[ZR1] IPS TT ZR1 Pics
IPS TT ZR1 Pics
Just so you don't have to go all the way to the 2nd page of the other thread here are the build / set-up pics:
http://www.flickr.com/photos/ipsmoto...7623877946145/
Summary of the set-up is as follows:
Bone-stock LS9 (Including stock cam)
IPS Twin-turbo Kit featuring HTA 35R Turbos & Tial 44mm WG's
IPS Custom Fuel System
IPS FMIC Kit w/Tial BOV
IPS High-output Alternator Kit
RPS Triple-disc Carbon Clutch
RPM Level 5+ Tranny & Rear-end
PFADT CF Driveshaft
DeWitts Aluminum Radiator
LS7 Engine Accessory Parts
No dyno #s w/o the owner's permission but I will say that it made as much power at 7psi as it did with the stock blower and many bolt-ons did at 16-17psi
At 15psi and pump gas (No meth) it has made more than any other LS9 ZR1 we have ever heard of E85 and larger injectors are going in on Friday and it is only going to go up from there
Dyno graph's / Vid's and further info to come!
Jeff
PFADT CF Driveshaft
Jeff
Since the plan all along was to tune it on E85 the owner doesn't care about posting the pump-gas #s so here they are:
Prior to the Twin-turbo conversion the car had a nice assortment of bolt-on's and a tune. At 16-17psi it put down a best of 627rwhp on our AWD DynoJet and an average of 615rwhp.
With the turbo kit on base-boost (7psi) it put down 626rwhp on a VERY conservative tune and just over 700rwhp at 10psi and then 850rwhp at 15psi
Larger injectors will be here Friday to run E85 where we fully expect to break into the 900s at 15psi and mid 900s if we run the same boost levels it ran before on the stock blower set-up. Stay tuned!
Jeff
Jeff
Jeff
Jeff
is the powerband still heavy thick even down low?
- Bryan
Any plans of meth to combat IAT's or are you going to run E85 solely?
Great numbers!
Jason
Great numbers!
Jason
Jeff
It obviously isn't going to have that huge spike in torque you get from a positive-displacement blower but the power-band is still incredibly flat / broad. From 4k and up there is no comparison at all
I will get some dyno graphs posted soon
Jeff
There really won't be many options aside from turbo choice which will consist of the following:
1. 3076R w/1.06 A/R in Billet or Non (1000-1200HP)
2. 35R w/1.03 A/R in Billet or Non (1200-1300HP)
3. 35R+ w/1.03 A/R in Billet or Non (1300-1600HP)
Any specific questions just email me at: sales@ipsmotorsports.net
Jeff
Jeff,
Honest question here:
How can a 6.2liter engine make more power per pound of boost than 7.0liter engines using similar components?
Also, 620rwhp doesnt sound right for a pullied ZR1, but you already mentioned you're dyno is convervative. Now, how is the car making much more power at the same level of boost? I understand turbos are more efficient than blowers, but turbos have their own restriction as well (exhaust restriction) whereas you can run a 2" header on a blown corvette. Point "many" are missing is that turbos are also not free power, again I thought maybe 60-80 more rwhp based on efficiency alone, but 300+ rwhp? How is that possible.
Again, this is an HONEST question, and im looking for a technical answer here
Taylor from Dallasperformance did 680rwhp from a pullied ZR1 with headers, custom CAI, heat exchanger and tune. and 700rwhp with race gas.
If another 10-second C6 shows up out of the blue for comparison then it might be an even better vid
Jeff
Jeff
1. MUCH better turbos
2. 6-speed Tranny in the ZR1 (Which is more whp friendly)
The crazy thing is the turbos are not even in their "Sweet Spot" just yet so it should REALLY start making good power in the 16-18psi range
Jeff
