[ZR1] Electric water pump?
05-19-2014, 11:57 AM
Looking to upgraded my water pump from the belt driven to an electric one. Meziere offers one for the ls3, I called them and they said it wouldn't work on my zr1 but there was no confidence on exactly why.
Any ideas???
05-19-2014, 12:06 PM
Could it be a belt issue. As in they don't know what belt to replace yours due to the blower.
05-19-2014, 12:07 PM
You do Yuri msg also check and see if the ls3 and ls9 use the same stock pump
05-19-2014, 12:17 PM
Ls9
ls3
05-19-2014, 12:37 PM
This is the Meziere pump, they mentioned the ls9 throttle body is in the way.
05-20-2014, 04:50 PM
Curious why you are wanting to run the electric water pump, for cooling or power gains?
05-20-2014, 05:29 PM
Quote:
Originally Posted by
PRE-Z06
Cooling.
05-20-2014, 07:57 PM
i doubt there is much cooling to be had there, maybe im wrong though.
It would benefit not over spinning the pump though if you road course it since your running an upper and lower.
05-20-2014, 08:26 PM
ace32x
i doubt there is much cooling to be had there, maybe im wrong though. It would benefit not over spinning the pump though if you road course it since your running an upper and lower.
I've heard 10-20 degrees on coolant. I'd be happy with 10.
05-20-2014, 08:30 PM
Location: Daytona Beach/ Atlanta---- Good Ol' Florida Boy/ Georgia
Throttle body doesn't look like it would be in the way.If anything it looks like the alternator bracket would be the concern. My concern would be the pulley on the pump is only designed for an 8 rib belt. Maybe you could transfer over the stock pulley.
05-20-2014, 08:38 PM
Cruise-In VI Veteran
St. Jude Donor '12
05-20-2014, 08:42 PM
Ballbearingturbo
rad temps getting to hot?
05-20-2014, 08:55 PM
Yeah I'm with c5kid on there are other ways
05-20-2014, 09:06 PM
ace32x
I was seeing 198-210 in traffic and 195-200 cruising under 40 mph.
I have stock radiator, pump and fan with 160 tstat.
05-20-2014, 09:18 PM
Ballbearingturbo
nothing wrong with those, your fine until you get up in the 260 + range
05-20-2014, 09:27 PM
ace32x
But I want better. Even if I'm fine. Suggestions?
05-20-2014, 09:33 PM
Wrap your headers and exhaust, Dewitt's radiator, upgraded fans and hard wire them. Also vented hood.
05-20-2014, 09:36 PM
whatcop?
Part number for radiator and fans?
05-20-2014, 09:38 PM
The only cooling mods I have is a Dewitt's radiator, thermostat, and E85. I haven't had any heat issues yet.
05-20-2014, 09:44 PM
Dewitt's radiator part number? Was in direct bolt in?
Why Dewitt's over LG?
