[ZR1] Billy Boat Performance Exhaust C6/ZO6/ZR1/GS 05-13 Headers w/high flow cats and 3"
Former Vendor
St. Jude Donor '13
Billy Boat Performance Exhaust C6/ZO6/ZR1/GS 05-13 1 7/8" & 1 3/4" Headers w/high flow cats and 3" x-pipe
Billy Boat Performance Exhaust has once again taken the PolePosition in the market by developing long tube header systems specifically forthe C6 Corvette. The header design incorporates the correct firing sequencewhich pairs exhaust ports together for more efficient exhaust scavenging. Dynotesting, utilizing technology previously found in racing applications has shownan increase of horsepower and torque throughout the entire RPM range. This is atrue bolt-on header, complete with hardware and gaskets, dedicated to the C6Corvette. The new 1.875" tube flows seamlessly to a 3", 4-into-1collector. Billy Boat Performance Exhaust also makes a variety of x-pipes forthe c6 Corvette. The x-pipe section evens the exhaust pulses with a sycronizedcrossover in the center section, resulting in a deeper, smoother tone.Utilizingtechnology previously found in racing applications dyno testing has shown anincrease
of horsepower and torque throughout the entire RPM range. When used inconjunction with B&B’s x-pipe and exhaust increases of 46hp and 44ft/lbs oftorque were seen. This true bolt-on header comes complete with necessaryhardware to make installation a breeze. As with all B&B products theseheaders are backed with their limited LIFETIME warranty. Any engine builder ortuner will tell you that balancing exhaust pulses form an engine is a sure fireway to increase power and while OE’s try to accomplish this they generally usean H-pipe or stamped part which tend to be not real efficient. Aware of thisBilly Boat Performance Exhaust developed a full 3” CNC mandrel bent X-pipe forthe enthusiast looking to turn their C6 Corvette into a full 3” race set up.Precision hand fabricated from the finest T304 stainless steel materials thisX-pipe provides a smoother transition for the exhaust pulses to blend togetherfor better balancing a scavenging. Designed on their in house chassis dyno thisbolt on part will not only increase horsepower and torque it also provides fora cleaner exhaust note. B&B also incorporated a pair of 200 cell high flowmetal catalysts into this x-pipe to be used in conjunction with their long tubeheaders that eliminate the OE cats. As with all B&B products this part isbacked by a limited LIFETIME warranty. *THIS PART IS DESIGNED FOR OFF-HIGHWAYRACING ONLY AND SHOULD NOT BE USED ON PUBLIC ROADS* Billy Boat PerformanceExhaust has had a deep commitment to build quality products. With over 3generation of fabrication and racing experience going into the development ofevery part B&B makes along with use only the finest T304 stainless steelmaterials it is easy to see why B&B has been an industry leader for over 20years. B&B designs every system for increased performance, a distinctivetone that they have spent years perfecting and an appearance that will set yourvehicle apart.
Includes O2 extension, gaskets, hardware
$1985.95
Delivered lower US
Delivered lower US
Former Vendor
St. Jude Donor '13
http://www.xplosiveperformance.com/B...e-_p_3662.html
http://www.xplosiveperformance.com/B...pe_p_3661.html
http://www.xplosiveperformance.com/B...e-_p_3663.html
http://www.xplosiveperformance.com/B...e-_p_3664.html
$1985.95
Delivered lower US
Earn 196 Reward Points order online
$1985.95
Delivered lower US
Former Vendor
St. Jude Donor '13
$1985.95
Delivered lower US
$1985.95
Delivered lower US
Former Vendor
St. Jude Donor '13
$1985.95
Delivered lower US
$1985.95
Delivered lower US
Former Vendor
St. Jude Donor '13
$1985.95
Delivered lower US
$1985.95
Delivered lower US
Former Vendor
St. Jude Donor '13
$1985.95
Delivered lower US
$1985.95
Delivered lower US
Former Vendor
St. Jude Donor '13
$1985.95
Delivered lower US
$1985.95
Delivered lower US
Former Vendor
St. Jude Donor '13
Click the image to open in full size.
$1985.95
Delivered lower US
$1985.95
Delivered lower US
Former Vendor
St. Jude Donor '13
$1985.95
Delivered lower US
$1985.95
Delivered lower US
Former Vendor
St. Jude Donor '13
$1985.95
Delivered lower US
$1985.95
Delivered lower US
Former Vendor
St. Jude Donor '13
$1985.95
Delivered lower US
ORDER NOW TILL JULY 4TH
GET A SET OF 8.5mm MSD WIRES & DEI BLACK PROTECT-A-BOOTS
$1985.95
Delivered lower US
Former Vendor
St. Jude Donor '13
$1985.95
Delivered lower US
$1985.95
Delivered lower US
Former Vendor
St. Jude Donor '13
$1985.95
Delivered lower US
$1985.95
Delivered lower US
Former Vendor
St. Jude Donor '13
$1985.95
Delivered lower US
$1985.95
Delivered lower US
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
