C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] Genuine GM Corvette Battery Tender Charger Available - GM Parts House
Old 01-12-2011, 08:03 PM
Gene Culley
Premium Supporting Vendor
Gene Culley's Avatar
Default Genuine GM Corvette Battery Tender Charger Available - GM Parts House
Hello All,
Quite a few people have been waiting for this item. It is the Genuine GM battery tender charger with Corvette logo! It has a Corvette logo carrying case and comes with a manual for $91.56! To order, go to www.gmpartshouse.com/search.html and use part number 20929740 and be sure to select Chevrolet make.
Thanks,
Gene.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Gene Culley is offline
Old 01-14-2011, 08:24 PM
Gene Culley
Thank you for the orders on this item. It is a nice item.
Old 01-15-2011, 06:34 PM
speedwaylemans
speedwaylemans's Avatar
Gene,
Does this plug into the cigarette lighter? Does it switch itself off and start back when needed to keep the charge while the Vette is sitting, like the battery tender does, forget the name, but the one everyone seems to be using. I like the look of this and just wanted some more details, thanks.
speedwaylemans is offline
Old 01-16-2011, 08:44 AM
Gene Culley
Originally Posted by speedwaylemans
Gene,
Yes, this one does come with the cigarette lighter adapter. It does everything for you. Think of it as a smart phone, hehe. I wish I could scan in the manual for you, but it is a small booklet and hard to scan.
Old 01-16-2011, 09:14 AM
speedwaylemans
Thanks for the answers.
Old 01-17-2011, 09:02 PM
Staxxin
Staxxin's Avatar
Pardon my ignorance but can this is the unit I can leave on my car through the winter when it's not being driven or is this simply a charger??
Thanks!
Staxxin is offline
Old 01-18-2011, 11:17 AM
patrickt
patrickt's Avatar
Thanks!
This is "a smart charger". You can leave it plugged in all winter long and it will maintain the battery voltage without overcharging.
__________________
Patrick Trageser
CULTRAG Performance
Your one stop source featuring the true experts for all GM Parts and Accessories, Lloyd mats, SLP Performance and Hawk Brake pads!
Order Your GM Parts at www.CULTRAGfactoryparts.com
patrick@cultragperformance.com
1-484-334-8833
patrickt is offline
Old 01-18-2011, 01:19 PM
RonR80
RonR80's Avatar
St. Jude Donor '09
Same C-tek charger you can get anywhere,
RonR80 is offline
Old 01-19-2011, 09:33 PM
Gene Culley
Here is some further information for you.
CTEK battery chargers aren't just boosters: they charge and maintain batteries with a patented system that's battery- and electronics-friendly. CTEK designed these elegant, compact chargers to be water- and shock-resistant, and they're UL-approved for outside use and immune to power line fluctuations. Your batteries will be charged efficiently with no interruption in their charging cycles. CTEK chargers' safety systems feature sparkless connections that won't allow you to damage your vehicle's electrical system, even if you hook them up backwards.
The MULTI US 3300 charger works with most 12-volt batteries found in motorcycles, cars, SUVs, and small boats. It features a low-temperature mode that ensures your battery will get charged, and will maintain its charge, no matter what the weather.
Maintenance charging prolongs the lifetime of your battery by preventing complete discharge and acid buildup — perfect for motorcycles, snowmobiles, boats, campers, and other recreational vehicles that only get used seasonally, or for "must-start" equipment like snow plows and tractors.
The MULTI US 3300 uses a patented 3-stage cycle of energizing your battery, filling it with power, and maintaining its charge — this cycle repeats itself when the battery's voltage drops too low. And never fear for your audio equipment or other electronics: CTEK battery chargers are completely safe to use without having to disconnect your system.
Old 01-20-2011, 01:08 PM
RonR80
RonR80's Avatar
St. Jude Donor '09
I agree there are great I have 4 of them and use them on anything that has a battery, Ron
RonR80 is offline
Old 01-22-2011, 08:25 AM
Gene Culley
Thanks for your input! It is certainly appreciated.
Old 01-24-2011, 10:16 PM
RobMorgan
Support Corvetteforum!
RobMorgan's Avatar
I bought a CTEK charger at the recommendation of a GM engineer who responded to my posting on the forum because my battery went bad in less than 6 months when it was driven sparingly because of weather. No way you can store a ZR1 without a battery tender and these work great. I ended up buying more and throwing out all the cheap tenders that I had and use these on everything.
RobMorgan is offline
Old 01-26-2011, 12:04 AM
GForceSS
GForceSS's Avatar
My battery seems to last about 2 weeks at most. I walked out this morning to move the car and the battery was dead....again.
Just placed my order
GForceSS is offline
Old 01-26-2011, 08:39 PM
Gene Culley
That is certainly good advice. If you're not going to be driving the vehicle on a regular basis, don't waste the battery and get a tender!
Old 01-26-2011, 08:40 PM
Gene Culley
Well, that certainly seems like it is necessary to get one. Thank you for the opportunity to earn your business.
Old 01-28-2011, 09:45 AM
bobby777
bobby777's Avatar
Wheres the C5 logo? also this unit looks like the ctek-800 model NOT the 3300 unit??
bobby777 is offline
Old 01-28-2011, 07:53 PM
Gene Culley
The manual states it is a CTEK 3300, and the manual comes from GM. This was to be released for the C6 so there would be no C5 logo. It works in a C5 fine though!
To Genuine GM Corvette Battery Tender Charger Available - GM Parts House
Old 01-30-2011, 08:25 AM
Gene Culley
Order your battery tender from GM Parts House.
Old 01-31-2011, 06:36 PM
Staxxin
Staxxin's Avatar
Thanks again guys for the great promotions! I finally placed my order.
Staxxin is offline
Old 01-31-2011, 06:51 PM
isnider
isnider's Avatar
Just placed my order...no free shipping for loyal customers???
Thanks again Gene for doing the research and posting pictures!
Ian
isnider is offline
Quick Reply: [ZR1] Genuine GM Corvette Battery Tender Charger Available - GM Parts House
