C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Keep loud pipe closed?
Old 05-04-2013, 11:48 PM
c6hp4fun
Support Corvetteforum!
c6hp4fun's Avatar
Default Keep loud pipe closed?
Heading to Laguna Seca soon. I've heard Z06's are marginal for passing the 92 dB restriction there. I know getting the valve to stay open is easy. Is there a way to override the actuator system to keep the butterfly always closed?
Thanks.
Old 05-05-2013, 12:38 AM
Charley Hoyt
Charley Hoyt's Avatar
Yes there is a way. Do a search using Laguna Seca and exhaust. The exhaust controller can be unplugged and a jumper wire used. I used this method at Laguna Seca and it worked well.
Old 05-05-2013, 12:44 AM
Charley Hoyt
http://forums.corvetteforum.com/c6-z...5-seconds.html
Here is the post that shows how to do it
Old 05-05-2013, 09:27 PM
c6hp4fun
c6hp4fun's Avatar
Thanks much, Charley! I will do that fix.
Old 05-05-2013, 11:52 PM
AzDave47
AzDave47's Avatar
Received 4,506 Likes on 2,597 Posts
An alternative is to safety wire the flaps closed by looping the wire around the actuator arm, starting the car so the flappers close and then tieing it off in the closed position. I did this, but tried to use tie-wraps. Not surprisingly the tie-wraps melted after 2-4 sessions.
To Keep loud pipe closed?
Quick Reply: [Z06] Keep loud pipe closed?
