[ZR1] Genuine GM Corvette Battery Tender Charger Available - GM Parts House
Premium Supporting Vendor
Thank you for your business. I certainly appreciate it.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
I will be ordering one here shortly (along with some ceramic front pads) for my Z. With the month long exercises and deployment coming up I am definately going to need one of these.
I hope the car even starts when I get back April first, will have been over a month since I last fired her up.
Thanks,
Ben
yes once the order is processed you will get a confirmation email then another with all the tracking info once it ships
__________________
Patrick Trageser
CULTRAG Performance
Your one stop source featuring the true experts for all GM Parts and Accessories, Lloyd mats, SLP Performance and Hawk Brake pads!
Order Your GM Parts at www.CULTRAGfactoryparts.com
patrick@cultragperformance.com
1-484-334-8833
CULTRAG Performance
1-484-334-8833
#34
Cruise-In II Veteran
The CTEK is a very good charger. I don't like the setup of where the cord will come out of the car to plug in to the 110 volt outlet.
A Z06 owner and friend of mine ran his connector out the back near the license plate. The cord doesn't touch the paint.
#37
Gene,
Does this plug into the cigarette lighter? Does it switch itself off and start back when needed to keep the charge while the Vette is sitting, like the battery tender does, forget the name, but the one everyone seems to be using. I like the look of this and just wanted some more details, thanks.
Scott...
#38
This may seem a bit redundant but if you are plugging into the lighter to maintain a charge aren't you draining the battery at the same time you are trying to keep it charged? I assume then that the amount being sent to the battery is larger than the amount you are draining when plugged into the lighter? Just seemed a bit odd to me...
Scott...
Scott...
#39
Scott...
#40
Not to beat a dead horse but that makes no sense. If the battery tender were hooked up directly to the battery it would probably be plugged into a wall unit. The question was did it have a plug in adapter for the car...my point was if you plug it into the car you are charging isn't that self-defeating? You are draining the battery via the plug-in while trying to charge it at the same time? Unless I am missing something it just seems as though this is not aparticularly well thought out question/issue....now that I think about it, this is probably wasting a lot of time over an issue that is not all that important...I am sorry I brought it up @ all.......
Scott...
Scott...
