[ZR1] My next round of mods
Which is also the same one in the veangence kit.
It fills up our whole shroud. If you go look in my build thread you can see it mounted.
My car is getting finished up and got on the dyno yesterday.
Myself along with KP Racings help completely redesigned my HX cooling system. As mentioned earlier in the thread the new set up includes-
Magnuson HX
Lingenfelter pump
KP Racing water/ice box
Custom water lines
Custom blower adaptor
The new system holds around 7 gallons of water and the box could easily hold around 20-25lbs of ice for race day.
Its important to note that yes my car has a nitrous kit but the following numbers were done motor/blower only.
So here are the dyno numbers from yesterday. The shop temp was around 85 degrees. All pulls were made on plain water(no ice) and the IAT2's never went above 105 degrees after multiple back to back pulls.
Car made-
1030rwhp on C85
1017rwhp on E85
Heres a quick video showing how much water the system flows-
Pictures of the new system installed-
Pump location and tank drain at rear of car-
Picture of dyno screen, I will post the video as soon at the shop posts it to youtube as its on FB now.
Magnuson HX
Lingenfelter pump
Custom water lines
Car made-
1030rwhp on C85
1017rwhp on E85
Awesome job and seems to be working. Do you find that big HX in front of the rad has any effect on engine temps ? I am thinking of trying one but worried about it blocking too much airflow to the rad.
In response to the "seems to be working" comment. It 100% works. My IAT's before would have reached 170-180 degrees and never cooled off till you car was allowed to set.
realcanuk- I did the magnusson unit and it has no effect on the car street driving, and no noticeable effect on the track. I also upgrade to the LG rad recently...
I actually have the "problem" of the car cooling down while sitting at idle in the staging lanes of the track or autox.... I drop oil temps into the mid 190's if just idling... I've turned AC on in staging to bring temps up...
When I beat the snot out of the car at a track like sebring, my max oil temps hit 273-275 at peak unless I leave the ac on by mistake (oops), and thats after multiple abusive laps...
My cars pulleys are 2.35 upper and Innovators West lower.
Compression ratio is actually probably been lessened as my Black Labels have larger combustion chambers than my stock heads.
#34
#35
Nice work on the cooling mods.
#36
Other than the cooling mods was anything else done to add power? Going from 934 to 1017 on the same fuel (was the 934 number on E85?) by just cooling things off seems too good to me true.
#37
I'm also highly interested in this as I have the same setup except for his impressive heads (which I want), different cam and meth. My IAT2s are 20 degrees above ambient or lower MOST of the time.
Could you tell us how much timing is in the tune?
I'm currently at 870/911 on e90 at 18psi. I know mustang dynos can be tweaked for whatever you wish but my ultimate goal is to have a car running as strong as his.
#39
From what I know the 934 was done on e85r per previous posts.
I can promise you the there is no dyno trickery going here, I eventually will take it to a local dynojet dyno and really blow peoples minds.
#40
Take it to LMR for that
