[ZR1] Corvette ZR1 Vette Tray
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
Thanks, glad you like it and taking the time to post!!!
Thanks,
Jim
Thanks,
Jim
Just received and installed (30 second drop in process) both the tray with the lids and the partition. I opted for no badging and it is just the clean look that I was hoping for. The carpet color and texture match is perfect. The color match is much better than the Lloyd's mats, but the Lloyd's are a more plush texture and I still think they are a must do. The tray and partition are the first after market purchase, for the ZR1, that my wife thinks make practical sense. Nice product!
PN Corvette C6 Trunk Partition
(Coupe & Z06)
[001-004]
#38
Received 1,391 Likes
2021 C2 of the Year Finalist - Unmodified
2015 C3 of the Year Finalist
That's a great idea, and unlike the center console storage, it won't cook bacon you put in it....
#40
Supporting Vendor
Southern Car Parts is VERY proud to introduce our two Corvette C6 Cargo Organizing solutions for all C6 Vettes including the Z06 and ZR1. The Original Vette Tray and Partition and the newly launched Vette Tray 2 and Partition combination.
The Original Vette Tray is made of extruded polystyrene (type of industrial foam) which is very strong (for foam) and light weight. It weighs a little less than 3 lbs and is perfect for someone who wants an open solution that is very easy to get things in and out of. Combined with the partition (made of 1/2" MDF board) it is an excellent combination to keep stuff from sliding from the trunk area up to the front of the car and for organizing loose items in the cockpit.
Our second option is the Corvette C6 Vette Tray 2 and Partition
The Vette Tray 2 is made of MDF Board (weighs a bit more than our original Vette Tray (20lbs)) and has hinged lids that are nearly unnoticeable to the casual passer by. Designed to be stealthy, the dual compartments give you a place to hide/store items in your Corvette. The Vette Tray 2 also can be combined with our partition for the same reasons as above (keep stuff from sliding all over the car). Unlike the original Vette Tray, the Vette Tray 2 DOES allow you to utilize your partition when the roof is stowed in the back, with the original Vette Tray you need to pop the partition out when your roof is in the back.
Both solutions install and remove without modifying the car.
More information below
Original Vette Tray
Vette Tray 2
Original Vette Tray
Vette Tray 2
