Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Corvette ZR1
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette ZR1
General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
Bill Stasek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-14-2009, 12:12 PM   #1
J HEBERT
CF Senior Member
Support Corvetteforum!
J HEBERT's Avatar
Default 10.24@ 133.51
That's right, and the track air could have been much better.
60' 1.432
330 4.213
1/8 6.547
mph 106.33
1/4 10.241
mph 133.51
Mods are upper/lower pulleys, headers/no cats, Katech heat exchanger and Z06 gearing in the trans. The only other mod was tuning out torque managment and my driving. I need to take this opportunity to thank lfsglass for his help in swapping my transmission, my back is pretty sore these days, and he just stopped by to lend a hand......well, turns out, he did MOST of the work. I was there, but he turned 3 out of every 4 bolts and for that, I owe u buddy!
Stay tuned, I am going to talk Richard at WCCH to send some heads to me, and I will port the blower as well. I know we can do this with a stock cam, but a custom EPS grind will insure success. We look forward to hitting the 9s in the next 30 days. The 2.97 transmission will make it's way into the car b4 I try the auto, but I think 9.60s is not out of reach when we are done. Other than the headers, this car appears bone stock. BTW, the DA was only -100 last night and we use shell 93oct fuel
J HEBERT is offline   Reply With Quote
Old 11-14-2009, 12:31 PM   #2
ATMER1
CF Senior Member
Congrats on your time.
Just out of curiosity, assuming you have an overdrive 6th gear as in the Z06, has the gas mileage improved?
Also, w/ the improved pump/heat exchanger how noticable is the improved power retention from reduced heat soak?
Thanks,
John
ATMER1 is offline   Reply With Quote
Old 11-14-2009, 12:34 PM   #3
69 Vette
CF Senior Member
69 Vette's Avatar
Congrats on the run John. I see the DA dropped into the negatives last night. I knew i should have stayed at the track.
69 Vette is offline   Reply With Quote
Old 11-14-2009, 12:35 PM   #4
lfsglass
CF Senior Member
lfsglass's Avatar
Quote:
No problem at all........kinda fun helping build the (soon to be) fastest ZR1 !!
60' 1.432
330 4.213
1/8 6.547
mph 106.33
1/4 10.241
mph 133.51
The first 9 sec ZR1 could have appeared last night with race gas and a little more timing !!!!
lfsglass is offline   Reply With Quote
Old 11-14-2009, 02:16 PM   #5
LEAVINU
CF Senior Member
LEAVINU's Avatar
I think this may be the first I have heard of swapping gears for Z gears? Whats the mph gain in each gear? Are the stock gears like that of the Z51 tranny (shorter) in the ZR1?
Congrats on the great run!
LEAVINU is offline   Reply With Quote
Old 11-14-2009, 02:23 PM   #6
J HEBERT
CF Senior Member
J HEBERT's Avatar
I used the 2.66 gear trans last night, I am building a 2.97 unit that should get the 60' well into the 1.3x range. And yes, highway mileage up a good bit, going from 2400rpm cruise to 1400rpm cruise. The car is now slower from 150-200, but quicker 0-150 As far as heat soak, I made 2 passes back-to-back and the 2nd pass was quicker, but I shifted around 5800 instead of 63-ish.
Old 11-14-2009, 02:38 PM   #7
Katech_Jason
Premium Supporting Vendor
Katech_Jason's Avatar
Send a message via AIM to Katech_Jason
60' 1.432
330 4.213
1/8 6.547
mph 106.33
1/4 10.241
mph 133.51
Nice job. 10.2 is really moving. I have LS9 head stud kits which you'll need because those head bolts are unobtainable.
__________________
_Jason Harding
Director of Aftermarket Operations, Katech Performance
__________________________________
http://www.katechperformance.com
YOUTUBE
FACEBOOK
MAILING LIST
Katech_Jason is offline   Reply With Quote
Old 11-14-2009, 03:11 PM   #8
J HEBERT
CF Senior Member
J HEBERT's Avatar
Quote:
I am going to need the million-layer head gaskets as well, going w/ ls3 heads and thinking about shaft rockers using 1.8 on the exhaust while keeping the 1.7 on the intake. The car put 649ftlbs to the tire and the plan is to get the hp way up and not loose ANY torque. I take pride in the knowledge I have building race engines, but have never been a fan of boost on the street, so lets hear some suggestions on my mods and game plan. I was going to retain the stock cam, but everything in me says I need to play with it, and I won't have to run the 1.8 on the exh. if I custom grind a cam.
