[ZR1] New ZR1 Record Pass 10.74
#41
I don't think it would be easy, but I guess almost anything can be possible within reason if everything is perfect. I don't think 10.40's is possible anymore. I went to a rental yesterday with a borrowed set of CCW Wheels with MT ET STREETS, the exact combination that the Lingenfelter car used and the traction was excellent but the problem I had was the those particular tires were too much tire for a stock car as they were too tall, about 2 inchs taller than my stock tires and about 3 inchs taller than my DR's I use on my Z06 and they killed my mph and the only way I could keep the car from bogging was leave at about 4800 rpms and that caused my clutch to get hot and it stuck to the floor on some of the few runs I made and I couldn't make the shift and it killed the run. They were too big and tall for stock hp levels without gears, and the best of my 3 clean runs were 10.69 with a 1.67 short time. I just bought a set of CCW wheels of my own and I am going to buy the much smaller BF Goodrich or Hoosier tire and give it a try again in the spring but I still feel whether its me or Kyle or someone else, 10.50's are going to be the absolute best IMO.
#42
RE: Jamie
I think with the shorter DR's we will atleast see some low 10.5x because on all my 10.7x passes (except for the record run) I was having pretty severe wheel spin on the 1-2 shift. I dont think the DR's will net much better than your 1.67 60.....but the shorter ones will really let us get the power down on that 1-2........When I stoped trying to hit that shift hard is when I started getting more runs in the 10.7x range.
#44
Ron I agree with you! I think the chirping you hear when changing gears is hardly worth anything, definately not even 5 hundreths IMO. Personally I think most of, if not all the improvement to run .50's is going to have to be made up in the first 60'. I think a good example is to look at Rangers record Z06 10.74 DR run that beat mine, 100% of it made up in the first 60', .59 to .70 and it was a .74 to a .83 at less mph. Et is all in the first 60' for the most part, I think its going to take a 1.60 or better 60' to have a chance to run 10.50's, but it will have to perfect leave and clean run. DR's on my ZR1 were much harder for me to get a feel for than the steet tires and I don't feel I ever really did (I need some practice). Ranger took Racerns ZR1 to 2 rentals with DR's and I think he said with gearing in the ZR1 it made it extremely tricky to launch and I think that was an understatement! It looks like there are quite a few good ZR1 pilots from what I have seen and when the spring gets here I guess all the speculation will end.
#45
#47
I agree with you on the savings from DR's......but dont forget we dont think that my 10.74 is the end of it on street tires as well.....I think mid 10.6x's is out there on the stock tires.....Im hoping we get a good weather spell in Jan or Feb. This is one car that is going to be alot of fun to try to see how fast it is....I was getting faster all day till the track went away on us that day. Also I dont think the ZR1 needs the crazy DA like the Z06 does I think 55 to 60 deg day with sun will make the track better which is what we need not air! Like we said I think the Z06 passes have found the records!
#48
You guys are great drivers & I will be watching your progress!!
Ron
#49
Great meeting you Jamie! I feel wheelspin on gear changing does effect ET, but I don't think it's worth 2 tenths. Obviously time a tire spends spinning is less time it spends hooking & propelling the car forward....
Ron
Ron
#50
Jamie is right et is in the 60 ft. With the mph the zr1 get's your going to see the zr1 run low 10's. Once you get the hang of launching on dr's
low 1.5 60ft will come. there's a fine line launching a blower car no spin or no bog the car will do it. Nobody thought 1.5's could happen with the z06 but in time they see it can.
#51
#52
I think the only way a stock ZR1 will run low 10's is with some type of clutch or clutch master cylinder upgrade, which in some folks eyes is no longer considered stock. If we can get a strong launch and get the clutch to behave, a low 10 is possible.
#53
Sal definately not totally stock, and I agree it would need a clutch but I think it would need more than that also, like gears to go with that clutch if you are looking to go below 10.4. Driver my best MPH has been 133.7 mph on street tires.
#55
Do you know how much 4 tenths is?? It's a spanking. Plus for that extra you are paying you get much, much more than a 4 tenths drubbing of a Z06. IE: road course spanking of a Z06 by many seconds, exclusivity, etc etc
#59
For the ultimate vette, you have to pay to play. Sounds alot like the base guys claiming the 20K price over a base C6 makes the Z06 not worth the extra money.
