C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] Safety Recall Notice 2011 ZR1 #638
Old 10-18-2011, 03:06 PM
Emmett
Emmett's Avatar
Default Safety Recall Notice 2011 ZR1 #638
It seems the rear hatch hinges may allow the rear hatch to separate from the vehicle in a crash.They will have to replace both rear hinges,the service will take about an hour to complete.[Ya never had a recall of any kind take less than two hours.There are two dealers in my area and I intend on interviewing both the service manager and the the assigned technician and will stay and watch the entire process. This may sound extreme but I want them to know I expect the car to be returned exactly as I gave it to them PERFECT. Emmett
Old 10-18-2011, 04:06 PM
Trapper Sean
Trapper Sean's Avatar
I'm hip, bro. In fact, I might not even have the "upgrade" done. I don't GAF if the hatch comes off in crash. I don't ride back there.
Old 10-18-2011, 04:12 PM
Gary '09 C6
Support Corvetteforum!
Gary '09 C6's Avatar
...the voluntary recall is being done due to the unacceptable (per NHTSA ?) decapitation risk in the event of a rear-end collision at a high enough speed...
If my car was in the affected production range I would have it done, and quickly at that...
Old 10-18-2011, 04:34 PM
Trapper Sean
Who's at risk of decapitation - the Corvette driver or the rear-ender? I've wished almost as much upon tailgaters in SUVs, minivans ....
Edit: I searched and found the whole recall.
http://www.corvetteactioncenter.com/...ation+in+Crash
Old 10-18-2011, 04:41 PM
Gary '09 C6
I believe it's the Corvette occupants...front hinge attachment points fail, putting undue stress on the rear hinge attachment points...?
rear hatch assembly separates/deforms/shatters more easily in the crash ? flying debris more dangerous for the Corvette occupants...
I'm not an engineer, but GM did not agree to this voluntary recall for altruistic reasons...it's all about liability & money.
Old 10-18-2011, 06:44 PM
3LZZ06
_"SCOTT"_
3LZZ06's Avatar
I would have to say that this statement hits the center of the bullseye!
Old 10-18-2011, 06:59 PM
BluegrassMotorsport
BluegrassMotorsport's Avatar
A friend of mine has 2011 ZR1 #666, not too far from yours
She also says that hers was the last ZR1 produced in JSB. But I don't know how accurate that is.
Old 10-18-2011, 07:13 PM
VicCaerter
VicCaerter's Avatar
GAF... lmao thats cute.
Old 10-18-2011, 07:23 PM
MarkP
MarkP's Avatar
#638? Didn't you buy Harvey Gluck's 2011 #685?
Old 10-18-2011, 09:43 PM
range96
range96's Avatar
Received 1,989 Likes on 1,221 Posts
What is strange that only "certain 2011 and 2012 coupes" are affected.
Did they had a bad batch of hinges from their supplier?
"Coupes" mean steel and aluminum?
OP - did you actually received the recall letter or just assume that yours is affected?
Old 10-19-2011, 10:02 AM
Glenn Quagmire
Glenn Quagmire's Avatar
What is #638?
Old 10-19-2011, 10:20 AM
Emmett
Emmett's Avatar
Mark you are correct it is ZR1 number 685.Yes I did receive a recall notice from the General.
Tried to edit the post,but can't change the title to 685.
Old 10-19-2011, 10:44 AM
09Z06pj
09Z06pj's Avatar
Received 1,102 Likes on 753 Posts
Well stated. I feel fortunate that mine was not built in the timeframe specified in the recall. If it had been, I would RELUCTANTLY have the work done.
Good luck to those that need to have the work performed. Don't forget to do a complete walk-around inspection of the car with the service rep before and after the recall work is done.
To Safety Recall Notice 2011 ZR1 #638
Quick Reply: [ZR1] Safety Recall Notice 2011 ZR1 #638
