[Z06] Day Lights Running Lights
I want to change the yellow Day Running Lights bulbs to white on my Z06, anyone knows the Bulb number and where can I get the Bulb. I went to two local auto parts and they couldnt pull the item on their computer
Easy change - just turn the front wheel and remove the access flap.
IThe OEM bulb is a 5702KA (2005‐2010) (owner's manual)
Sylvania makes a good replacement bulb in the 3157NA / 4157NA.
I found a bulb that is white when off and amber when on so that you don't get the "egg yoke" look when the car is off, but looks normal when driving.
You can also find white bulbs from Sylvania.
I went with Hoen bulbs for the high beams (to match the white HID low beams), fog lights, and front turn signals (amber when on, silver when off).
