[ZR1] Getting ready to hit the dyno!!!
#43
thats impressive.No other zr1 with the same mods has ever been dynoed at more than 625 rwhp.A stock one makes around 520 rwhp so for a no headwork and no cam set up to make 711 rwhp is almost unreal.Thats a 190 h.p gain from bolt ons and a tune.For the record i would like to add that using 94 octane gaz has zero benefit over 93 or even 91 octane .112 and 116 octane then you re talking.
#44
Manny (and we all know his dyno is 100% accurate) just did a similar car and made over 650rwhp on 91 octane. I am sure with 94 he would get an extra 25hp out of it. A 5% variances in dynos is no big deal and not important to anyone but you.
Maybe instead of ragging on this "aggressive dyno" thing, thowing out a "nice numbers Tommy" would be nice.
Oh, and have a great day !!
#46
Wow. Almost identical numbers to my 2010 ZR1, which put down 706/703, also on a Dynapack Dyno.
My stock 2011 ZR1 put down 540 on the same dyno with old fuel that caused some KR. Filled up with fresh 93 and data logged and the KR is all but gone. Don't know how much more it would have made, but more for sure.
#47
706 with similar set-up than Timmy?
#48
Phil. You are half right. 94 vs 91 octane will make no difference if the car is not tuned for it, but with 94 you can definitely be more aggressive with timing and make more power. Tune your car aggressively on 94, and then go beat on it with 91 in it and tell me how that works out for you.
#49
You once again miss the point and have no clue what you are talking about.
I don't care if Tommys car makes 200 rwhp, or 2000. The guy makes a thread excited about his mods and getting tuned, and instead of saying something nice, you bring up the same crap.
You worship a shop that you have never even visited or met the owner, and crap on one constantly that went out of their way to help you. What you have against Federal is beyond me, but you should just keep it to yourself instead of ******** on everyones threads.
No one is taking anyone for a ride. Only you are more concerned with the dyno number than the actual work or how the car runs. Seriously Phil, wtf is your problem. You have posted this same crap countless times, in countless threads of other people. I will not respond next time you do it. Its obviously a total waste of time. Continue worshipping shops you don't use, and cars you don't own. Its obviously all you have.
Oh, and to respond to your comparisons of cars, why is it when my car dynode 620 rwhp on that inflated dyno, I ran 10.40 at 135mph. What you are saying is that my car actually was around 550 rwhp. I am ok with that.
Then why does a car dynoing at 750 rwhp on a "real" dyno at Mannys, only manage to run 10.20 at 140 with a full drag pack and skinnies. I would think 200 hp more should net more gain than that.
#50
Because that car that went to Manny s had damaged valve train by the time it went to the track.It was down at least 100 h.p had no oil in it as he found out right after the run,in fact 5 dual valve springs that had one craked spring .I am not worshiping any given car or shop i am simply calling out bogus dyno numbers.As for your car 10.40s was a long time ago with the stock ls2 and a set of wchh heads.It hasnt seen anywhere near that time since being upgraded to a 402 stroker.The dyno numbers have gone up but the mph has dropped substantially.
#51
#56
I drove the car for a while today and HOLLSH!T !!!!! Its just retarded! Love it it is crazy how stock and quiet it feels. ...till you nailed it! !
#60
Even after reading the thread, I'm not 100% sure of Timmy's mod list. Mine is Torq Speed Lab's ZR800 build package. Basically pulleys, ported Lingenfelter snout, Lingenfelter air intake, NW102 TB, cam, springs, pushrods, Kooks LT's and Kooks X pipe, ID 850's, larger heat exchanger. Heads are untouched.
I just recently converted to flex fuel and expect some good gains once we get it on the dyno and tune the PE alcohol table and spark adder for alcohol table. Right now I just have flex fuel enable and variable stoich AFR in the ECM so that I can drive it on E85, but gains have not been realized yet.
