heat exchanger do you have?
OEM heat exchanger with water and water wetter.
Old 07-23-2014, 11:07 PM
Morphin
Morphin's Avatar
I am on the OEM belt.
Old 07-23-2014, 11:26 PM
ace32x
ace32x's Avatar
hmm, how old is the belt? what ilder set up?
Old 07-23-2014, 11:55 PM
Morphin
Morphin's Avatar
It has 8000miles and have a 100mm idler the belt is not slipping anymore it was in the wrong position.
Old 07-24-2014, 12:08 AM
ace32x
ace32x's Avatar
o good to hear, its stretched quite a bit then, i could barely get my stock one on with a 76!
Old 07-24-2014, 12:18 AM
Morphin
Morphin's Avatar
Are you also using the 2.35 pulley?
Old 07-24-2014, 12:20 AM
Morphin
Morphin's Avatar
So the conclusion is that high IAT2 ****ed my dyno numbers? It is safe to say that with the IAT2 numbers where I usually have them (below 130) car should be making 700whp?
Old 07-24-2014, 12:38 AM
ace32x
ace32x's Avatar
14% lower 2.35 upper 1 stock ilder 1 76mm
Old 07-24-2014, 02:26 PM
Dave Schotz
Dave Schotz's Avatar
14 lower and 2.35 upper... definitely is calling for a H/E... stock one is BARELY good enough for just a 2.6 upper. (IMO).
Dave
Old 07-24-2014, 03:25 PM
ace32x
ace32x's Avatar
looks like kp just came out with cnc front peices for the bricks on the blower to run individual coolers to each one. if you were feeling adventerous you could pull your fogs and run coolers on either side. id have done that instead of my set up now if i hadnt just finished it lol
Quick Reply: [ZR1] Dyno numbers, I expected more...