Old 11-15-2009, 03:35 AM   #9
venomws7
CF Senior Member
venomws7's Avatar
Very nice man congrats..
but I thought with your mods the car had to be close to 140+mph.
any vids??
venomws7 is offline   Reply With Quote
Old 11-15-2009, 08:19 AM   #10
tomsws6
CF Senior Member
tomsws6's Avatar
yeah iv noticed these cars times are very consistant but there mph and hp is all over the place for the same times. maybe the z06 trans with this car?
tomsws6 is online now   Reply With Quote
Old 11-15-2009, 12:37 PM   #11
Katech_Jason
649 ft-lbs at the wheels
Just make sure you order some extra washers from me. The LS3 head bolt pad is lower than the LS9 so you'll need extra washers to make up the difference.
__________________
_Jason Harding
YOUTUBE
FACEBOOK
MAILING LIST
Old 11-15-2009, 02:28 PM   #12
thee Dragon
CF Senior Member
Awesome passes! You promised to deliver 9's and you're well on your way
Ditto Jason 649 lbft
any vids??
His shift point was 500 rpm earlier with the tranny swap.
thee Dragon is offline   Reply With Quote
Old 11-15-2009, 02:40 PM   #13
groovyjay
CF Senior Member
groovyjay's Avatar
Who is John Hennesey?
groovyjay is offline   Reply With Quote
Old 11-15-2009, 02:50 PM   #14
Mr.Chevy
CF Member
Any vids
Mr.Chevy is offline   Reply With Quote
Old 11-15-2009, 05:08 PM   #15
ATMER1
CF Senior Member
Was the gearset just changed on a ZR1 tranny or did you change over entirely to a Z06 tranny? I'm unclear if a direct swapout is possible due to the clutch differences and also the beefier casing on the ZR1 tranny.
Old 11-15-2009, 07:25 PM   #16
Luweegy
CF Senior Member
Luweegy's Avatar
Send a message via Yahoo to Luweegy
Your on your way to the 9's for sure.
Luweegy is offline   Reply With Quote
Old 11-15-2009, 09:43 PM   #17
HennesseyPerformance
Supporting Vendor
HennesseyPerformance's Avatar
Put a cam in it. And get the head stud kit too from Jason.
Your so close to 9's! Congrats.
HennesseyPerformance is offline   Reply With Quote
Old 11-16-2009, 04:11 AM   #18
venomws7
CF Senior Member
venomws7's Avatar
Thanks for clearing that up
9s shouldnt be a problem.
Old 11-16-2009, 09:52 AM   #19
Black730
Forged
Quote:
The transmission casing is the same for all TR6060 transmissions. It is only the internals that are different.
Now when it comes to the differential, the casing is beefier on the zr1 as compared to the z06, which is beefier than the c6.
__________________
936rwhp/932rwtq - Dallas Performance Forged 416, F1R, Callies Crank & Rods, Diamond Pistons, ETP Heads, FAST 102, NW Throttle Body, Full Grandsport Widebody, Z06 Brakes, RPS Triple Carbon Clutch, ZR1 Trans & Diff, DSS Axles, Pfadt Coilovers, DP Big Mouth Intake, DP Boost By Gear, AR Headers, DP Dual Meth Injection, DP 1000hp Fuel System, DP 8 Rib Direct Drive, DP Blower Cam, B&B Fusion Exhaust, Dewitt Rad/Fan, DP 3.5" Propshaft, 4 Point Cage
Black730 is offline   Reply With Quote
Old 11-16-2009, 10:35 AM   #20
MTIRC6Z
CF Senior Member
Congrats John!
What kind of launch RPM were you using and what brand/size of rear tire?
With regard to the ZR1 diff, it also has the cooler line exiting from the rear of the case as opposed to the bottom. This is nice to know if you're putting it in an '08 or earlier Z06 because you need a fairly significant notch in the cradle.
Cheers, Paul.
MTIRC6Z is offline   Reply With Quote
Reload this Page 10.24@ 133.51
Tags
night, run
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
VANITY PLATE LIST of MEMBERS - UPDATED AC54ME C6 Corvette General Discussion 1936 12-28-2011 10:04 AM
"BBQ at The Baymont" - List of Attendees RoscoesC5 National Events 104 05-25-2005 08:45 AM
In the fairness of full disclosure. 93 ragtop's bins. scorp508 C4 Tech/Performance 248 03-26-2005 12:00 PM
Is the Z06 this fast around the ring? Video TAXFREE C6 Z06 Discussion 48 02-24-2005 10:41 PM
rear gears for the 1990 6-speed 1990dtgL98squared C4 Tech/Performance 19 08-05-2004 07:47 PM
AM I CRAZY?!! 4.10's? joe2gaan C5 Tech 30 12-17-2001 02:51 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
