[ZR1] My drag strip experience this past Saturday
Kyle where is mir located?
Nelson007
I remember now , its at Budds Creek i use to race dirt bike there.
Nelson007
I used to run my 95 at Mason Dixon years ago too. I would never even attempt to run a ZR1 on stock tires at that track, Im very hesitant to take mine there on the DR's. It is only an hour and 20 min away from me, and mir is over double the drive time. But well worth it!
The first 6 runs i set the air for 25. Than checked the air afterwards and it went up to 27. I than adjusted the air to 22. I don't think it made much of a difference. I am going to order a set of wheels from ccw and get the tires Whatcop recommended. Hopefully that should solve my problem. What surprised me the most was the launch control did not work well on the strip but works great on the regular state roads Thanks,
Nelson007
Nelson007
what rpm range do you use for a launch without drag radial?
You can go to the dealer to get rotor protectors, but a much cheaper substitute is foam pipe insulator. When I bought my 2010 ZR1 used, the orginal rotor protectors were not with the car I had to get something before putting on the other wheels with my drag radials, so a quick stop at Home Depot took care of it.
Even with protection, you should still be careful (like what my dad said to me in high school. )
When you unseat the wheel off the axle pad, don't let it fall down on the rotor. Use your arm strength to try and hold it up and pull it straight towards you without crashing down on the rotor. If you think the wheels are too heavy, put a block of wood under the tire so the wheel maintains the same height as you pull it off.
This shot is just a quickie the first time I used the pipe insulation. I've since refined the technique so it doesn't look as crude, but doesn't really matter. Effectiveness is what counts.
Hello Al,
I floor the gas pedal and it goes to approximately, 4500 and settles around 3700.
That when i pop the clutch. It works great on a concrete road with a little wheel hop, but at the track it just spins.
Nelson007
Nelson007
Thanks TWS that is really helpful using the pipe insulation. I have a bad shoulder so that board technique is fantastic it saves me from calling my son all the time.
Nelson097
Nelson097
