C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] Official ZR1 Exhaust Mild 2 Wild Switch...
Old 07-12-2012, 10:51 AM
southerncarparts
Supporting Vendor
southerncarparts's Avatar
St. Jude Donor '06-'07, '13, '15
Default Official ZR1 Exhaust Mild 2 Wild Switch...
Guys,
We have partnered with Ed from Pipe Dreams and are offering his Mild to Wild Switch for $79.95 with free shipping. This is not a copy cat product, but the official Corvette Mild to Wild as seen on Jay Leno and Vette Magazine.
Ordering and additional info at the link below...
Corvette C6 Mild to Wild Switch
In stock and ready to ship!!
Also have a cool video on the site that shows the mild to wild in action.
Thanks,
Jim
Old 07-12-2012, 12:35 PM
tom46818
Support Corvetteforum!
tom46818's Avatar
Your website is charging shipping on this product. Is there a coupon code I should be using?
Old 07-12-2012, 03:19 PM
Nanook
lifeislikeaboxofchocolats
Nanook's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19-'20- '21-'22-'23-'24
Does it default to closed so car starts always closed.. ?
Old 07-17-2012, 10:10 AM
southerncarparts
Supporting Vendor
You probably have 3 day shipping selected by accident. Make sure ground is selected and the shipping will zero out.
Let me know,
Jim
Old 07-17-2012, 02:00 PM
Nanook
Nanook's Avatar
I'll take the lack of response to mean no ?
Old 07-17-2012, 08:24 PM
southerncarparts
Supporting Vendor
It remains in either On or Off position, such that, if you have the system turned off and valves open, they will be open when you start your car and vice-versa.
Thanks,
Matt
Old 07-17-2012, 09:13 PM
Nanook
Nanook's Avatar
So it can't be programmed to default to off ?
Old 07-17-2012, 10:58 PM
Gary '09 C6
Gary '09 C6's Avatar
You always want to shut down the car with the exhaust valves open, so as to reduce battery drain.
There is a no-drain installation method that can be used as well. It's in the instructions.
Old 07-17-2012, 11:37 PM
Nanook
Nanook's Avatar
I'm not so much concerned about the battery drain...I have one of these now.. and it always starts in the open mode...regardless of how I shut the car off..annoying..
Old 07-17-2012, 11:50 PM
Gary '09 C6
If I'm not mistaken, isn't that the "normal" way the bi-mode exhaust operates ?
Once the vacuum pressure is gone (engine off), the exhaust valves just open.
Old 07-18-2012, 12:00 AM
Nanook
Nanook's Avatar
Well mine are always open at startup..I'd prefer they start closed and I open if I desire or they open as normal..this device on my Z06 would start in the same state as at shut down...now I didn't install this one in this car so I'm not certain if it's the exact same or if it's connected differently (or if it even could be installed wrong).. ? (I didn't word this well)
Old 07-18-2012, 12:06 AM
Gary '09 C6
If I set my M2W so the exhaust valves are open at shut-down, they are open at next start-up and stay that way.
If I set the M2W so the exhaust valves are closed at shut-down, they are briefly open (no vacuum) at next start-up
but immediately close (vacuum restored).
Maybe you did have a different unit in your Z06 ? One would think all would work similarly...
Old 07-18-2012, 12:12 AM
Nanook
Nanook's Avatar
Yes there are different units I think..if one reads their website there are options for memory state at shut down/startup..I did look into the wiring but can't see an option there..(with my current unit)
Old 07-18-2012, 12:17 AM
Gary '09 C6
I purchased mine from Top Flight Reproductions, f y i.
Old 07-18-2012, 12:22 AM
Nanook
Nanook's Avatar
It's lookin like I may have to purchase a new unit..rats. Well at least I'll get rid of the remote with the newer type that can be learned by the Car2u system...which won't learn this current unit either..
Old 07-18-2012, 12:34 AM
Nanook
Nanook's Avatar
Okay I found the situation...the device has a power saving install method that if utilized always starts the car in the (what they call "off") position....otherwise I suspect it starts in the last used position...woohoo..will rewire tomorrow..
thanks for your input Gary
Old 07-18-2012, 04:04 PM
Nanook
Nanook's Avatar
Fixed..
To Official ZR1 Exhaust Mild 2 Wild Switch...
Old 07-18-2012, 10:57 PM
Gary '09 C6
glad I could assist, and good for you !
Old 10-05-2012, 01:27 AM
Brady Kohuth
Brady Kohuth's Avatar
No,it stays on whatever you have it on. The only way you change it,is when you use the controller.
Old 10-13-2012, 04:02 PM
southerncarparts
Supporting Vendor
Guys,
We have partnered with Ed from Pipe Dreams and are offering his Mild to Wild Switch for $89.99 with free shipping. This is not a copy cat product, but the official Corvette Mild to Wild as seen on Jay Leno and Vette Magazine.
Thanks,
Jim
Quick Reply: [ZR1] Official ZR1 Exhaust Mild 2 Wild Switch...
