[ZR1] Vibration Problem-2012?
Does anyone know if the dreaded vibration problem has been corrected for 2012? I am on my 6th ZR1 and 4 of them have had the problem......It has been a problem since the ZR1 came out in 2009........Hopefully it has been addressed and corrected.......
Moderator
Received 3,622 Likes
CF Banner Relay Captain
West MI & JAX/NE Florida
Events Coordinator
St. Jude Donor '11-'12-'13-'14-'15-'16-'17, '21
Here is what I received recently from the Brand Manager for Corvette who worked on my 2010 in reference to the Wheels and Tires:
<<< We had them tested at the labs and both tires were out by road force more than we like. They were within limits but not as good as they could have been. It was though your car that we learned what we could do better. Because of what you went through the tire supplier to Bowling Green added new equipment so the tires and wheels could be match mounted to achieve a much better radial force variation. We have also went to cut to length wheel weights which makes the balance procedure more precise. If the balance machine called for a weigh of between 1/4 oz or less we did not have the ability to get a smaller weight. With the new process and new cut to length weights they can be much closer to what is required. We also learned that as the ceramic rotors wear they do not wear evenly. They stay flat but the weight changes as they wear and the rotor can actually go in and out of balance slightly as it wears. As much testing and validation as we do before we produce a car we just never seem to find all the issues until it gets in the hands of a customer.>>>
Hopefully this takes care of it. Have not heard of it occurring lately.
Six ZR1s!!!! Are you related to Harvey Details
Sixth ZR1, you must be second only to Spring Mountain. I had no idea that we purchased disposable vehicles. One can only hope that they are fabricated from 'bio-degradeable" materials.
No vibration issues with my 2011 ZR1. Took delivery in 2/11. I've had no problems with this car!
The Consigliere
Received 5,444 Likes
Probably not many '12s on the ground, and even fewer of them owned by CF members.
May take a while to see how they do in this regard.
I've been fortunate, my '10 has no such issues.
My 2010's vibration reduced to imperceptible after about 3,000 miles, and I hadn't heard a lot of complaints from others following a few thousand miles either. Still, nice to know GM identified and attempted to address the issue.
Thanks Deb!
I'm a little disappointed here.
The letter states that it is the nature of carbon ceramic brake rotors to go in and out of balance. GM is not offering solution to that.
As far as the new tire/wheel balancing, my 2010 already has the "variable" length weight strips, so nothing new there.
The dealers are told to not "recognize" the problem. Gee, I couldn't feel any vibration.
If 3 ton pickup trucks can be perfectly smooth why can't GM's jewel of the crown be?
A vibration issue is subjective (unlike a start/no start condition).
It is not a speculation.
I also have a letter from GM that states that after careful balancing the tires (and possibly indexing them to the wheels) if there is still vibration that is considered normal characteristic of the car.
In plain english: GM won't cover it under warranty.
As I said before, you can believe what you want, but these are the facts.
Before you paint me as a hater, overall, I'm very happy with my car.
You're twisting my words. I won't start an argument with you on this. Believe what you want. I know that what GM accepts for warranty claims is a great motivator for a dealer to see or not to see a problem that is marginal.
BTW, how many ZR1s in 2+ years
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes
St. Jude Donor '08
Your effort is admirable to address the problem, but it all comes down to that "indexing" is just a temporary band aid fix if the problem is with the rotors.
My dealer did the roadforce balance and it came to acceptable levels. GM paid for that. Still, a slight vibration exist. Now, the problem (according to the dealer) is undetectable.
I know, I must have bionic sensories that I can still feel it.
There were other examples where it was traced to the rotor's imbalance.
GM is admitting that the rotors could wear unevenly (weight wise) that causes inbalance. That may or may not result in a vibration.
In my case, the vibration existed since day 1, so, it is not an "uneven wear" issue.
I could fight city hall on this, but it just not worth it.
If the car comes back again and GM says it doesn't pay for any more warranty, what will you do? We're not talking about vibration that rips the steering wheel out of your hand. It is a much higher frequency vibration that makes your hands numb after driving for an hour.
Still this is an issue that my Pickup truck doesn't have with its 20" wheels and Pirellis.
I'm not criticizing or faulting my dealer, it is what it is. There are dealers who sincerely will try to fix problems. You and my dealer are that. Hopefully, someone at GM listens and will address the problem in a year or two, so future owners will not have to go through all this. That creates a better product.
Vibration
I can vouch what Range says, they will not warranty the rotors....The 2011 I have and drive the most is actually worse than when it was delivered......Ruins the driving experience.......Hard to believe that 3 yrs. later the problem is still there, what is even worse is that I am still buying them.....I have a good one that is perfect thank goodness but GM has lost this guy until it is proven this is no longer an issue.....Thanks for all your input and best wishes to my ZR1 brothers.....
Moderator
Events Coordinator
Still waiting to hear the details of your multiple ZR1s
Legally GM cannot deny warranty coverage on the rotors. They can deny a problem exists.
Some dealers will work diligently to solve the issue, others won't.
I still yet to hear from anyone who got a new set of rotors because of a slight vibration. Except maybe JVP. But, that's another story.
Vibration
I traded 3 of them because of the vibration problem, totaled one and have 2 in the garage...........one is perfect (2010 Lingenfelter 710 HP package) and my 2011 which I wish had been the one I totaled......
