Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette ZR1
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C6 Corvette ZR1
General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
Bill Stasek
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-26-2011, 02:40 PM   #1
awesomezr1
Junior Member
Default Dead battery
Went to drive it today after setting for a week and was completely dead. Called AAA for a jump start and still nothing. this is a AC Delco battery with 590 CCA and was tested to only have 85CCA remaining.Should I bite the bullet and buy another battery of the same make or have it towed to the dealer under warranty? I did notice that I left it in first gear and found out today that I should have left it in reverse. What a bummer. I just purchased it last September
Any suggestion ??
awesomezr1 is offline   Reply With Quote
Old 03-26-2011, 02:52 PM   #2
BT ZR1
2009 ZR1 SN 1166
Support Corvetteforum!
BT ZR1's Avatar
Leave the car in reverse and if its going to sit for more than a day or two just throw it on a tender. I am convinced these cars draw more than we think.
BT ZR1 is offline   Reply With Quote
Old 03-26-2011, 03:04 PM   #3
Richie High PSI
Junior Member
I hate to sound dumb, but why do you have to leave it in reverse, instead of 1st or neutral?
Richie
Richie High PSI is offline   Reply With Quote
Old 03-26-2011, 03:19 PM   #4
awesomezr1
Junior Member
The guy from AAA did a charge at the battery and not under the hood does anyone know if this could damage the system ?
Old 03-26-2011, 03:41 PM   #5
ufaj26
CF Senior Member
ufaj26's Avatar
I believe I would have it checked out by the dealer and replaced in case there is some type of electrical thing going on. Should not go dead in a week. Mine has sat for longer than that and still cranked.
I agree with having it on a tender. I do that now just as a precaution.
ufaj26 is online now   Reply With Quote
Old 03-26-2011, 03:45 PM   #6
awesomezr1
Junior Member
thanks
do you know why it has to be placed in reverse ?
Old 03-26-2011, 04:01 PM   #7
ufaj26
CF Senior Member
ufaj26's Avatar
No I don't. When parked in my garage I usually have mine in neutral. But I have been known to also leave it in first.
Old 03-26-2011, 04:32 PM   #8
capevettes
CF Senior Member
capevettes's Avatar
Quote:
Originally Posted by awesomezr1 View Post
thanks
It doesn't. Only the 2005 6 speeds required that the car be shut down in reverse to prevent battery rundown. GM only recommends Reverse for parking as it is the gear with the most holding power. These cars have computer functions that never really allow the car to go to sleep.
Get a C-Tek 3300 battery tender and leave the car on it when not in use. I would also get a new AC Delco Professional Series battery. After a complete rundown, the battery is never the same.
capevettes is offline   Reply With Quote
Old 03-26-2011, 04:35 PM   #9
GOLD72
CF Senior Member
GOLD72's Avatar
thanks
It does not have to be put in reverse. GM changed the programming with MY2006 to avoid DBS.
I see that you bought a 2010. I am going to guess that your car was built well before September 2010. It could be many months just sitting on your dealer's lot. Meaning the battery was not kept up during that time. If this is true, I am not surprised that you are having battery problems. You should be eligible for a free replacement by your dealer.
__________________
GOLD72
1972 WB Coupe L48/TH400 - Sold
2001 QS Z06 - Sold
2006 VY Z06 - NCM Delivery - Sold
2007 MR Vert - NCM Delivery & Wife's Garage Queen
2010 Vanilla Latte CTS 3.6L Sport Wagon - Wife's DD
2011 AW ZR1 - NCM Delivery & Daily Beater
GOLD72 is offline   Reply With Quote
Old 03-26-2011, 04:56 PM   #10
awesomezr1
Junior Member
Thanks guys. I'm going to call GM Monday and get it towed to the dealer. Just hope that the driver doesn't screw it up loading on the flat bed. I am sure the dealer will give me hard time when I ask to have the battery replaced instead of just letting them charge it
Old 03-26-2011, 06:52 PM   #11
rwpatte
CF Senior Member
rwpatte's Avatar
The dealer usually charges them before checking the electrical system. Some dealers will give you a hard time before replacing the battery, and some won't.
I rotate between my Z06 and my ZR1. I keep a battery tender on one or the other to insure that the battery is topped off.
rwpatte is online now   Reply With Quote
Old 03-26-2011, 07:53 PM   #12
Reciprocal
CF Senior Member
No way in hell I get it towed for a battery, I'd rather pay for a new one than go this route.
Reciprocal is offline   Reply With Quote
Old 03-26-2011, 08:01 PM   #13
Reciprocal
CF Senior Member
The only reason for not connecting to the battery is to avoid sparking off a hydrogen bomb if it's gassing, or to provide a connection point with more surface area. No harm caused.
Old 03-28-2011, 10:05 PM   #14
edittman1
Junior Member
edittman1's Avatar
I highly doubt that the reverse trick keeps it from draining.
I think its just that the computer slowly drains it in about 7 days.
edittman1 is offline   Reply With Quote
Old 03-29-2011, 06:39 AM   #15
camirocz
CF Senior Member
7 days is ridiculous. It is not a normal situation.I agree that your car sat for a long period on a g.m lot somewhere and the battery took a beating while it was there.
camirocz is offline   Reply With Quote
Old 03-29-2011, 09:06 AM   #16
awesomezr1
Junior Member
Taking the beast to the dealer today for a battery check. Spoke to the Corvette mechanic at the dealership yesterday and found out that the 2011 ZR1 has a $100.00 option for a battery tender. You would think that GM would make everyone aware of this problem upfront, but I guess since we are only spending $100K plus it's no big deal
Old 04-01-2011, 01:08 PM   #17
awesomezr1
Junior Member
After inspection GM failed to replace the battery under warranty, but the dealer in Maryland, Koons Chevrolet stepped up and replaced it at no charge First class operation
Old 04-01-2011, 01:12 PM   #18
ufaj26
CF Senior Member
ufaj26's Avatar
What a crock!!!!
To the dealership !!!!!
Old 04-02-2011, 11:44 AM   #19
narush
CF Senior Member
narush's Avatar
I have to keep my on a charger as well or the damn car is dead in a few days. I just went ahead and out a deep cycle gel battery in it and damn if the car does not drain that battery as well.
narush is offline   Reply With Quote
Old 04-04-2011, 12:01 AM   #20
GForceSS
CF Senior Member
GForceSS's Avatar
GForceSS is offline   Reply With Quote
Reload this Page Dead battery
Tags
2010, battery, corvette, dead, pevent, rundown, zr1
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
