C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Is a bigger cam than stock "harder" on a motor?
Old 04-26-2011, 10:28 PM
spinkick
spinkick's Avatar
Default Is a bigger cam than stock "harder" on a motor?
I've been looking at the Katech torquer cams and was wondering if the higher lift and overlap causes excessive wear on the motor, or if its just "harder" because the engine is outputting that extra power.
What do you guys think?
Old 04-26-2011, 10:34 PM
Blackdevil77
Blackdevil77's Avatar
Any increase in power would make it harder on the car as a whole, not just the motor. Not that a small increase in power would be enough stress to make it fail, but I would say it's harder. A higher lift cam puts more stress on the valve train, lets more air into the combustion chamber for a bigger boom to make more power, the bigger "boom" would cause more stress on the cylinder's, the extra power puts more strain on the transmission, drive train, everything. But not necessarily enough to make it fail. It's when the tune is off and everything isn't running at 100 percent that can cause extra, un-necessary stress that can cause things to fail.
Old 04-26-2011, 10:52 PM
spinkick
spinkick's Avatar
Originally Posted by Blackdevil77
Any increase in power would make it harder on the car as a hole, not just the motor. Not that a small increase in power would be enough stress to make it fail, but I would say it's harder. A higher lift cam puts more stress on the valve train, lets more air into the combustion chamber for a bigger boom to make more power, the bigger "boom" would cause more stress on the cylinder's, the extra power puts more strain on the transmission, drive train, everything. But not necessarily enough to make it fail. It's when the tune is off and everything isn't running at 100 percent that can cause extra, un-necessary stress that can cause things to fail.
Got it, thanks
To Is a bigger cam than stock "harder" on a motor?
Quick Reply: [Z06] Is a bigger cam than stock "harder" on a motor?
