[ZR1] LPE 710 package VS. Porting stock snout and pulley upgrade?
1 Post
Cruise-In III Veteran
St. Jude Contributor
So i'm on the fence here, I have an extra stock snout and was really dead set on having that and the throttle body ported and adding a 10-bolt hub with a 2.60 pulley and getting a tune but the bug really hit and now I'm thinking of ditching the idea and going the LPE 710 route and an upgraded heat exchanger. Any advise would be welcome.
Jamie
Jamie
Since you have an extra TB and snout I have to ask. Why not just port them and add a pulley? Sure, you won't gain quite as much as the LPE setup, but you will be saving over 2k by just porting what you have. You can put that money towards headers and a tune for everything and probably net more power than the LPE kit alone.
1 Post
Your basically asking what I'm asking, this was my original plan but I can't find anything that really shows what the gains are on this vs the LPE setup.
As a side note I'm not having LPE install the kit if I go that route, I'll be doing it myself and then taking it for tune afterwards, same scenario on the other setup if I were to go that way.
Plus the added expense of having the TB, snout ported and the hub and pulley installed vs just buying the LPE kit ready to install.
