C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] Date set, deposit sent!!!
Old 04-10-2014, 04:35 PM
  #41
PHPD7102
PHPD7102's Avatar
St. Jude Donor '14-'15-'16
Ok its on the dyno today, first numbers are currently:
649 RWHP and 655 RWTQ
Any final number guesses?
Old 04-10-2014, 10:09 PM
  #42
PHPD7102
PHPD7102's Avatar
Wow no guesses, not even one person taking a shot at it?
Old 04-10-2014, 10:21 PM
  #43
K B Vettin
K B Vettin's Avatar
670hp and 680tq
Old 04-11-2014, 11:50 AM
  #44
PHPD7102
PHPD7102's Avatar
Originally Posted by K B Vettin
670hp and 680tq
About what I was guessing, I should no by end of business today so just waiting on the email from LPE.
Old 04-11-2014, 03:00 PM
  #45
PHPD7102
PHPD7102's Avatar
Numbers are in:
673.26 rwhp and 674.87 rwtq
RPM version
Old 04-11-2014, 08:42 PM
  #46
PHPD7102
PHPD7102's Avatar
Any of you build guru's have any opinions on the dyno sheet results? I was hoping for 680 and it hit pretty close I guess.
Old 04-11-2014, 11:45 PM
  #47
K B Vettin
K B Vettin's Avatar
Awesome numbers. When do you get it back? Did you upgrade the heat exchanger and do a catch can set up?
Old 04-12-2014, 12:26 AM
  #48
WeaponsGradeTorque
WeaponsGradeTorque's Avatar
Outstanding results.
Does your car have headers?
Was this with 2.38 upper pulley? stock lower pulley?
Numbers are in:
RPM version
Old 04-12-2014, 07:24 AM
  #49
PHPD7102
PHPD7102's Avatar
It comes home this week and yes I went with the Lingenfelter heat exchanger upgrade.
Yes it has ARH headers with a Corsa cat back system, yes the 2.38 upper and stock lower pulley.
Old 04-12-2014, 09:37 AM
  #50
WeaponsGradeTorque
At a half mile event this car is going to kick some major butt. You are at 600 rwhp by 4700 rpm.
Old 04-12-2014, 10:26 AM
  #51
K B Vettin
K B Vettin's Avatar
PHPD7102--If you don't have one I would definitely get a catch can set up, there are plenty of threads that show them, I have the elite engineering dual set it and I can tell you these cars modded needed them. The PCV system that comes stock on these cars is perfect for stock boost but now with the stock crank and 2.3 upper you now running 16psi which is a 52% increase over stock and the way it stays now you will oil soak your blower with out them. These are really easy to install on your own and I'm more than happy to help. that's my .02, other than that great build!
Old 04-12-2014, 10:32 AM
  #52
PHPD7102
PHPD7102's Avatar
Thats my hope, I'm signed up for the June 22nd event at the Monee Airport.
Thanks I was already reading up on that in the threads you guys have been posting on and my elite engineering dual can set up is in my garage awaiting the cars return.
Old 04-12-2014, 11:54 AM
  #53
K B Vettin
K B Vettin's Avatar
Awesome! Be sure to post some pics of the beast with your new wheels and some cold start idle videos.
Old 04-12-2014, 05:04 PM
  #54
WeaponsGradeTorque
Good luck at the Event!
What tire combo are you going to run? I may come out and watch.
BTW - I've had LPE performance parts on my Vettes in the past. They have NEVER let me down and delivered beyond the promised performance with no BS and good engineering to back it up. I love your setup and results with such a mild camshaft.
Old 04-12-2014, 09:03 PM
  #55
K B Vettin
K B Vettin's Avatar
i agree LPE is awesome The gt9 cam has stock like manors but it has 656 exhaust lift which is a lot of lift when compared to most ls9 after market cams. here is a video of my first zr1 with the gt9 cam, it has a small lope to it, these are the specs
215/247 .629/.656 on a 121 CL
Old 04-12-2014, 11:08 PM
  #56
WeaponsGradeTorque
nice videos. that is a bunch of lift. not sure what to think about that. I know Katech also uses that cam and they did not seem to concerned by that lift amount. But, I hear what you are saying. At any rate, the cam still behaves like stock and that is good to know.
Livernois also has high lift cams in their ZR1 packages (Livernois Motorsports 2C Hi-Lift Camshaft
Intake Duration: 224 @ .050
Exhaust Duration: 236 @ .050
Intake Lift: .646
Exhaust Lift: .646
LSA: 117
Old 04-13-2014, 10:34 PM
  #57
PHPD7102
PHPD7102's Avatar
I'll be running stock wheel sizes and more likely than not Nitto Invo's. Its not optimal for a launch obviously but I'll make do.
After what I just spent on the car I'd rather not have to battle it out with the wife about why I'm buying another 3.5k worth of wheels and tires for a drag package.
To Date set, deposit sent!!!
Old 04-16-2014, 09:31 PM
  #58
PHPD7102
PHPD7102's Avatar
Default Home!!!!!!
Well its back in the garage......come on warm weather!!!
Old 04-16-2014, 11:25 PM
  #59
K B Vettin
K B Vettin's Avatar
those wheels are F-ing sick! will take a video of the car idling and post it?
Old 04-17-2014, 05:44 AM
  #60
narush
narush's Avatar
I agree those rims are SWEET
Quick Reply: [ZR1] Date set, deposit sent!!!
