[ZR1] Control your 2009-2013 bi-mode ZR1 exhaust from your universal visor remote!
Location: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
Control your bi-mode ZR1 exhaust from your 2006-2013 universal visor remote! No Fobs needed!
Open and close your bi-mode exhaust right from your universal visor remote, no keyfob remotes needed at all. 100% ZERO Battery Drain in ALL install configurations!
The Lear Car2U visor compatible Exhaust Commander is HERE! Get yours now! This controller works with your Car2U Universal visor remote! Its an exclusive feature found only on the Exhaust Commander car2u.
This is the exhaust controller you need it you want to control your factory 2009 - 2013 ZR1 exhaust from your built in universal visor remote.
Introducing the new Lear Car2U visor compatible Exhaust Commander
One Button Wireless GS/NPP/Z06/ZR1 exhaust controller!
For sale in my online store and ready to Command your NPP, Z06 or ZR1 Bi-mode exhaust using one button on your 2006-2013 Lear Car2U universal visor remote! No Fobs Needed, just your visor remote that is already built into your car!
The kit includes the 2006-2013 Lear Car2U visor compatible Exhaust
Commander main receiver unit. The install instructions are available at www.sunsetorangecreations.com
You can also have a keyfob remote added as a $25 option if you want to control the exhaust from outside the car. Keyfob remote is NOT needed to control the unit from your visor remote.
Take Command of you NPP, Z06 and ZR1 exhaust, you get to choose
whether the exhaust is Quiet and mellow, and you also get to
Command it to be Loud and mean when you want it.
Open and close your exhaust with ONE button on your Lear Car2U
visor. Switch between Quiet and Loud anytime at the push of a button!
You press the button on the Car2U visor once, the valves open and you are in Loud mode and ready to rumble! Press the visor button again the
valves in the bi-mode mufflers close and you have the quiet factory
operation mode, nice and quiet and opening at the factory rpm.
Exhaust Commander is 100% Zero Battery Drain when the
car is turned off.
Its a Simple 5 minute plug and play install! No permanent modification
is made to your car, it can be removed without a trace in 5 minutes.
Click Here to buy one--> Lear Car2U Visor Compatible NPP Exhaust Commander
Get your 2006-2013 Lear Car2U universal visor compatible Exhaust Commander One Button
Wireless NPP/Z06/ZR1 Exhaust Controller now!
Take Command of your GS, NPP, Z06 or ZR1 Bi-Mode Exhaust!
Every unit is tested by me personally to ensure perfect operation and they are
backed by a 100% Lifetime Warranty!
Click Here -> Exhaust Commander Elite the revolutionary new bi-mode exhaust controller!
NPP Bi-mode exhaust vacuum retrofit kits -> Exhaust Commander All-in-1 bi-mode retrofit kit.
My Online Store -> See all my Bi-mode Exhaust Controller Products!
car is turned off.
St. Jude Donor '13
Control your NPP exhaust using your built in universal visor remote.
No extra keyfobs needed, its plug and play!
St. Jude Donor '13
Place your order now and take full command of your bi-mode exhaust using your universal visor remote!
No Fobs needed! Lifetime warranty! Simple 5 minute install!
PM sent.
Another +1 for the visor controlled Exhaust Commander!
Received my unit last night, took 5 minutes to review the instructions, and then had it installed (including the quick programming of the visor button) in 15 minutes (and I was taking my time...lol).
The one bit of feedback I would provide is this: when it came time to place the Exhaust Commander unit below the stereo amplifier, as suggested, I realized my car's iPod/iPhone module was already occupying the space. It took a few minutes of looking around and a re-visit to your website, where I found your 'alternate location' instructions (which are great - and simple/obvious once I read you notes). The suggestion I would make would be to simply add the 'alternate location' instructions to the install as an appendix (or at least reference them in the install document).
I have only played with the unit in the garage thus far, but I can tell it will be super convenient and very 'OEM-like' to be able to simply hit the visor button!
Thanks for a great product!
eta: oh, and I love the fact you provide the option to have the unit start in either 'open' or 'factory closed' mode.
St. Jude Donor '13
St. Jude Donor '13
Spring has sprung and we are busy filling your orders!
A whole bunch of controllers are going out in today's shipments!
St. Jude Donor '13
On Sale now! Lifetime warranty!
No keyfob remotes needed, use your built in visor remote!
100% ZERO BATTERY DRAIN in every configuration!
Get yours now!
Get yours now!
