[ZR1] 2010 ZR1 dyno results
We dyno'd my buddy's 2010 ZR1 yesterday, with 700 miles on the odometer. I've dyno'd LOTS of Vettes, but this was different than earlier ones. First getting the traction control off via the button and the 5 position ****. Then on the first run I stabbed it too fast to WOT and torque management kicked in, taking out lots of midrange torque. That run gave 560 SAE RWHP but only 485 SAE RWTQ.
A big difference from earlier Vettes is that you can't just hit reset to remove the DIC warnings of Service Active Handling, Service ABS, etc. They throw codes and put the car into limp mode after the first dyno run. I had to use a code reader to remove them before I could get the car into race mode for the second run.
Finally got the car ready to dyno again, ROLLED into the throttle, and final results:
568 SAE RWHP and 520 SAE RWTQ
I had heard the 2010's were dynoing higher than the 2009 ZR1's, what do you think?
BTW: We've dyno'd 5 stock Z06's on this same Dynojet and all put out 440 to 450 SAE RWHP, so this isn't a particularly generous dyno.
Its so hard to compare numbers from dyno to dyno as you know but that one seems to have a bigger gap between rwhp and rwtq than most other zr1 dyno sheets that I have seen.....could you post the graph may still be getting into tq mgt.....and what codes did you pull?
Interesting, I've got a '10 with 2300 miles on it now. Sounds like there's a need for a confirming dyno run
Were you using 91 or 93 or ? octane gas for the pulls?
but 560 sounds a little higher than what ive personally seen. Never dynoed mine however.
About the codes... unknown. The diablosport Predator said "no codes found", but cleared whatever was set anyway.
> Albuquerque is at 5,000+ altitude, 91 is the highest octane pump gas available
Ah - but then the dyno figures would be corrected not actual. I'm curious whether the ZR1 needs 93 octane (or higher) at sea level to make max power?
Of course the numbers are corrected, our dyno correction factor for SAE at the time was 1.19. That's pretty good air for ABQ, NM. I've seen it as high as 1.25 when racing.
SAE is the best, commonly used standard. People who use uncorrected are usually in below sea level conditions for bragging rights.
I'm sure that at sea level 93 octane will produce better results than 91.
Sadly, here in CA we don't get anything beyond 91 octane, even at sea level.
