C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] Lowered ZR1 Pictures ?
Old 08-01-2013, 07:22 AM
  #41
JG853
JG853's Avatar
Is this Inferno Orange or Torch Red - Looks nice either way
Originally Posted by Zeekmann
Lowered on stock bolts....
Old 08-02-2013, 05:49 AM
  #42
jdmvette
Night Owl for life
Support Corvetteforum!
jdmvette's Avatar
Received 3,237 Likes on 1,661 Posts
Old 08-02-2013, 08:26 AM
  #43
barduch
barduch's Avatar
IIRC, Zeekmann posted in another thread that his car is IO. IO, IMO, is the new "king of the color orange" supplanting Ford Grabber Orange from the late 60's and early 70's. And, it just seems to pop on a ZR1.
Old 01-29-2014, 09:36 PM
  #44
cruzc5frc
cruzc5frc's Avatar
Originally Posted by SWB3
I lowered mine. You need to take it in and have the steering angle aligned, not sure anything else needed alignment.
wasn't aware of this and plan on lowering mine all the way down on the stock bolts. is this alignment DIY or dealer would know how to adjust?
anyone confirm or deny if this is mandatory?
Old 01-29-2014, 11:18 PM
  #45
nightflyer
nightflyer's Avatar
2015 C6 of the Year Finalist
Lowered on factory bolts. I had mine aligned afterwards and the only adjustment was made to the right rear, other than that it was still spot on and the tech told me it was a very small adjustment!!
Old 02-01-2014, 08:15 PM
  #46
timmyZ06
timmyZ06's Avatar
look awesumm!!!
Old 02-01-2014, 10:13 PM
  #47
nightflyer
nightflyer's Avatar
Thanks TZ06
Old 02-02-2014, 07:49 AM
  #48
Z06Ronald
Z06Ronald's Avatar
ALL lowered ZR1s in this thread look fantastic!
@nightflyer - Are the parts that the arrow is pointing to from APSIS? Do you have a part #?
Old 02-02-2014, 07:55 AM
  #49
Z06Ronald
Z06Ronald's Avatar
I'm awfully sorry ... the LMB Z06 looks SICK too!!!
Old 02-02-2014, 09:41 AM
  #50
nightflyer
nightflyer's Avatar
those are not from Apsis, those are the factory parts. I ordered a roll of CF and put that on there myself. I took the piece off of the car, cleaned it very good then put the CF on there allowing it to extend beyond the edge. I then took a very sharp razor knife and trimmed it. After that I put a couple of coats of clear over the top and it has been on there a couple of years now!! Very easy to do and I have a lot of people asking where I got it. I also did the same to the pieces in front of the rear tires!
Old 02-02-2014, 09:53 AM
  #51
Z06Ronald
Z06Ronald's Avatar
Wow, the result is fantastic!!!
One more question, if I may ask: what brand is that roll of CF?
Old 02-02-2014, 10:29 AM
  #52
nightflyer
nightflyer's Avatar
it's 3M. I bought it from MetroStyling.com. You can by it by the roll there as much or as little as you want. Works good and has lasted a long time. I get a lot of questions about it from people that see the car in person.
Old 02-02-2014, 03:14 PM
  #53
Z06Ronald
Z06Ronald's Avatar
It appears to be metrorestyling, and I found it: http://www.metrorestyling.com/Carbon...-Wrap-s/25.htm.
Thanks a lot for your reply!
Old 02-02-2014, 05:40 PM
  #54
nightflyer
nightflyer's Avatar
yea, the stuff works pretty good and is pretty easy to work with, just make sure every thing is good and clean before applying and if you can find some of that 3M adhesive promoter...little yellow foam pads...it will really help...good luck and pics after you finish!!
Old 02-03-2014, 05:56 PM
  #55
ace32x
ace32x's Avatar
lowered on stock bolts aswell, thought about going with the longer bolts and dropping it a bit more but the front is as low as it can be with out scrapping on speed bumps atm (stock bolts maxed front and rear)
Old 02-04-2014, 08:34 AM
  #56
cruzc5frc
cruzc5frc's Avatar
Nice!
Old 04-24-2014, 08:40 PM
  #57
Al3x_666
Al3x_666's Avatar
Sorry thread Hi-jack...!!
But do you go all way down front and rear?
Because I want to do this mod tomorrow when my car will be on the lift for the wheels swap.
thanks
To Lowered ZR1 Pictures ?
Old 04-24-2014, 11:18 PM
  #58
nightflyer
nightflyer's Avatar
thanks
yes, all the way down front and rear!
Old 09-15-2018, 12:14 PM
  #59
JackZR1
JackZR1's Avatar
Did you lower both front and rear? I want to do this to my 2013 Zr1
Old 09-15-2018, 12:16 PM
  #60
JackZR1
JackZR1's Avatar
Attachment 47763076
Attachment 47763077
Attachment 47763081
Looks Sick, did you lower both front and rear? I noticed that other guys only lowered the rear
Quick Reply: [ZR1] Lowered ZR1 Pictures ?
