C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Cam opinions - LXL lobes
Old 12-14-2012, 09:56 AM
COVERT GUY
COVERT GUY's Avatar
Default Cam opinions - LXL lobes
Cam gurus I just wanted to get your thoughts on a prospective cam for my Z06.
It is a Comp Cams LXL lobed grind 230°/242° .645"/651" on a 114 lsa. I am looking for a cam that has good driveability, mild lope, excellent midrange and makes 530+ rwhp on Dyno Jet or better yet has enough power to let me trap above 130 mph. Thanks for your opinions.
Old 12-14-2012, 10:36 AM
MTIRC6Z
MTIRC6Z's Avatar
Seems to me the LXL lobe is really better for positive displacement blower engines, that doesn't mean it wouldn't work in a NA car, just that you could do better. Personally I think the best lobe for NA is the LSG but you can only get that from Geoff at EPS or a shop that is smart enough to have Geoff design their cams for them, like Lethal Racing http://www.lethalracing.com/
The advantage to going to someone like Shawn David at Lethal for the cam instead of directly to Geoff, is Shawn will nail down the perfect tune for you.
Cheers, Paul.
Old 12-14-2012, 10:47 AM
2000FRCZ19
2000FRCZ19's Avatar
St. Jude Donor '12
I am running a 231 247 lsr cam with a 115 lsa. it put down these numbers on a 90* day after driving it an hour to the dyno. drives very good and has a nice lope.
Old 12-14-2012, 10:53 AM
06LMBZ
06LMBZ's Avatar
LG G7X3 cam or the RR Lethal cam would be perfect for you, atleast in my opinion.
Old 12-14-2012, 11:11 AM
VetteVinnie
Support Corvetteforum!
VetteVinnie's Avatar
Received 1,640 Likes on 1,049 Posts
This is what is in my car (LXL lobed design). Call Shawn at Lethal Racing and ask for the Phantom cam. There's a link in my signature where you can see the dyno graph and the numbers. Car drives like stock with a nice lope at idle. I love it.
Old 12-14-2012, 11:14 AM
2000FRCZ19
2000FRCZ19's Avatar
St. Jude Donor '12
Cheers, Paul.
I have heard a lot of good things about the eps lsg lobes. from my understanding its an endurance lobe that is aggressive but is easy on valvetrain.
Old 12-14-2012, 11:30 AM
MTIRC6Z
MTIRC6Z's Avatar
Exactly, wont beat the crap out of your valve train like the LSK, it even sounds way nicer/quieter. I've also heard that on a good day the G lobe will improve your sex life
Cheers, Paul.
Old 12-14-2012, 03:15 PM
COVERT GUY
COVERT GUY's Avatar
Nice graph. I would be pleased with numbers and a graph similar to yours.
Old 12-14-2012, 04:02 PM
2000FRCZ19
2000FRCZ19's Avatar
St. Jude Donor '12
it drives quite nice with a 9 overlap. it has killer low and midrange tq and it keeps pulling to redline. I would go with this cam again if I were building another set up.
Old 12-15-2012, 11:28 AM
Michael_D
Michael_D's Avatar
Cheers, Paul.
Keep in mind that Geoff is a hell of a tuner as well.
Geoff spec'd one of his grinds for me after I sent him the post port work numbers. He's a great guy to deal with, but keep in mind that he is pretty damn busy and doesn't have time to BS about some of the sillyness you see on these forums.. So if you do call, make sure you know what you want, what your goals and expectations are, and most importantly, be honest with yourself.
Old 12-15-2012, 12:22 PM
vertC6
vertC6's Avatar
I too have spoken with Geoff on several occasions an he recommended the LXL lobes, they are designed for the 1.8 rocker with a soft seat landing.
To the OP I would even consider 226/242 if you are looking for drive ability and better low end torque. That is the spec I am leaning towards, after speaking with Brian Tooley he turned me on to the xtreme rpm LS1 lobe to use on the exhaust, it has less lift with a same soft landing design ( you just don't need that much lift on the exhaust side)
My specs 226/242 LXL/Xtreme rpm .641/.627 116+2
Old 12-15-2012, 01:39 PM
lt1z
lt1z's Avatar
LXL lobes work well. I use them on both sides and as an exhaust lobe in combination with other intake lobes with good results. It all depends on exactly what you are looking to do with the car.
Old 12-15-2012, 03:19 PM
2000FRCZ19
2000FRCZ19's Avatar
St. Jude Donor '12
if I were doing my build all over again. I would use my same cam but use lsl lobes on the intake and the lxl lobe on the exhaust. the lxl is a slightly less aggressive lobe and will work well on the exhaust side.
Old 12-15-2012, 03:37 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
That is pretty much my blower cam. 230/242 LXL LXL but on a 116+3 LSA. Can't comment on the n/a part since I have a blower, but it drives great and idles nicely.
Old 12-15-2012, 06:45 PM
COVERT GUY
COVERT GUY's Avatar
These are all informative comments. I like that I hear a lot of you saying it makes for a good blower cam as well as a naturally aspirated cam. Never know when a Procharger may accidentally slip into the engine bay.
Old 12-15-2012, 07:01 PM
vertC6
vertC6's Avatar
LS7's like the wide split on N/A so that's why guys say they are similar to what a blower cam would be on a LS2/3. Blower cams usually have little or no overlap.
Old 12-17-2012, 11:16 AM
VetteVinnie
How about this one?
To Cam opinions - LXL lobes
Old 12-17-2012, 10:15 PM
Buddy A
Buddy A's Avatar
Originally Posted by EViL427
How about this one?
And that is 8* of overlap
Old 12-17-2012, 11:28 PM
2000FRCZ19
2000FRCZ19's Avatar
St. Jude Donor '12
How about this one?
stock intake or fast?
Old 12-17-2012, 11:30 PM
vertC6
vertC6's Avatar
Now that's a flat torque curve!
Quick Reply: [Z06] Cam opinions - LXL lobes
